Question about Microsoft Xbox 360 Console
No Video... When I turn the system on I only get some diagonal fuzzy lines. It worked fine the day before. I get sound and you can hear me going through menus and games read and load fine, I just can't see anything.
Mine did the same thing! i think it is static build up in the tv! Ventilate the room turn tv and xbox 360 off. unplug everthing and make sure the vents are not covered on both the tv and xbox 360. mine has not played up since!
Posted on Jun 26, 2007
  • 85 Answers
Try and return it. It sounds like something is wrong with the cousel itself. Unless your tv is completely mess up. send it back. thanks connie
Posted on Jun 25, 2007
Sounds like a GPU problem to me. Time to get on the phone to Microsoft :(
SOURCE:
Hi my problem is at first my xbox 360 went on fine then after 10 mins the screen started going fuzzy so i turned it off then back on was working fine for about half an hour then the screen started going...
If you hear sound but no picture then your graphic chip has got separated from your motherboard, this is not a simple fix. receommend you to look for a local repair shop that can handle game console repairs or send it to xbox.com
Thanks
www.1RepairStop.com
Sep 11, 2011 | Microsoft Xbox® 360 Core System Console
When I turn on my xbox the screen shows lines and colours and green/red dots. I can make out what is on the screen but it is fuzzy. The sound is also wrong, on and off and strange when you can hear it. I...
I would try cleaning the connections to the xbox and the TV. Also you could try connecting with a different type of cable (VGA or use the HDMI cable).
If that doesn't clear things up then you could have a hardward problem with your xbox.
Feb 28, 2011 | Microsoft Xbox 360 Console
My system works fine but some demo downloads won't play I have sound but the picture shows diagonal lines across the screen
Maybe the Demo Game isn't compatible with your TV, or your PS3. Try going to a friends house (who has a PS3 obviously), and try downloading that game on his. If it works, it could be just your PS3. If not, its probably the Game itself.
Jan 03, 2011 | Sony Playstation 3 (PS3) Console
My 15 year old Home theater RCA tv turns pink with diagonal white lines after 15 minutes
Are you using a component video cable to feed into the TV? If so... your cable may be bad. If you have different video outputs from the home theater system then use one of them such as a yellow composite video or S Video (round with multiple pins) . However, the fact that it's happening after a period of time suggests that something electronic is about to go. If you have another TV in the house to connect the system to then go ahead and do that. If it works fine on another tv then you have a problem with your old tv.
Feb 06, 2010 | RCA RT2380 Home Theatre System System
Xbox 360 Blurry/Fuzzy Screen
The machine is overheating and the graphics chip on the main board is acting up cause of it. Make sure there is no dust or dirt blocking the air vents that would cause the system to heat up more then normal.
If that doesn't do it then maybe think about getting a cooler for the system, here is a website that talks about a few of them. Click here.
If that doesn't help then your mainboard is going bad and would need to be replaced.
May 29, 2009 | Microsoft Xbox 360 Console
Screen failure
sounds like ur xbox is about to go red light soon. It is fixable and i can list the steps for fixing it if u'd like. Kinda complicated, but ive fixed 30+ systems using the process
Jan 13, 2009 | Microsoft Xbox 360 Console
Video channel has diagonal lines
check the connections from your video to your tv, sounds like you have a loose wire,
If not re-tune your tv , it might have lost the tuning a bit , but its probably a loose connection
Feb 28, 2008 | Televison & Video
Microsoft Xbox 360 Console Logo
87 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
