Question about Global Star Software 100 Professional Legal Forms For Business Use (GLS99353) for PC
Cant install on windows 7
I have a 64 bit os and this disk i have is not compatible
    Problem Solver:
  • 9 Answers
You can download windows7 from windows.com for free
Posted on Jan 01, 2013
Qc848enu-Compatibility issue in Win 7 64 bit
Hello
It depend on the CPU if it is 32bit or 64bit. Windows 7 64 supports 32 bit software and 64 bit I suggest re-installing the software. It depend on the software if they have 64bit and 32bit you should install the version your PC is. Sometime 32 and 64 bit are embedded in software.
Feb 05, 2014 | Logitech qc848enu.exe
THE MITSUBISHI CP8000DW DRIVER IS DISCONTINUED HOW CAN I FIND THE DRIVER?
What OS is your computer running? I found the drivers for supported OS versions here: http://displays.mitsubishielectric.eu/resources/product/CP8000DW . The direct links are listed below. (All are .zip files so you will need to unzip them.)
Mac http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000m_macos.zip .
Win95-98 http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000dw_win95-98.zip .
Win NT and Win2K
http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cpd8000n_wnt4_0.zip .
If you have a newer Windows OS, you can try the compatibility mode. (The NT driver will likely work in XP. If you have Vista or Win7 32-bit OS, it's possible they will work but maybe not. If you have the 64-bit version, the above files will not work directly.) For executable files in Windows, right click on the .exe file and choose properties. Select the Compatibility tab and check Always run this program in the Compatibility Mode. Select the appropriate older version of Windows. Then click Apply. Close the Properties window. Then right click again on the file and choose Run as Administrator (required for Win7 and Vista).
To check if you have the 64-bit OS, click Start > Control Panel > System and Security > System (for Win7). In Vista, the steps may be slightly different. If the version name ends with x64, you have a 64-bit OS. Otherwise, you have the 32-bit version.
If you have a 64-bit OS, you need a 32-bit OS for a work-around. This can be a true second computer, a dual boot system (2 partitions with different OSes loaded), or a virtual computer with an older version of the OS. If you have Windows 7 Pro or Ultimate, you can install a virtual XP computer for free. Go to microsoft.com and download Virtual PC and the XP mode program. Install them in order. Then install your printer under XP as if it were the only computer running. (Note some computer hardware limits may stop you from using this option.) There are other virtual computer programs (VMWare, Parallels). However for the other virtual computer programs or the dual boot or second computer options, you need a licensed copy of the older OS.
I hope this helps.
Oct 03, 2011 | Mitsubishi Color Printer 8000DW Thermal
I cant install it on windows 7
Try downloading the Vista driver. Make sure that you select the 32- or 64-bit version, as needed, from http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_Z605&focusedTab=DOWNLOADS#4 . Click on filter to get the correct file. To check the version of Windows that you have, click Start > Control Panel > System and Security > System. If you see x64 after the OS version name, get the 64-bit driver. Otherwise you need the 32-bit driver.
Make sure to disconnect the data cable between the computer and the printer, if you have connected it. Uninstall any problem driver (generic from the Windows OS or a failed Lexmark driver install) before installing the new driver.
If you still have problems, uninstall the driver again. Then use the compatibility mode. Right click on the exe file that you downloaded from Lexmark and choose Properties. Under the Compatibility tab, check the box for "Run this program in the compatibility mode" and select Vista. Then right click again and choose "Run as Administrator".
I hope this helps.
Aug 11, 2011 | Lexmark JetPrinter Z605 Color InkJet...
It says it cant start or run do to incompatibility with 64 bit versions of windows....any way i can make my mission think game work? :/
The Learning Company Super Solver Mission T.H.I.N.K. was released in 1999 for Windows 3 and probably Windows 95/98. It could run under XP in the compatibility mode.
For a newer Windows OS, you need a workaround. You can use a a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software in the virtual computer using the compatibility mode and it should work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. If your computer has a USB keyboard and mouse, you will need to use Win98 or newer OS. (However, the drivers may be an issue with Win98.)
For the compatibility mode, right click on the installer and choose Properties. In the compatibility tab, check the box for Run as compatible with an older version of Windows. Then launch the program.
I hope this helps.
(Windows 95b supported USB but it wasn't really ready for the USB)
May 14, 2011 | The Learning Company Super Solver Mission...
Is the deskjet 656c series compatible with windows 7 OS?? if not, can i use the vista installer instead?? many tnx..
Yes it's compatible with windows 7. Click here Click on above link select your os windows 7 32 bit or 64 bit then download driver and install. Let me know if you need further assistance. Thanks for using FixYa.
Feb 14, 2011 | HP DeskJet 656c InkJet Printer
F5d5050 Belkin USB 10/100 Ethernet Adaptor - Does it work with Windows 7 64 bit OS? I have spent hours trying to install a Swann and a Digitech product but none seem to work with the above OS. Any...
You cannot install this adapter in a Win 7 computer because the drivers are not compatible with Win 7.
So far Belkin haven't updated the drivers for win 7 OS. The latest drivers for this adapter is compatible only with
" Windows 98SE, Windows Me, Windows 2000, Windows XP 32-bit, Windows Vista 32-bit "
Click here to see the belkin compatible drivers in the website.
With Regards,
Prema.
Jan 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
Will not install with window 7. pls write how
If I am correct this game looks old, and if it is it probably isn't compatible with windows 7. Windows 7 is supposed to have a lot of backwards compatibility but it doesn't work so well just yet. Wait a bit and maybe microsoft will patch the OS to fix the compatibility problems, then you will be able to play your game.
Mar 24, 2010 | Ubi Soft Warlords IV - Heroes of Etheria...
Cant find any drivers for vista 64 bit os
Most of the device and their driversare compatible with Windows Vista if they support XP.Still if the drive isn’t supported go to theofficial website of the hardware manufacturer and look for the drivers. Thesedrivers are generally free of cost.
Jan 05, 2010 | Tascam US-122 USB Audio/MIDI Interface...
Printer Driver compatibility with Vista??
Hi, You need to download the vista driver. Can be found on Brothers site or windows site. Here is the windows direct site link :
http://www.microsoft.com/windows/compatibility/Details.aspx?type=Hardware&p=Brother%20QL-550&v=Brother&uid=&pf=0&pi=3&c=printers%20%26%20scanners&sc=other%20printers&os=32-bit
Copy and paste and Good Luck!
Jan 31, 2009 | Brother P-touch QL-550 Thermal Label...
Global Star Software 100 Professional Legal Forms For Business Use (GLS99353) for PC Logo
62 people viewed this question
Top Global Star Software Computers & Internet Experts
David Payne
David Payne
Are you a Global Star Software Computer and Internet Expert? Answer questions, earn points and help others
