Question about Proform Exercise & Fitness
Treadmill skipping during run - Proform Exercise & Fitness
    Top Expert:
  • Proform Master
  • 12,223 Answers
Please see the video and proceed according.
Happy new year . God bless you
Posted on Jan 01, 2013
Treadmill belt doesn't run smoothly
First of all lubricate the treadmill. If it didn't workout then try to tension the walking belt.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
https://www.youtube.com/watch?v=b1MU7MvBETs
https://www.youtube.com/watch?v=JC72OIKdluY
Dec 27, 2015 | Bodyguard T240 Treadmill
ProForm Space saver treadmill was closed while inclined, belt skips and moves to side
see the video and proceed according. God bless youlube the rack and pinion of elevation motor, and adjust the small POT attached. see the diagram attached.
Apr 05, 2013 | Exercise & Fitness
I have a Image 15.0 R treadmill. It skips and I tried tightening the belt 1/4 turn as directed and not over tighten it. Still skips and actually squeaks now especially when running on the treadmill at 6...
3 different possibilities in my opinion:
belt is too loose, belt is too tight, belt is worn out.
Try to lift the belt and get your hand under it in the middle of the deck. If you cannot reach, it is possible that your belt is too tight. Another clue for this would be the belt "curling" on both sides at the edges. Try to loosen the belt, gradually and testing it along the way.
If on the contrary you can easily slide your hand under the belt from one side to the other, it is more likely that the belt is too loose. The squeaking might be due to the belt not being "square" on the deck. Try to loosen it even more until you can slide it with your hands across the deck. And have it aligned evenly at the front and back. Then retighten and adjust the tracking at low speed.
!!! Do not over loosen as the bolts might come out of the back roller.
A worn out belt might squeak and skip when its old.
Mar 04, 2011 | RTO Image 15.0R Treadmill Walking Belt
Tread skips or stops when running
On my Epic you can adjust the belt tension by using an allen wrench in the holes on the end of rails. Tighten 1/4 turn on each side and see how the tension is. Repeat another 1/4 turn if necessary.
Nov 29, 2010 | Epic Overstock T60 Treadmill Treadmills
Belt skips
This typically means the belt is worn - or not tensioned properly.
Look in your owner's manual - and it will tell you how to properly tension the belt with the included spanner wrench.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 27, 2010 | Proform 540ls Treadmill Walking Belt
Belt squeaking and hesitating when I run
Before beginning this repair: Check to make certain that the drive belt requires adjustment. Check out belt slipping instructions or with the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
Step 1- Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust. Step 2- Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts. Step 3- Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts from Steps 1 and 2 and test your treadmill for slipping. If belt continues to slip, repeat Steps 1, 2, & 3. If a second attempt does not repair the problem, skip to Step 5. Step 4- If your treadmill is not equipped with a bolt as described in Step 3, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step 2. Tighten the bolt from Step 1 and test. If the problem is not corrected, repeat Steps 1, 2, & 4 and retest. If problem persists, skip to Step 5. Step 5- If you have arrived at this step, let's make sure you have a drive belt tension problem. With the motor cover removed, walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced. Step 6- The belt should be able to be turned by hand at approximately a 90 degree angle from its normal operating position
Jun 02, 2010 | Proform Exercise & Fitness
Belt skips
take the cover off, if the front drive roller continues to turn when the running belt stops, tension the running belt by using the rear adjustment screws. One full turn on each side should do it. If the front roller stops turning but the motor doesn't, tension the drive belt by adjusting the motor back.
May 26, 2010 | Proform 760 CrossTrainer Treadmill
Tread Mill Skips Jerks Every So Often
Your treadmill is trying to tell you its due for a tune-up!
Jan 16, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
41 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
