Question about Craftsman Garden
Ran over rock and now the cord is hard to pull to make the lawnmower start
  • 429 Answers
Does it start?
Did you bend the blade?
Posted on Jan 06, 2013
  • 84 Answers
SOURCE: lawnmower
what do you mean doesn't engage? doesn't start, doesn't let you pull, doesn't cycle, what?
Posted on Jun 24, 2009
agent91
  • 2100 Answers
SOURCE: I hit a rock with my push lawnmower. The
Oooh boy, I know you bent the shaft, but why it is blowing oil out the carb, I don't know if I would even bother with the blade, you could go buy the same mower, then you would have some parts. Unless you just bumped it hard enough to throw oil around in there, it might settle down, but it is a long shot. I hit a stump once and bent the crank, it was lights out for that mower. Hope this helps.
Posted on May 08, 2010
40longyears
  • 275 Answers
SOURCE: the lawnmower won t start after pulling the start
try a touch of starting fluid right into the carburator by taking the air filter off. If it then starts but wont run or stay running, the reservoir below the carb should be removed to clean at and the pinhole in the intake tube above the bowl nut. This is the most common problem with lawnmower start problems, the pinhole can be unplugged with one wire from a wire brush. Be careful with the gas, at least pinch off the gas hose with a vise grips while removing the carb bowl.. Never use a droplight around gasoline.
Posted on Oct 08, 2010
  • 150 Answers
SOURCE: My lawnmower which is a TORO 6.5hp-Tecumseh engine
It sounds like hydraulic lock. The carb is dumping to much fuel into cylnder. Pull the plug when it feels locked up and pull again, if it blows gas out of the plug hole you have carb problem. Maybe needle is ****, maybe float has a hole in it and is sinking causing flooding.
Posted on Oct 11, 2010
Testimonial: "Thanks,my inlet seat needed repl. "
SOURCE: My lawnmower pull cord is stuck. I cannot start my
Need to replace pull cord
Posted on Apr 23, 2011
Pull Cord Stops...
could be valve needs set. if it isn't opening at the right time it wont release compression for it to start. it may be the shear key in the flywheel has sheared if you have hit something like a big rock or log or something causing it to die suddenly.
May 17, 2016 | Craftsman Garden
Pull cord won't pull on Snapper 6.75 exi
HOW TO Replace a Broken Lawnmower Pull Cord - YouTube
? 5:53
www.youtube.com/watch?v=G02OobT7fII
Oct 4, 2011 - Uploaded by donyboy73 Easy to follow video tutorial on how to repair a broken lawnmower pull cord. The procedure for this lawnmower ...
Sep 21, 2015 | Snapper Garden
How to fix Mower cord stuck after hitting rock?
Pull the plug. MAKE SURE THE PLUG IS COMPLETLY REMOVED AND SEPARATED FROM THE MOWER!! Remove the cover with the pull start attached. see if you can turn it by the flywheel or the blade. If you can, you can just have the rewind repaired.
If not, then you have a probable bent or twisted crankshaft. Most likely not worth repair.
May 16, 2014 | Electric Lawn Mower
When i pull the cord on my lawnmower it kicks back and pulls the cord out of my hand
sounds like the SHEAR pin is broken, replace shear pin, this can cause the timing on the motor to be off. it is designed to protect the motor from hitting a stump, a rock, etc.
Oct 01, 2012 | Tecumseh 4.5hp Engine Model Tvs115-570138
Bolens 4.5hp mower won't start
did you hit a rock? and shear the key that times the flywheel to the crankshaft check for spark the coil might have failed
Jul 01, 2012 | Briggs & Stratton Briggs Stratton...
Briggs and stratton lawn mower 4 stroke engine
did you hit something while mowing the key way between the flywheel and crank shaft might have sheared it will act like the blade is missing pull back on you while pulling the rope
May 25, 2012 | Briggs & Stratton Briggs Stratton...
Lawnmower hit a stump and now can't pull starter cord
you may have bent the crank shaft if it pulls hard and pulls back then remove the flywheel and check the key
Apr 01, 2012 | Garden
My lawnmower which is a TORO 6.5hp-Tecumseh engine won't start. When I pull the cord the valves start to move but on the second pull it seems to sieze up and blow some vapor out the exhaust.It ran fine...
Oct 11, 2010 | Toro Garden
May 07, 2010 | Mtd 22" Yard Machine Push Mower
Toro GT5 lawnmower - the pull cord (to start the engine) only comes out about 3 inches - I'm afraid to pull to hard for fear of breaking the line.
First - remove spark plug and squirt 3mls of engine oil in there - replace spark plug and leave overnight.
Try pulling that start handle !
Two things may happen - it snaps or - it turns over.
If it turns over - prime fuel and start in choke setting.
If the cord snaps - undo the pull start block - and take it to a lawnmower spares depot, and buy some more cord. It's quite cheap.
Get the length right so you don't have too much.
Next - the engine is probably seized - so needs freeing up. You may be able to do this with the new cord, Otherwise - take the head off the cylinder and tap the piston down with a wooden drift while turning the crank.
Use a non-setting gasket sealant like hematite red to re-use the old gasket. Lawnmowers are quite resilient.
Jun 29, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
44 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
