Question about Dryers
I have a whirlpool duet dryer WGD9600TWO that will not run at all, just clicks. Code says F01. Is that the thermal fuse next to the thermistor?
Code is F01. Can I get in to the fuse through the lower front panel? I really don't want to take the whole thing apart (again).
  • virginia272
    virginia272 Jan 04, 2013
    Looks like the control board is bad, thanks for the help, now I have to decide whether to buy the board or replace the dryer. NOT the first time this dryer has failed.
5 Suggested Answers
vostendorp
  • 347 Answers
SOURCE: Whirlpool Duet dryer runs for
E1 error code is a problem with the thermister sensor is is located behind the lower front panel..you do NOT have a thermal fuse concern because the unit will not run at all if its blown.MAKE SURE TO UNPLUG UNIT BEFORE REMOVING THE FRONT PANEL.. ps the thermistor is mounted on the blower housing and is kind of oval shaped ,the thermal fuse is about and inch long skinney and has 2 blue wires going to it hope thus helps Good luck
Posted on Aug 22, 2010
Testimonial: "Thank you so much for your advice. I'm going to purchase the thermal fuse as well, for the extra few bucks its well worth it. I'll keep you all posted"
blueextc3221
  • 15935 Answers
SOURCE: I have a Whirlpool Duet dryer and it cut off and
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool duet electric dryerGEW 9200 L --no heat
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$#@!
Posted on Sep 30, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Whirlpool Duet front loading dryer does not
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question*****
I am getting a F01 code on my whirlpool duet steam Dryer. MOD: WGD9600TWO
The F01 error indicates a primary failure of the control board. Try unplugging the dryer for a while (20-30 minutes); this will reset the control board if the problem was caused by a power surge. This will reset the internal breaker on the dryer. If the error recurs, the main control board needs to be replaced. However, you should inspect the wiring and the motor just to make sure that no other parts have been damaged by whatever caused the board failure.
If the model number of your dryer is WGD9600TW0, then the control unit is part w10141671. See http://www.searspartsdirect.com/part-number/w10141671/0026/110.html . Sometimes, you can repair the old control board by soldering a jumper wire (16 AWG) across a damaged solder connection for one of the relays. However, if you aren't careful, other parts on the board may be damaged beyond repair.
I hope this helps.
Jul 23, 2015 | Whirlpool Dryers
My Duet Dryer starts runs a minute or two then beeps two or three times and stops. The display lights flash, if I push start it starts again but then stops again after a minute or two. I've gone t
I would first unplug the unit and remove the top cover. There are 3 screws towards the back of it. Push the cover back towards the wall and pull off. To the left you will see a control panel (usually black metal case), remove the 3 screws and flip over so you can see the control. Make sure there are no loose connections. I have ran into quite a few that had relay connection wires loose. If everything is ok. The next thing you would want to do is remove the front lower access panel (kick plat panel) and blower chamber. There is a thermal fuse and a thermistor located behind it. If you have a meter then take the proper continuity tests that are displayed on schematic. Both the thermal fuse and thermistor are fairly cheap. Click Here for a link to a thermal fuse on a Whirlpool Duet Dryerefd097de-8d08-43d9-8d3d-9f8b17924fb9.jpg
Apr 01, 2013 | Whirlpool GEW9200L Electric Dryer
WHIRLPOOL DUET DRYER WGD9600TWO MOTOR SHUTS OFF AFTER 45 SECONDS OF USE
First you need to take off the bottom panel, using a 1/4" socket to remove the two screws that are on the bottom front corners of the dryer. I propped it up on some blocks of wood to get easier access to the screws and make it easier to slide the bottom panel off.
There is a thermal fuse (Thermistor) that shorts out if the dryer outflow is too hot. This prevents you from destroying larger more expensive components, and all you have to do is buy a $25.00 fuse. The Thermistor is located behind the blower casing, which you can reach around if you take off the bottom panel. It is a white flat plastic piece, with two connectors coming out of it. It is pretty well centered in the dryer by the blower. Just take it out with a ratchet and don't lose the screws. Make sure you clean out your dryer vent, as restricted flow because of lint is generally the cause of the failure. Here is a link to the part you will need.
Oct 14, 2012 | Dryers
Sensor light comes on when you push the start button but does not start spinning
This is a problem commonly caused by a blown thermal fuse due to a faulty thermistor or cycling thermostat depending on the model of the dryer. The thermal fuse is located on the blower housing and wired in series with the motor. The motor cannot therefore run when the thermal fuse blows open and no dryer functions works.
Unplug the dryer then remove the bottom panel and the lint duct and check continuity of the thermal fuse. You can also bypass the thermal fuse for troubleshooting purposes. Check for blocked lint filter and restricted vent system if the thermal fuse is indeed blown then replace it including the thermistor/cycling thermostat. Click on the link below for detailed troubleshooting of this common problem.
Kenmore Elite and Whirlpool Duet Dryers Not Starting
Jul 19, 2011 | Whirlpool GEW9250 Electric Dryer
I have a Whirlpool Duet Dryer model WED9400SU0. The thermal fuse went out last week. I replaced the fuse and fully cleaned the vent and internals of the dryer as well as the full path to the outside of...
to the touch the clothing should not be very hot, i see where ya have cleaned the vents(good job!!)
on occasion i have found where a fabric softner sheet has clung to the face of the lint filter housing,look at the plastic housing around the area of where the lint filter goes and see if something is stuck to it restricting the air flow into the filter housing
Jul 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Cabrio electic dryer has power but will not run
There is a thermal fuse wired in series with the motor and if it is blown, power to the motor is cut and cannot. No dryer function works when the motor cannot run. The thermal fuse usually blows due to a failed exhaust thermistor. Check for clogged lint filter and/or restricted vent system then replace both the thermal fuse and the thermistor if the thermal fuse is found blown open. This is a DIY repair which only requires very minimal effort with a screwdriver.
Disconnect power then remove the back panel and locate the thermal fuse and the thermal fuse on the blower housing.
Click on the link below for some troubleshooting information before replacing the thermal fuse and the thermistor.
Kenmore and Whirlpool Dryers Not Starting
Jun 17, 2011 | Whirlpool WED7300XW Dryer
My dryer is stopping after about two minutes and displaying message code F22. What is wrong?
its an open temperature thermistor located in the exhaust vent housing,usually between the blower and the rear exhaust opening that leads to the outside,the thermal fuse is also next to it on the tube
Jul 29, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Trying to locate thermistor whirpool dryer and replace it
Just bought a new thermistor for the Whirlpool Duet dryer and ready to install, does it has any polarity; ie. does it matter which wire goes to which side?
Jun 16, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
201 people viewed this question
Top Dryers Experts
