Question about Whirlpool Dishwashers
Found a part at bottom of dishwasher... Black kindof cap with a separate spring. I couldnt find any place in the filter system or elsewhere, that it could fit. It might not even be a part of the dish
W10431032A
jsrock516
  • 5911 Answers
SOURCE: black stuff in the bottom of the dishwasher
That black or gray stuff you're talking about is actually a combination of old food particles and soap deposits. The stuff builds up in the corners of the lower front areas of the tub and right under the inside of the door where it closes over the tub front. These areas can develop "scungy" deposits because these are areas that the dishwasher doesn't always clean and/or water remains pooled. A little routine cleaning about once a week around the bottom lip of the door and the door gasket with a damp sponge will prevent this build up. Hope this helps you.
Posted on May 12, 2007
  • 338 Answers
SOURCE: kitchen aid dishwasher doesn't clean dishes in the top rack
Sounds like you have 1 of 2 problems. Either your pump is clogged or you need a bigger drain loop.
Posted on Nov 25, 2008
  • 530 Answers
SOURCE: black specks
is that a glass? can't tell. is there water curculating to the top rack? if not you probably have a bad chopper
Posted on Jan 06, 2009
SOURCE: Standing water in the bottom of the dishwasher
I had the same problem - a 10 minute fix. The issue tends to be that the trap gets clogged by debris (like broken glass etc.) and restricts the amount of water that can be evacuated by the tub.
1. Undo the trap cover (two hex headed screws)
2. Remove the trap cover
3. Remove the inner trap grate
4. BE CAREFUL NOW ! Gently remove debris - this can have broken glass in it !!! - You can use a wet vac if you have one. Ensure all debrs is removed and the trap is clear.
5. Clean trap cover and grate
6. Re-install cover and grate
7. Bingo !
Posted on May 10, 2009
  • 677 Answers
SOURCE: my viking dishwasher does not rinse the soap scum off the dishes
Its not soap, its actually calcium from hard water. There is a new product out at www.dishwasherfilter.com that solves this problem once and for all. It is a small filter that goes under the sink and filters out the hard minerals that cause these spots from the water before they enter the dishwasher. It is very affordable (like 70 bucks) and even has a money back guarantee. After just one load you will be amazed how your dishes look.
Posted on Aug 12, 2009
Electrolux EIDW6305GS1 will not run , keeps flashing error code 11 which indicates drain valve problem. I have replaced drain valve, wash pump, float valve and reed switch but no luck, still flashin
Hello Gene Skates - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. This is typically not a DIY job and strongly recommend contacting a professional to check the wiring between the main control board and drain valve since you have already replaced the drain valve.
Jan 11, 2013 | Electrolux Frigidaire Professional Series...
Electrolux dishwasher with error code 11
Hello Jason Johnson - Typically error code E11 indications that there is an issue with the drain valve, possibly the main control board is timing out before receiving status of drain valve. I strongly recommend contacting a professional to check the wiring between the main control board and drain valve.
Dec 30, 2012 | Electrolux Frigidaire Professional Series...
The spring holding the door came off. Where does it go? Is there a picture to help see?
If you take the bottom panel off there are two springs, if one is still in place you can see where the other one goes. Hope you found this helpful.
Jun 18, 2011 | Maytag MDB6000 Dishwasher
Dishwasher doesn't clean well
Just got done working on my wife's after she holler at me for the same problem...
Found that there was a ton of **** at the bottomjust inside the door. Also the float switch, which looks like and unsidedown cup at the bottom front of my dishwasher had goobs of olf food up underneath it. The spray arms were full of undisolved soap, paper, and plastic. Beats me how that got through the filter, but it did...
Also found that the bottom spray arm cap is broken...ordered parts for everything from repairclinic.com and with shipping it was less then fifty bucks...new spary arms, ends for the rack rails that were broken, the bottom spray arm cap...totally redoing the insides...
Then washed it out with a strong (couple of cups) of clorox. Then a cycle with just dishwashing detergent...my wife is happy!!! and will be happier once I install the new parts...
Also check out this tip...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
Heatman101
Mar 22, 2010 | Dishwashers
My Bosch shx46A05UC no longer will drain.....it
I ran into the SAME problem with my Bosch SHX46A06UC /21. The problem ultimately ended up being a clog in the air gap vent, (meaning, SOMEBODY ran the dishwasher without the bottom filter being in place or not in place properly). Remove the air gap cover and upper surface nut to drop the air gap vent into the area under the sink. Disconnect the hoses from the air gap vent filter (placing a bucket under the hose from the dishwasher). Run the drain cycle on the dishwasher. The washer should drain into the bucket and let you know that your pump works and that there are no clogs or kinks in the drain hose. (This will also remove the clog if so). The air gap vent's smaller hose connection is MOST LIKELY where your clog is. Look at the upper end of the air gap vent. You'll see a couple of clips on opposite sides of each other, that hold the air vent cap in place. Using a small screwdriver, (or your hands if you can), depress the clips (or one at a time) to get to the point where you can pull the vent cap off the filter. Either use water or a thin, long blade screwdriver to force any objects out of the filter. You should now have full flow through both branches of the filter. Using water and a rag, clean the vent cap and filter. Mount the air gap vent filter back onto the sink. Reconnect the hoses and remove the dishwasher's internal filter(s) and clean them as well while you're at it, making sure to remove any debris that might remain underneath the filter and has the chance of clogging the unit again.
Run the washer again to test. You should be good!
Cheers!
Oct 13, 2009 | Bosch 24 in. SHX46A05 Stainless Steel...
GE Profile Dishwasher not cleaning - older PDW7880GOOSS
My GE Profile Dishwasher PDW8280N00SS wouldn't clean the dishes. I found what looked like plastic particles along with food particles in the wash arm spray holes. I found that heat had warped the gray flat filter in the bottom allowing food particles to bypass the filter, and I found that the flexible plastic sump inlet was disintegrating internally shedding plastic which clogged the filter to the pump and getting into the pump. This shouldn't happen. The material that the sump inlet is made out of is too soft and porous. I noticed other components in the wash water system made from the same white flexible rubber which is an unacceptable material. I bought replacement parts at a cost of $100 for both and this has solved the problem. What's distressing is that the replacement parts appear to be made of the same inferior plastic. And I have noticed upon closer inspection that additional interior parts appear to be heat damaged (warped). This dishwasher has been used less than 4 years and problems like these in a high end dishwasher are unacceptable.
Sep 15, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Dishes not completely clean or rinsed, and mold
get some dishwasher salts and unscrew the cap at the bottom of the dishwasher empty the filters and run the cycle. fill up the water with dishwasher salts in the white unscrewable cap put about two cup fulls in.there it should work better then. there is also a product called rinse add you can by this from the local supermarket. hope this helps
Mar 27, 2009 | GE Nautilus 24" Built-in Dishwasher
Kenmore Quiet3 not cleaning top rack, now stopped cleaning all
The problem is likely that the cutter/chopper filter is plugged. This reduces or eliminates water flow to the cleaning arms.
Solution:
Remove dish baskets
Remove bottom arm - Rotate the centre post until arm is free to be lifted out.
Remove conduit to top arm(s) - Remove 2 screws, one at top and one at back. Rotate whole conduit 45 deg right and lift off of centre post.
Remove bottom plastic assembly. - Remove 4 screws and lift off.
Remove cutter cap. - Remove 1 screw at front left. Lift off plastic cap. Remove cutter filter. It is on a spring loaded pin. Pull cutter blade foreword and lift filter disc straight up. Clean filter disc thoroughly
Reassemble!
Dec 24, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher Amana ADB2500AW door spring and cable
The nylon cord is part of the door spring mechanism. One end hooks over a tounge at the bottom of the door, then the cord goes around a pully at the bottom, then hooks onto the spring. If the other sides spring is still attached, duplicate it.
Dec 14, 2008 | Amana 24 in. ADB2500AW Built-in Dishwasher
My kenmore dishwasher isn't cleaning the dishes very good
Your broblem is probably the cutter/chopper filter. This is located under the bottom cleaning arm assembly.
Remove the baskets.
Remove the bottom washing arm. Unscrew the centre post and lift off the arm
Remove the conduit to the top arm(s). Remove screw at top and at back. Rotate the conduit assembly 45 deg right and lift off.
Remove 4 screws (Star T-20 bit) and lift whole assembly out. Pop off screen and clean.
Remove cap over cutter/chopper. There is one screw at left front under assembly just removed. Remove it and the plastic cap (Needs some wiggling to free it up). Remove the cutter and filter. It is on a spring loaded pin. Pull in foreward and also lift the filter disc up and out. Thoroughly clean the filter.
Reassemble
Dec 01, 2008 | Dishwashers
Dishwashers Logo
46 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
