Question about Sony Playstation 3 (PS3) Console
No communication between PS3 and TV
PS3 consoles turns on, however, the PS3 menu screen does not appear on the tv screen and the game will not play.
  • 4 Answers
Try geting a new hdmi cable or a new av cable and plug it in turn on the ps3 let it sit turned on for a while and a message should pop up saying it has found a hdmi or av output witch ever you are using and it will ask you if you want to use it as the ouput to the tv and then you will select yes. if that dident work your gpu (graphics processing unit) has over heated and you will have to send it to sony or take it apart and reflow the prosesers and gpu
Posted on Feb 08, 2013
J4XXN
  • 182 Answers
SOURCE: Source list for Samsung LCD TV when hooking up PS3
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option. hope this helps
Posted on Jan 08, 2008
  • 135 Answers
SOURCE: PS3 BD payback causes a pink screen
Dear customer
sir,,i think ur avr receiver is not working ..tty to change that
thanku
Posted on Jul 16, 2008
SOURCE: Ps2 slim won't start, plays intro sound and TV screen goes blank
I turn on the console: the disc spins, the led is on, the boot sound is played, but the screen remains blank. No further sounds are played as well (e.g. the Browser sound or the game's sound). The cable appears fine (since it plays the console boot sound).
Posted on Oct 11, 2008
localwonder
  • 6784 Answers
SOURCE: blue rays not playing and screen says no signal
This is blue ray lens failure. this optical Assembly has two separate reading lenses. there is one designated for Cd audio and CD_ROM reading and, the other is blue ray compatible. the blue ray lens in inoperable at this point. you will need to replace this lens assembly.
Posted on May 27, 2009
  • 105 Answers
SOURCE: PS3 Flickers on and off on the screen
Is could be your TV and not the PS3. When the resolution of the screen changes, you TV will flicker to adjust to the new resolution. My TV flickers in a similar way when playing games of lower resolution than my HDTV.
Posted on Jul 14, 2009
The play station turns on but the menu is not coming up. The wave line is on the screen of the TV
Same problem just happened to me. Playing a game and the game froze. Sat there in shock for about 10 to 15 seconds and the screen went black. Shut it off. Now every time I go to turn it back on again it starts up, I get the PS3 logo and then the blue wave starts. About 5 seconds after that the wave starts to lag and then nothing.... Stays on the lagging blue wave screen... THIS BLOWS!!!!!!!!!!!
Jun 15, 2010 | Sony Playstation 3 (PS3) Console
I changed my tv and in new tv whenever i try to
You need to try and change you video audio settings for that tv,on your ps3.
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
I have 2 ps3 consoles one new slim model other is older model both attached to 1080p 120hz tv's one sony one sharp aquos both using top of line $300 monster cable hdmi cables. The ps3 menu screen on both...
did you try going through the settings to configure yur tv with the game console so they could work together properly.also make sure your hdmi cables are good ones.and also try to reset the contrast,brightness etc of the tv.
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
Today after playing a game I moved the console to another tv and now the ps3 will start and play the short intro but it will not continue to the menu screen where you can select video,internet,dvd ect......
try using a different cable to connect the ps3 to the tv it might be looking for a different type of cable if this works you can set to look for the right type of cable under screen settings
Dec 11, 2009 | Sony Playstation 3 (PS3) Console
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
My tv get snow when i try to play a game
Try using another TV. If you don't get the same problem then it's the TV and not the PS3. You might also want to try changing the display settings so that you're using the correct outputs.
Feb 18, 2009 | Sony Playstation 3 (PS3) Console
Dvd or game not playing
If this is an issue you have always had (meaning you just started using the system) it may be a resolution problem. If your PS3 is set to display movies or games in a resolution your TV can't handle, you'll get issues like this. Go into your video settings in the bar and check to make sure you don't have it set for something your TV can't do. My TV, for example, won't do 720p.
Jan 08, 2009 | Sony Playstation 3 (PS3) Console
Playstation 3 Does not display on TV using HDMI or regular video cable. senerio: My son hook it up using HDMI Cable to my bedroom sony flat screen tv to watch a blue ray movie and play some games. which...
I posted to your problem with a similar one. I was able to get my PS3 to work by:
1.) Powering down both the PS3 and ViewSonic LCD
2.) Unplugging the power cables to both PS3 and LCD
3.) Waiting at least 10 or more seconds
4.) Plugging in the power cables to both PS3 and LCD
5.) Turning on the ViewSonic LCD
6.) Turning on the PS3 and holding down the power button until the beep
After this sequence I heard the bootup audio and the menu appeared on the screen- which detected the HDMI connection to my LCD.
Very odd.. I've had my PS3 in the same place for months and just today this happened.
I wanted to post my success. Best of luck!
Seth
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
Fixing BD movie disk on UK Ps3
Try a Blue Ray lense cleaner dont where to get
Sep 15, 2008 | Sony Playstation 3 (PS3) Console
No picture any more
if your tv has a light blub replace it this is only for hdtvs
May 10, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
