Having trouble setting up our digitview 180s to our Philips Cineos tv. We just moved house and can't seem to reprogram our freeview box to our tv, can you help me. Or do you an instruction book I
Can you help us to reprogram our digitview 180s to our Philips TV, as shown above.
SOURCE: Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Posted on Mar 13, 2009
  • 476 Answers
SOURCE: how to get freeview
Download the manual here:
http://www.p4c.philips.com/files/3/32pf9967d_10/32pf9967d_10_dfu_eng.pdf
NOTE: You may need an aerial upgrade to receive the Freeview service.
Check availability of Freeview in your area here:
http://www.freeview.co.uk/
Posted on May 19, 2009
  • 117 Answers
SOURCE: Philips 42PF9967D plasma tv with freeview. After
yes/buy a freeview box/cheapest way
Posted on Apr 18, 2010
jdvillanueva
  • 2098 Answers
SOURCE: Hi, I own a 50 inch
Hi erron_d,
The 6 blinks ended with 3 blinks error code is a general IIC bus error detected upon self test of the processor. This is located in the main board which is the affected parts is the system IC and or some of the resistor in line with this IC going to EEPROM IC. This is responsible for powering on the unit. If not isolated the symptoms will remain the same. I would advice you to look for a qualified technician or send the unit to your local Philips Service Center because diagnosing the fault required some test instruments and skills in that kind of symptoms. Your power supply board is not an issue here.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Apr 19, 2011
  • 3 Answers
SOURCE: I have just got a 42'' philips lcd cineos model
You could have shorted out the mainboard from the power surge. If this is the case, you may only need to replace some capacitors if you are handy with a soldering iron.
If you don't have soldering experience, I would recommend replacing the whole board. Search around online for the schematics, or replacement board for sale
Posted on Oct 18, 2012
Oct 18, 2012 | Televison & Video
I can't record digital tv on the dvd recorder coupled with a new philips tv with built in digital
You need a freeview box to connect to the scart INPUT of the DVD recorder. The Freeview box has to have a programmable timer built in. Connect your aerial to the freeview box, the aerial output then goes into the TV. You program the DVD to the times you want to record each program, but always the input is the SCart. You the program the Freeview box to change to the right program at the beginning of the program you want to record.
Jun 27, 2011 | Mico DVDR311
I bought a Toshiba 32 Inch HD Ready Digital LCD TV - 32BV500B yesterday from Argos, Leyland. I tried to set it up and it searched for programmes but did not return and any programmes. It had a blue...
Are you using the freeview tuner, I only ask as it looks like your having a similar problem that I had a few months back. I moved into a new house and plugged in the tv. Using the freeview tuner I wasnt able to get any channels. It turned out although the aerial picked up regular analogue tv it wasnt the correct aerial for freeview.
Aug 17, 2010 | Toshiba Televison & Video
How to get freeview
May 18, 2009 | Philips 32PFL7332D 32 in. LCD HDTV
Connect philips dvdr80 to intigrated freeview tv
Solved the problem by connecting the freeview box back into the dvd recorder. Apparently because the dvdr was made before tvs with integrated freeview, it can only recieve decoded signals from a freeview box, ie analog
Jan 16, 2009 | Philips DVDR80 DVD Recorder
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
Freeview box and dvd is not working
Have you checked the fuse in the plug for the dvd player?
Feb 18, 2008 | Televison & Video
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
Electro Med Services...
