Hitachi Model # 53fdx01ba v1b002594 has a red shadow on picture
I have a hitachi Model # 53fdx01ba v1b002594 that has a red shadow appears on objects on the tv. Is there a way to fix this on my own? I have had experience pulling apart smaller tv's and fixing boards before, but this is my first time messing with a projection type tv.
MikeNJ1964
  • 398 Answers
SOURCE: 52" HITACHI PROJECTION ----50UX27KV6J009857
If you mean that one of the colors has suddenly drooped toward the center, creating a curve along the side where the colors no longer line up, it means that one of your convergence IC's has burned out and needs to be replaced. You should not play with the convergence settings when this happens because when the IC is replaced, the settings will be all out and have to be reset. It is a good idea to replace both STK392-110 IC's with the newer improved STK392-150's. If you have never replaced convergence IC's or realigned convergence circuits then allow a qualified tech to handle it for you.
Posted on Aug 07, 2007
ctf1800
  • 4402 Answers
SOURCE: shadow around objects in picture...shadow is bluish
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
Slinteriors
  • 8617 Answers
SOURCE: Hitachi Projection tv Model 43FDX10B
Green and Blue tubes need the coolant changed.
Posted on Jan 13, 2008
  • 4234 Answers
SOURCE: Hitachi 43VWX10B Rear Projection Television - color adjustment problem
Either the pins on the convergence ICs need to be resoldered or the ICs need to be replaced. These are large black ICs attached to a heat sink and should be marked STKxxx. Resolder first. If that does not resolve it, replace the ICs.
Dan
Posted on Mar 17, 2008
doin12volt
  • 233 Answers
SOURCE: Blue and yellow shadows on my Hitachi rear projection TV
The color has gone crazy on you because your convergence IC's have gone bad.
These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.
Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go.
If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!
Hope that helps!
Posted on Dec 21, 2008
My hitachi big screen has red shadows on picture how do i fix it
What you described sounds like a convergence problem. When convergence has failed the colors will commonly look 3D,warped, etc. This tips page here on Fixya has more details.
Jan 27, 2013 | Hitachi 43FWX20B 43" Rear Projection...
HITACHI 53FDX01BA THE PICTURE IS GETTING DIM. ALL THE COLORS LOOK GOOD EVERYTHING IS JUST GETTING DIM
This is a common problem on this Hitachi model. You can get the parts and repair instructions from www.TvRepairKits.com. In most cases the TV will look real dim or have no video...but audio will work,
Jul 18, 2011 | Hitachi 53FDX01B 53" Rear Projection...
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
53 INCH HITACHI RED CONVERGENCE
This is a defect most likely on the convergence board.
You should have the manufacture authorized service people repair the set. You can end up buying a convergence board, and the service manuals, and still have some other faults.
For information and parts, look up the Hitachi home page on the net and go to their support area.
Jerry G.
May 18, 2008 | Hitachi 43FDX01B TV
Hitachi 53SWX01W Distorted red lines and shadowing.
replace the conv ic,s stk392-110 and ck for any bad rest in that circuit
Apr 14, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Colored shadows on sides of subjects
Convergence problem... most likely caused by convergence ics
Jan 18, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
158 people viewed this question
Top Televison & Video Experts
