Question about Fanimation FP320OB The Islander® FP320 Series Oil-Rub’d Brnz Ceiling
My Fanimation Islander FP320 stopped working, I've replaced the wall switch but fan won't spin and lights won't dim.
    Genius:
  • Fanimation Master
  • 1,617 Answers
Check to make sure your fan is set on the high speed & the light is at the on possition with the pull chains.
Posted on Jan 24, 2013
Help. I need help properly connecting wires on a new ceiling fan.
Usually, the fans with remotes will dim the lights by holding the light button for a few seconds. So, the red wire would stop this feature if wired directly to the fixture. That would eliminate the wire coming out of the receiver for the lights. If you want the light to dim, then tape off the red wire, so the remote will dim them. The wall switch won't work anymore. If you want to connect the red wire , tape off the wire from the receiver that connects to the light sockets and connect the red wire to the wire for the light sockets. This will operate the fan but the remote will not dim the lights. If you have a motor speed controller in the wall from the old fan, remove it and replace it with a switch or eliminate the switch altogether so the remote will control the fan speed.
Nov 13, 2016 | Dryers
Fan was installed but only one side of the wall switch works giving power
confirm from contractor otherwise replace with normal on/ off switch.
Oct 05, 2013 | Dryers
Lights won't work on Harbor Breeze ceiling fan
Ceiling fans operated with remote controls, pull chains, and/or wall switches tend to get confused and just fail. You can try disconnecting power at the source and, while pausing briefly, remove batteries from the remote and push all buttons to eliminate the "stuck button" cause. Then, reconnect power and try various combinations of controls until something works or you give up in frustration.
May 03, 2017 | Dryers
Some functions of switch stopped working
Sounds like you need a NEW RECEIVER. Call 1-800-307-3267(Minka Aire)
Feb 13, 2013 | Minka Aire Ceiling Fan
Red light on control comes on and off and fan speed has now stopped working
You must to exchange battery for remote control 2) clean your contact with special clean contact.3) see if some wires is loose or desolder.4) Try again.
If the problem persist, you must shure the electronic board is faulty.Repair or exchange.
Dec 12, 2011 | Fanimation C23 White Fan Control Remote...
Don't have remote control how can you get it to
Don't know that fan even thou I sale Fanimation! If it came with a remote & has no pull chains then you can only use the remote feature. You can order a new transmitter, that you would have to match the dip switches in the receiver to. I would need to have model# of fan. www.fanfairceilingfans.com fanman9952@aol.com
Aug 19, 2011 | Fanimation Pedestal in White with Standard...
Mika aire remote fan
Not sure if this addresses your problem or not, but with my Minka Aire ceiling fans, the fan has to be moving in order to change the fan direction. Turn the fan on (any speed works), then push the reverse button. The fan will speed up to max, then you'll hear the gears switching. The fan will slow to a stop, change directions and get back up to speed in the new direction.
Oct 03, 2008 | Fanimation Bon Aire White Remote Control -...
Fanimation FP320OB The Islander® FP320 Series Oil-Rub’d Brnz Ceiling Logo
374 people viewed this question
Top Fanimation Dryers Experts
Michael Galve
Michael Galve
Paul Bade
Piyal Perera
Piyal Perera
Are you a Fanimation Dryer Expert? Answer questions, earn points and help others
