Question about Brother MFC 7840W Printer
Brother MFC-7840W Printerwill only give me Scan To FTP option now
When I first set up my Brother MFC-7840W, I was able to do Scan to FTP, Scan to e-mail, Scan to File, Scan to Image. Now I can only do scan to FTP. I'm not connected to the machine via USB (I'm not sure if I was when I first tried this). But from my laptop (15" 2.2ghz MacBook Pro running Leopard), I can choose to scan and it will scan over wirelessly.
But I would like the freedom to be able to initiate a scan from the Brother MFC-7840W
  • Anonymous Mar 11, 2009
    godamn thing is supposed to be wireless, wtf is FTP? I didint spend all this fuckin money to have thi **** not work! Its not even mine, im usn it at the office but WTF. someone pleae help!! puuhhleeaasseee
I had the same issue - was previously able to scan to a number of different formats, then switched modems, providers and then only the scan to ftp option came up.
took me about an hour to figure out the solution, but now it works
for windows users: * go to your control panel * go to the scanners & cameras section * your printer/scanner should show up here * right click on it and select 'properties' * select the network settings tab and then -- enter in the correct ip address here OR -- specify your machine by name (enter in name here)
hope this helps!
Posted on Jun 21, 2011
How to configure Brother DCP-7065DN to scan directly to Synology DS412+
I don't believe the DCP-7065DN allows scan to FTP. Brother's models MFC-7460DN and MFC-7860DW do provide this function. Good luck and please share your solution should you find one.
Dec 31, 2013 | Brother DCP-7065DN MFC / All-In-One Up to...
On the mcf 7840w, how do i scan to pdf and save the document
Follow the instructions on this Brother link:
http://tinyurl.com/5ssuacj
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 21, 2011 | Brother MFC 7840W Printer
The manual that comes with my brother MFC-7840W covers all functions ACCEPT scanning! How do I scan multiple pages into ONE file so I can send a single file to someone. Thank you, Jeff Vanskike
Information on the scanning function can be found here:
http://welcome.solutions.brother.com/bsc/public/as/au/en/faq/faq_list.html?reg=as&c=au&lang=en&prod=mfc7840w_all&Cat=107
In order to scan a multi-page document into a single file, you must configure the scan to use a file type that supports multi-page documents. For illustrated instructions of how to scan multiple pages into one file instead of each scan being saved as a separate file go to here:
http://welcome.solutions.brother.com/BSC/public/as/au/en/faq/faq/000000/002500/000078/faq002578_001.html?reg=as&c=au&lang=en&prod=mfc7840w_all&Cat=107
Feb 10, 2011 | Brother MFC 7840W Printer
I own a brother mfc 7840W and want to scan to a word file then convert it to a pdf how would I do this?
hello there
first thing, scan the document and when you typed the filename below that box is option, you can select what extension name you want to that file select pdf and click save. be sure you have pdf reader or acrobat reader etc..
Thanks
Nov 13, 2010 | Brother MFC 7840W Printer
I'm finding that the scanning on the brother MFC-7840W creates a big file (a two page document is over 2MB). Is there a way to condense the pdf files?
Hi, you can reduce the file size by decreasing the DPI (dots per inch) or resolution of the scanned image. This can typically either be done from the scanner's control panel or from the software installed on your computer. The less DPI you set it for, the smaller your file will be.
Some scanners will also allow you to compress files. If the MFC-7840W will let you, the option would be in the software program, and it should say "enable file compression" or "enable image compression" or something similar.
Sep 14, 2010 | Brother MFC 7840W Printer
When I scane a document,how to put in a PDF file.
You go to HP Solution Center ( it will be on your desktop as shortcut maybe) and choose settings, then choose Scan settings. Here you will have the option scan document settings. Click on this and inside you will find a question "where do you want to send the scanned image" and the option to choose FIle type. The file type can scroll to PDF among other options.
Jan 30, 2010 | Brother MFC 7840W Printer
I can't figure out how to scan on Brother MFC-7840W Can you help?
Do you have XP? If so open control panel and select Scanners and Cameras then select your scanner and follow instructions.
There is also a demo here for your machine.
Jan 20, 2010 | Brother MFC 7840W Printer
How do you reset a Brother MFC-7840W printer to factory default settings?
Menu * 2864 (within 2 sec.), 0,1, when 'maintenance' appears, press 0,9 to exit.
Dec 08, 2009 | Brother MFC 7840W Printer
How to scan with brother mfc 7840w
Just put the scan job in the scanner and press the scan tab in your printer the scan image will appear in your directly connected machine/pc.
Oct 24, 2009 | Brother MFC 7840W Printer
Brother MFC 7840W Printer Logo
3,721 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
