Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
I have a 02 600 XC edge the temp light come on and off when the light comes on the motor starts to run rough also when you give it acculturate the light comes on
I have a 00 700 XC and my temp light and engine use to do the same thing. I raised the hood once and noticed the temp sender wire had rubbed bare and a cylinder head bolt and was shorting out. Just an idea??? Not sure if it would cause it to run rough though, it seems as if mine did as well a few years back.
Posted on Jan 03, 2013
2001 xc barina won't start,kicking over but won't start.got fuel and never had a problem before?
Holden Barina turns over but won t start Questions ... - Fixya
www.fixya.com > ... > turns over but won t start > Cars & Trucks > Holden
Holden Barina cars & trucks turns over but won t start questions and answers. Ask your ... 2002 barina xc automatic choke does not work when motor is cold.
Holden Barina XC (2001-2005) Questions & Answers ...
www.productreview.com.au > ... > Hatchbacks > Holden > Holden Barina
Holden Barina XC (2001-2005): 27 questions and 40 answers on Australia's ... My 2004barina won't start, inspection symbol comes on a Speedo then flashes.
2002 Holden Barina Comments (r97719), Page 3
www.carsurvey.org > Holden > Barina > 2002 > Review
Feb 05, 2016 | Cars & Trucks
Why are so many trouble diagnostic codes being thrown
sounds like you speed sensor and your throttle poistion sensor
Sep 02, 2014 | Cars & Trucks
Snowmobile troubleshooting
most newer machines derate (reduce power) when the temp light comes on unplugging it may not change anything because the ECM still senses a problem with the temp maybe a sensor problem
Feb 12, 2014 | Winter Sports
I was driving out 2003 thunderbird yesterday and about 5 minutes after I left home the overheat light came on and then the engine light. It started to run rough so I immediatley went home. The guage of...
u need to take somewhere and have codes scanned (most parts store do this for free) my best guess is it probably a bad coolant temp sensor (u have 2 of them one for gauge and one for computer) one that probably bad is one for computer (should be one with two wires)(one with one wire is for gauge) if temp sensor is reading that the motor hot it will adjust air/fuel ratio for a hot motor but if motor is actually cold it run bad
But to know for sure u need to at least get codes scanned
Jun 28, 2010 | 2003 Ford Thunderbird
Car runs rough at idol,hard to start after it warms up.
048 Engine Hard to Start or No Start Scan Data for Starting Problems This is how you find problems like your's , viewing scan data , sensor data parameters . What are the fuel trims at ? +- 5 to 10 % . short an long term trims . Do you know what these are ? Are the O2 sensors switch normally ? What's the coolant temp ? Intake air temp . Is the check engine light on or flashing ? Mass air flow sensor data . Misfire codes ?
047 Engine Hard to Start or No Start Scan Data for Ignition
056 Engine Hard to Start or No Start Misfire Scan Data
Sep 12, 2017 | 2005 Chevrolet Malibu
My 1987 Toyota Tercel will not run. It will start, but wont stay crunk unless im giving it gas. I check for vacuum leaks and no sucess.?
if you have a carburator then you have a blocked idle jet, simple job unscrew **** dirt out clean jet hole through, replace, (change or fit fuel filter to prevent it happening again. )
to tune is simple replace jet start motor and warm up . when at operating temp turn jet out and then in till motor runs rough then screw back out til motor smooth out , and runs sweet, if it cuts out when slowing car down (while driving) screw need to come out a slight bit more
Dec 20, 2009 | 1987 Toyota Tercel Liftback
Car starts but stalls and cuts out what is wrong. the car will start but runs rough and when you try to give it the gas it will die.
if your check eng light is on get it scaned to see why .if not you could need a good tune up or have weak fule presure or a pluged converter
Jul 12, 2009 | 1994 Ford Taurus
Rough idle after warm up
I'd take a look at the temp sender...the engines computer may be "thinking" the engine is still cold when it's not. That would cause it run rich (and rough) after it's warmed up. Generally the sender can be tested with an ordinary volt/ohmeter but you will need the specifications available in most inexpensive manuals. As with any complicated electronics system, I can only give you my best guess, without the luxury of doing any hands-on testing myself.
Good Luck!!
May 28, 2009 | 1991 Cadillac DeVille
Check engine light is on, motor runs rough, sometimes stalls
Go to Advance or Auto Zone and have them run an obd scan on it and it will pin point why your light is on and could solve your problem. This is often done for free.
Apr 12, 2009 | 1998 Chevrolet Tahoe
Volvo v70 xc- i have a noise comming from near or
If your car has the xenon headlights, it might be a faulty xenon ballast/regulator module. You car has daytime running lights so they are on at a low power setting all the time.
Mar 28, 2009 | 2002 Volvo V70
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
204 people viewed this question
Top Polaris Winter Sports Experts
Larry Fostano
Larry Fostano
toddgilbert
toddgilbert
Todd Arndt
Todd Arndt
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
