Question about Sony PFM-50C1 50 in. Plasma HDTV
There are black lines runnin vertically on my tv. theyre bout a 1" wide & run 1/2 the screen. 6 on the top, 1 on the bottom.
The tv was given to me, so i dont mind working on it. im good with an iron, just need to know where to start. can any1 help please?
  • scot Jan 01, 2013
    i do have the service manuel
vinnyq
  • 157 Answers
SOURCE: Hello! I have a problem with my kdf-e50a10 sony
This is caused by a failure of the optical block of your TV. The only way to fix the issue is to replace the whole optical block which is very expensive ($1000+) and time consuming (need to take whole TV apart to replace the part).
The optical block in your model had inherent issues and there is currently a class action lawsuit pending against Sony for this issue. Up to date information reguarding the lawsuit can be found here: http://www.sonya20tvclassaction.com/main/home.sfx
Posted on Oct 07, 2009
Testimonial: "Very Helpful, Thank you so much!"
JoeO700
  • 80 Answers
SOURCE: Vertical Black line on display
Rakesh, You have a "dual scan" panel, this is why the line only decends down the screen half-way. This could be a connection problem on the buffer board which causes loss of the drive signal only to that part of the display which it is connected to. The vertical address buffer will be located on the top rear of the display, use great caution in inspecting these cables and connectors. If the integrity of the cable and connector is good the panel itself may be bad due to the drive IC being located on the ribbon cable attached to the panel body. this is better known as COF or, chip-on-film technology. I hope this helps you. Good luck. Joe Weibel CustomElectronics.Org
Posted on Apr 24, 2007
SOURCE: Vertical line on TV
usualy this problem is cause by the lcd drive board.
Posted on Oct 24, 2007
mistersony
  • 320 Answers
SOURCE: Lines on tv screen
Both sound like bad LCD panels. The following must be answered to confirm this:
Do the lines appear on all inputs/all signal sources?
Can they be seen in the OSD/menu?
If yes to both questions, it is likely that the LCD panel is bad
Posted on Oct 20, 2008
  • 68 Answers
SOURCE: Permanent Vertical Line on my Sony Bravia 46 inch LCD TV
What you're describing is usually the result of an improperly seated connector. With the power disconnected, open the tv and locate any connectors between the LCD screen and the driver circuit board. Unplug them, and reconnect it assuring it's properly and firmly seated. Be careful when handling these cables as they tend to be quite fragile... take your time.
Posted on Nov 28, 2009
Black vertical lines comes and goes on my 46" BRAVIA LCD TV. Lately the lines stay there longer. It is mounted to a wall and after about 3 years this started.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
See the site in magazine view.
Jul 02, 2016 | Sony KDL-46XBR5 46 in. LCD HDTV
Fix samsung plasma vertical black bar
Line faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
Mar 27, 2016 | Samsung PN50A450 50 in. Plasma HDTV
Vizio XVT3D650SV 65-Inch Theater 3D Edge Lit Razor LED LCD HDTV has a black vertical 6" wide line on the right side of screen. What is causing this problem? Is it the T-Con board?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 23, 2016 | Vizio Televison & Video
Panasonic Plasma tv model TH-37PX50U. Black vertical line about 3 inches wide runs up middle of screen about 1/3 of the way to the top. What is causing this?
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 22, 2016 | Panasonic TH-37PX50U 37 in. HD-Ready...
How to i fix my Samsung Plasma TV which has a 3" wide black vertical bar down the middle?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Nov 29, 2015 | Samsung Televison & Video
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
My 50" Samsung Plasma TV Has a white line going vertical on the screen when the TV is on. he line is about 6" from the right edge and is 1/2" wide. What's wrong? What is the fix?
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jan 14, 2015 | Samsung Televison & Video
Approximately. 2" wide vertical black line top to
You may need to adjust the resolution of your laptop to fill the full screen of the TV.
Sep 27, 2013 | Televison & Video
Black vertical line appears on plasma tv screen
Jun 03, 2017 | Philips 42PF7320A 42 in. Plasma HDTV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Sony PFM-50C1 50 in. Plasma HDTV Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
