Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidaire gallery dishwasher fdb949gfb2
I am rtying to figure out what is wrong with my dishwasher. All the cycle light continue to flash and when I trip the breaker and try to reset it is says in the display 68 and the low rack light is on. Does anone have an idea what is wrong.
  • 2 more comments
  • 7666 Apr 22, 2008
    Frigidaire gallery dishwasher model fdb949gfb2.Washer suddenly quit about two minutes into the cycle, all lights out. Breaker not tripped. I reset the breaker allowing about 30 min inbetween. Light started blinking PF, also the indicator light over high temp and no heat was on but no other. Dishwasher making no sounds. after about 1min those lights went out. Dishwasher completely dead. Any Ideas on how to fix this. thanks Dave.
  • clydeie Oct 27, 2008
    All of the cycle lights are flashing all at the same time. I have also trip the breaker and reset it nothing works at all. What the heck is going on with it? I have called and tried to get help but, seems like no one can help or wants to help or at least tell my what's going on. Can someone please tell me why it's flashing? Thanks
  • apfell Mar 04, 2010
    when the dishwashing powder box trips the powder gets wet and doesn't unload into washer. Help!
  • Anonymous Mar 15, 2014
    Dishwasher not working at all. No sounds or lights on the display. I have already check the breakers/fuses in the house
  • 35 Answers
It looks as tho.you have a touchpad problem.the touchpad is malfuntioning.
Posted on Jun 25, 2007
My Frigidaire Gallery dishwasher has the code "PF" flashing and door latch is not working. Any suggestions.
PF code on Frigidaire dishwasher
Since the PF indicates a power failure, it has most likely lost electrical connection before the control board and this is the most likely place for this to occur. Frigidaire dishwasher (PLD4375RFC0) seems to complete wash cycle but often has power failure (PF) code during the dry cycle.
the latch must be fixed for it to work a broken latch will cause this problem Frigidaire Gallery dishwasher has the code PF Google Search
also we need to know what model it is to recommend a part
Feb 03, 2018 | Frigidaire Dishwashers
Frigidaire gallery fghd2455lf leaks from bottom of door
Thank you for your post, Jacques Lanthier!
From what you have described it sounds like you could have a loose or bad gasket on your Frigidaire dishwasher. Typically, to clean any seals you would remove them and wipe them off with a rag and warm water. If you continue to experience an issue with water leaking I would recommend replacing the gaskets. I hope this information has been helpful. -Matt
Jan 10, 2015 | Frigidaire Gallery FGHD2455LF Full Console...
Why are the lights on the far right of the panel of the Frigidaire gallery dishwasher model #GLD8958A52 ?
Hi friend, thank you for your inquiry!
I understand that the panel on your Frigidaire dishwasher has lights on the far right side of the panel. I would recommend a reset on your dishwasher and you can do that by flipping the household circuit breaker in the off position for ten minutes. The lights on the right side of the panel could be providing a warning to inform the panel that something is wrong. A reset could provide an error code for further diagnosis. I hope this information has been helpful. -Matt
Oct 16, 2014 | Frigidaire Gallery 24" Built-In Dishwasher...
Why won't it run
follow this steps and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer/electronic board.91d0c2b1-1baa-49b9-9f99-f6a86f3b29df.jpg
Sep 29, 2013 | Frigidaire Gallery FGBD2451KB Full Console...
My frigidaire gallery series dishwasher wont start and the lights are flashing. whats wrong?
I would cut the power to it for a full 5 minutes and see if it resets itself???????
Feb 10, 2011 | Frigidaire 24 in. FDB1050REC Stainless...
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
May 27, 2009 | Frigidaire 30 in. Electric Gallery Series...
FDB949GFB2 Frigidare Dishwasher
don't know this appliance but as a guide:
take top off and dryer manifold goes across the top of the machine. there are various stats mounted on the manifold. one or more may be resettable stats ie have a litle button in the middle. press the button to reset. if you have access to a multimeter, check continuity thro the stats as wee and check continuity thro the heater itself
Sep 05, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire gallery series FDB125ORES1 wash light blinking, dishwasher won't cycle on.
The lights flashed on mine for about three months before smoke started to pour out of it during the drying cycle. It nearly burned my house down.
Aug 14, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Frigidaire Gallery Dishwasher Model #FDB949GFB2
You have to change the motor. Sorry !
Please Rate This !
Jul 12, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
1,830 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
