Question about Whirlpool Duet GHW9150P Front Load Washer
Loud noise when spinning out
When washer spins out (from wash cycle or rince cycle), it sounds VERY loud. I took the back off the machine, and there is a brown watery substance sprayed around the back and pooled on the floor of the washing machine. It appears to be coming from a hole in the back of the washer tub, just below the back wheel that holds the belt. Does anyone have any ideas of what could be causing this?
  • 18,424 Answers
It needs new drum bearings and seals, it's a big job here a video that will show you what needs doing
Posted on Jan 01, 2013
IFIXALL
  • 868 Answers
SOURCE: Spin Cycle Making Loud Noise
You brake is failing .Replace it.
Posted on May 23, 2008
Lumpy816
  • 246 Answers
SOURCE: loud noise at end of spin cycle
The most common cause of the symptom you are describing is a bad drive block which has probably ruined your basket drive as well. Let me give a quick explination. The weight of the basket you put your clothes in is supported entirely in the center of the washer underneath your agitator. It rests on an aluminum block called your drive block. So that the basket will move back and forth while the washer agitates, there are two tabs on the drive block that lock your basket drive underneath in place. Once the drive block wears out or round down these tabs, the basket will raise slightly and "skip" across the top when the spin cyle is stopped. To verify this, you can check one of two things. First (and easiest) is put a heavy, large load in the washer, get it wet then spin it out. Once the washer reaches the maximum spin speed, open the lid. The washer should snap to a halt when functioning properly. What I belive you'll find is that even with the lid open, the basket will continue to spin. The other method to verify this is take the top of the agitator off. Next remove the bolt in the middle of the agitator and lift the agitator off. In the middle, you should find a large flat metal colored nut.In the middle of that nut, you should see two tabs across from one another. There should be two straight pieces of metal coming up from the bottom which have nice, straight sharp corners. Again, if I am correct, you will find they have been rounded off and there may even be shavings of metal visable.
To replace a basket drive and drive block, you will need to purchase the parts and also a specialty tool from removal and instalation. These will probably run you around 125-175. If you are interested in giving it a go, reply back to me and I will get you some step-by-stpe instructions typed up.
Posted on Jun 26, 2008
  • 641 Answers
SOURCE: Washer makes loud thumping after finished spin cycle
Remove washer cabinet (easy to remove)and check that "base pads" (there are 3 pads, located under the main tub)are not worn. In case they are worn (even one of them), you should replce them all. Good luck !!
Posted on Jun 07, 2006
  • 2976 Answers
SOURCE: Washing Machine Moves in Spin Cycle
There are 2 things you can do.
All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
Posted on Feb 02, 2009
SOURCE: Washer machine model LSR8233EQO want spin
The agitator is loose I believe. Can I repair this myself? If so, how?
Posted on May 17, 2010
Washer skips spin cycle
You have an issue with the controller on your machine. Needs replacement.
Sep 17, 2017 | Maytag Legacy Series Top Load Washer
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine is really loud
It sounds as if the inner water seal has failed and allowed water to get into the bearings.. Rust on the bearings means they are no longer smooth..Hence the noise! Replacing the bearings (and possibly the shaft) is a big job. This is not an unusual problem with front lad washers. Too much detergent will shorten the life of the seal/bearings...Get quotes...Nomess
May 31, 2010 | LG WM2277H Front Load Washer
Amana washing machine makes loud noice when trying to spin
sounds like you are dealing with the same problem as me .
take off the front panel (after unplugging power) take a flash lite and look at the large pulley at the back just below the pulley is the helix check to see if they are worn .
http://fixitnow.com/wp/2008/10/21/amana-washer-makes-loud-ratcheting-noise-during-spin-but-doesnt-actually-spin/
Feb 26, 2010 | Amana NAV3330AW Top Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Kenmore Series 80: Loud clicking at spin cycle
sounds like spin tube bad will need to remove basket and gearcase to remove it
Sep 30, 2008 | Kenmore 20172 Top Load Washer
Front load washer makes whining noise on spin cycle
Check to make sure that your machine is still level using a regular carpenters level. If it is not, You may be able to level it by screwing on the legs until it is level. But carefully and not too much at once.
Aug 02, 2008 | Frigidaire ATF6000ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
2,018 people viewed this question
Dan Webster
Dan Webster
Sal De
