Question about Whirlpool Dryers
Dryer plug melting to outlet - Whirlpool Dryers
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: LG dryer DLE2516W - everything runs but no heat,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Mar 04, 2011
  • 324 Answers
SOURCE: Problem started with the plug
Please do yourself and your family a HUGE favor and DO NOT RUN THE DRYER!
You are at high risk for an electrical fire!
You already isolated the #1 cause.... lint buildup inside. The problem is that it gets inside the motor and the heater windings. It sounds like your motor is overheating and shutting down due to thermal overload....be thankful that it did so.
Your best alternative short of replacing the dryer is getting a new motor. There is a very high probability that the windings have been damaged by overheating. There are still a few appliance shops that rebuild motors, but in most cases it is cheaper to just replace, plus you then will have a huge comfort factor in knowing that it is new and not a rebuild.
Make sure the heater(s) are clean of all lint while you have it apart.
Posted on May 04, 2011
Turned on my machine light flicker now nothing, checked outlet and they are good but prongs on plug don't look good
definitely get a new power cord first if it looks burnt melted or damaged in any way. If lite still flickers check door switch
Apr 23, 2016 | Dryers
Is there setting to adjust to when using Revlon RV417 hard dryer in Europe?
Need a adapter that allows US made appliance to plug into European made outlets. Different wattage, voltage, amperes, ohm and so on and so fort. If you don't, your dryer will fry, explode, melt etc.
Aug 20, 2011 | Revlon Rv417 1600 Watt Compact
Problem started with the plug and outlet melting(plug was burnt and one of the oullet receptacles was completely melted). I replaced the plug and outlet and it would run for approx. ten minutes, then shut...
May 04, 2011 | Dryers
I smelled something burning and found the dryer's outlet box on the wall melting. Why did this happen? /
Probably due to a loose or corroded connection at the receptacle/outlet box. Most likely a loose connection, sometimes they will also corode if the dryer is located in the basement due to humidity and mosture.
Also double check to make sure your dryer venting is free from obstructions that could also cause your dryer to overheat.
You should have both the outlet & the dryer cord replaced.
Feb 11, 2011 | Whirlpool Dryers
One dryer prong burned and melted were the cord meets the dryer,do i need to replace the wire housing box were the wire meets the dryer. i am replacing the outlet and the wire
i would take the dryer apart and see how it looks inside, the real question is what caused the melt down, if it looks good then I would just replace the outlet and the cord, as long as the stud is still good. I would not run the dryer unattended as it sounds like you might have a problem, since you will have the dryer apart might as well clean all the lint out with a brush and vacuum. here is a website that will help with the dissemblance, Tim:
http://www.partselect.com/dryer+open-cabinet+repair.htm
Nov 20, 2010 | GE Profile Harmony DPGT750EC Electric...
LG dryer DLE2516W - everything runs but no heat, 18 months old, checked lint trap and vent to outside, the plug over heated and melted slightly so bought a new plug and new house outlet, dryer worked for a...
heatman101
Nov 15, 2010 | LG DLE2516 Electric Dryer
My wife started the dryer the other night and 15 min into the cycle we could smell something burning.we discovered that the electrical outlet got so hot that the dryer plug and wall outlet were melting.i...
The problem was not in the dryer, but it was a loose wire in the plug or the outlet...I have seen this happen many times.. the wire gets loose and then because of the poor connection it heats up and starts a fire...
Replace the outlet AND the plug!!
The dryer pulls a lot of current but it is not the problem...
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Aug 23, 2010 | Hotpoint NVLR333EE Dryer
I have a Dimplex CS1205. Plug hot and melted outlet cover.
Many people think melting plugs and outlets are caused by the appliance that is plugged into them. It is very likly that the outlet is worn or loose or wiring connections are loose or the receptical is faulty. Arcing is a major cause for this condition and all of the above issues can cause arcing. This condition usually only happens when high draw appliances are plugged into the outlet. So a lamp could work fine in the outlet for 10 years then a toaster or heater is plugged in and a loose connection causes current to jump from the receptical to the plug prong which inturn causes tremendous heat.
Jan 11, 2010 | Dimplex Compact Electric Flame Stove...
HAVE A 8 YEAR DRYER( Kitchen Aid)
I would be checking the service panel. I'm assuming the dryer has been working in that outlet. If the breaker is over 50 amps that is why it didn't trip. But the breaker may be bad itself. Make sure it is wired properly. Red wire should go on one side of the breaker and the black on the other. The white should go over to the neutral bar. Then make sure the outlet you plug into is wired the same way. (MAKE CERTAIN THAT BREAKER IS OFF) The top two prongs should have a red on one side and a black on the other, with the white at the bottom. If these are correctly wired, the problem is either in the breaker or inside the dryer. Depending upon the model you have, a 50 amp double breaker isn't prohibitively priced. If you buy the breaker, wire it the same, turn it on, plug in the dryer and it happens again, the dryer is at fault. Coils burn out inside them, lugs burn through, but I'd feel more comfortable at that point calling a service man, tell him what you've done with wiring, breaker, and outlets. It may be time for a new dryer.
Sirwriter
May 16, 2009 | Whirlpool LER5636P Electric Dryer
Dryers Logo
24 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
