Question about Philips Televison & Video
Green lines all along the screen.
Lines go through all the inputs
  • Philips Master
  • 8,617 Answers
Sounds like a bad green CRT if the lines are sort of curved and are on almost the entire screen
Posted on Jan 02, 2013
SOURCE: horizontal green lines the whole length and width of the screen
Hey, I had the same problem with blue and red lines and this post helped me bigtime ! Just adjust the color your having problems with. Best Solutionposted on Sep 12, 2006By maddogmic Rank: Not rated Rating: 100%, 1 votes I had the same problem with my sony KP-57ws500 rear projection tv. To solve this problem all you need is a flat and phillips screwdriver. Right below your speakers on the right and left side are tabs. Pull out the tabs and remove the screw on eachside. Once that is done remove the speaker cover and you will see a fiber board cover in the middle of the tv, there will most likley be twist ties holding some wires, to make it easier to work remove the ties. Now remove the screws on the fiber board and pull it off. You should see 3 adjustments on the top for focus, do not touch those. Below the focus adjustments on the
Posted on Sep 27, 2006
  • 1694 Answers
SOURCE: Red and green lines across the screen
classy cuban,
Probable convergence issue....replace convergence IC's
Guest,
In front of set behind access panel,locate RGB focus and screen
adjust block.....turn red screen control ccw a bit........
m888, Your monitor has a bad CRT.........................T.
Posted on Dec 04, 2007
ctf1800
  • 4402 Answers
SOURCE: Green lines along top of Hitachi 53UWX10BA
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 09, 2008
Russmann
  • 203 Answers
SOURCE: green lines on screen
That symptom is caused by a bad dmd board. This will help: make sure you use all digits of model number when you order or lookup parts. This is located on a sticker on the side of your set. Also, you can price "rebuilt" light engine or dmd assy. and check for core value of your defective one. Good luck, Russmann.
Posted on Jun 12, 2008
  • 179 Answers
SOURCE: Mitsubishi DLP WD 52525 has small green lines on the screen
do the lines go from top to bottom, and are they about 1 inch apart? or do they move diagonally across the screen?
Posted on Dec 29, 2008
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
EEGreen lines on screen still hear and see picture
Green lines on screen means either the tube is worn out ( green lines stay in same place channel after channel) or you may have a connector problem where the signal comes into your set, try a differnt input type.
Nov 19, 2013 | Televison & Video
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Televison & Video
Do you need the red yellow white blue and green to have it show on the power its on but it wont show up on the t.v. so if you know whats rong on it holler at me
You need tyo select the input on your tv that matches how you have the dvd player hooked up if you are using hdmi select hdmi, if you are using the red yellow green blue and white cords these are called component video cables so look for something along those lines on your input selection screen
Apr 02, 2011 | Cyberhome CH-DVD 300 DVD Player
When you turn on the camera and look at the screen, it has lines on it...and when you take the pic along with the lines, it has some green color on some items in the picture. We have tried the pixel...
I have a similar problem but with red and blue lines all the time. Do your's jump around the screen when taking photos or videos? I don't have a solution yet unfortunately. I have tried reformatting my memory card or using a different card but I think it is a fault with the lcd screen in my case?
Dec 02, 2010 | Olympus Stylus 790 SW / µ[mju:]790SW...
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Dec 27, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green semi-circle of lines on Samsung 55" HDTV (projection)
I believe i have the same problem myself. When my TV is on any of the Component Inputs without my DVD player turned on i usually get the normal green screen. But now that is a dip in the green at the top of the screen from the top left to almost the top right and black pushing down on the dip. Almost like a green curtain was sagging at the top and you can see the black behind it. It does this on every input and distorts every picture you see. The distorted picture has all the green slightly off from where the rest of the picture is and where the dip at the top of the screen is there is somtimes purple instead of black.
I know the basics of how the picture gets onto the screen and its my guess that the Green "gun" for lack of a better term and somhow come loose, or been missaligned to a great extent. I would love to find an answer to this problem, and anyones best guess as to how much a repair man will charge, just so i know the ballpark.
Jan 31, 2008 | Samsung HCN653W 65" Rear Projection...
convergence ic bad
Jan 02, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Vertical red/green lines
This set has a bad digital board.and or signal board
The company is in California and is a china inport.
Digital and signal board could cost $130+
Nov 03, 2007 | Soyo Dymond DYLT032A Television
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
