Question about LG Televison & Video
Trying to upgrade the firmware on my lg 26lh20d television
How to upgrade firmware on LG 47LN5750
You can upgrade firmware from there official link
Dec 10, 2016 | LG 47LN5750 47" LED TV 1920x1080, 120 Hz,...
How do I upgrade my LG LH 20 lcd tv firmware
As far as I can see on the support page, here: Product Support
there is no firmware upgrade. An upgrade is only made, when several people have a issue with there device, and it can be solved by upgrading the firmware. Ir is NO SOLUTION for real defects.
You even can't upgrade if the device is not working correct.
It needs to run a short program, put is a small part of the RAM, and during the upgrade it can't lose power, because the little program has to flash (put new software in) the electrical erasable memory.
When something goes wrong during the update, nothing works and you need to visit a service centre to put things right.
As long as your TV works fine, don't update. When LG really does have an update, they will email all registered owners and carefully explain how to do the upgrade.
To be sure about any updates, register your TV on the support site.
When you have a problem with the TV contact LG or a certified repair centre close to you.
It would not be wise to try to change something on your TV, as long as you are not 100% sure it would improve the TV.
Jan 18, 2015 | LG Televison & Video
Lg 3d tv
You may want to call LG to see if there is a firmware upgrade for this model for this issue--sound like it may be firmware problem.
May 30, 2012 | Televison & Video
How to do a firmware update
Contact LG and unless absolutely needed do not upgrade just to upgrade--seen a lot of sets where it makes matters much worse.
LG should know if upgrades are available and what the reasons for them are.....
May 16, 2012 | LG 32LG30 32 in. LCD HDTV
I have a sony blue ray DVD player and when I connect it via HDMI cables into either HDMI1/DVI or HDMI2, i get the message invalid format. I've tried multiple cables, multiple LG TV's, and the it...
Tries tv unplug,replug it back like about an hour later.Than tries go into the tv menu do a resetting to factory setting in every settings on the tv.Than reconnect the Blu Ray player again should work.If not the tv and Blu Ray player softwares main firmware just not compatibles.The only solution is just don't used it on this tv,because if u tries to upgrade the tv firmware or the Blu Ray firmware and u get the wrong upgradable version in the tv or Blu Ray player.That it u in deep ****,than the tv or Blu Ray player well not functions at all or have multiple orperational problems during it playing times.
Jun 18, 2011 | LG 42LC7D-UB Television
Im trying to find a firmware update for my LG 47LG50 47" LCD TV? where and how do i do this?
I've checked the LG support website. The product is discontinued but if you register your product you may get downloads of firmware upgrades, etc. With my phillips I couldn't see any firmware upgrades until I registered my product. Register here!
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=47LG50&matchedModelCode=1000003999&searchEngineModelCode=47LG50&initialTab=documents&targetPage=support-product-profile
Please rate if this helped :)
Mar 10, 2011 | LG 47LG50 47 in. LCD HDTV
I reciebe all the new channels but 7mate and gem have no volume, I have tried everything is there a certain cord or set top box I need.........Please help....
i have had this same problem with many of my customers of late...have not found and hard and fast solution however try retuning the tv or upgrading the firmware. I think you may have to contact LG regarding a firmware upgrade as this tv has no network connections or usb ports. i had to replace a set top box for a newer model for this same reason.
Oct 07, 2010 | LG 42LC2D 42 in. LCD HDTV
Invalid format error with P1600 blu-ray and LG LCD TV 42"
It may be a firmware issue if hdmi works with other items such as playstation.
If no hdmi the main Pcb hdmi ports are bad and the main Pcb would have to be replaced.
Consumers cannot upgrade the firmware so a shop would be the only option.
Jan 17, 2010 | LG 42LC2D 42 in. LCD HDTV
How can i tell if my lg tv has the lip sync firmware fix
In the menue go to Update firmware. It will display the firmware number. reply no when it ask if you want to upgrade. Contact LG any tell them the numbers. They will tell you if firmware upgrade is current or not. They will send you the upgrade if it's needed.
Nov 22, 2009 | LG 55LH40 55 in. LCD HDTV
Televison & Video Logo
48 people viewed this question
Computer Repairing
Computer Repairing
