Question about Husqvarna Garden
Clutch permanently on
132r
  • Husqvarna Master
  • 2,239 Answers
If the clutch is permanently engaged then the clutch spring is weak or broken
Posted on Jan 02, 2013
1990 Honda EX clutch. It does not ingage. It pops to the top or sticks to the floor
Not sure of the model EX, but it probably has a clutch hydraulic slave and master cylinder that has leaked out the hydraulic fluid. Fill the clutch master cylinder (near the brake master cylinder) with brake fluid and pump the clutch pedal several times. The clutch work again until the fluid leaks out, so the permanent fix is to replace the master and or slave cylinders and bleed the system. Other models have a clutch cable that would need replacing in this case
Oct 24, 2017 | Honda Cars & Trucks
4WD indicator is permanently displayed on the dashboard
This indicates that a problem exists in the control system of the 4WD system. This can be mechanical like a sticking clutch in the transfer case or electrical in nature. You need to have the dealer do special testing to determine what is the actual cause. If you have never changed the fluid in the transfer case do that and see if the light is mechanical in nature from dirty fluid and a sticky cone clutch
Aug 09, 2012 | 2006 Toyota RAV4
Chain on partner 370 chainsaw is permanently engaged so when I start it it is spinning. I think it may be a clutch problem?
Iether the clutch spring has broken, or become weak, or simply the sprocket bearing is dry and need greasing, either way you need to remove the clutch and sprocket, there is a special tool to remove the clutch part no. 530031112, this is a pin spanner that fits into the two cut a ways in the clutch centre so as to jar it off against compression with a 19mm spanner.
Oct 29, 2011 | Garden
I have an electric trimmer plus 132r. Some times it works and some times it doesn't. When it doesn't and I play with the cord then the trimmer plus works. What do you recommend I do to fix the problem?
If you can get it going by "playing" with the cord, that is the problem. Either get a new cord or strip the one you have and find the break, repair it and go to work! Good luck...Lee
Aug 08, 2010 | Ryobi 15" Electric Factory Reconditioned...
How to restring 132r trimmer
Get a gater head for your trimmer. It has 4 easy to replace strings, that when broke off you can make up a new set with a pair of side cutters, or just replace 1,2, or 3, I put one on my homelite and it's the best thing i've seen since sliced bread.
Mar 30, 2010 | Ryobi Garden
How do I change string on my Ryobi TrimmerPlus 132r? I am unable to get the cartage off to replace the string. I have aligned the arrows but it will not pull apart
Send me $45.99 and I will give you the information in three easy lessons. But wait! I will even throw in an easy dvd and a twitter showing. All for the easy one time payment of $45.99.
Aug 01, 2009 | Ryobi Garden
Weed eater
Hi
check the following link
The idea is the same for all trimmers
http://www.youtube.com/watch?v=WFu66Q6J62Q
good luck
Jul 19, 2009 | Ryobi 15" Electric Factory Reconditioned...
My Ryobi 132r don't work
THE MOTOR HAS PUSHED BACK INTO THE INTERNAL HOUSING. YOU CAN DISASSEMBLE THE HOUSING AND FORCE THE ELECTRIC MOTOR TO IT ORIGINAL SET UP BUT OVER TIME THE MOTOR WILL KEEP MOVING BACK. THE COOLING FAN WILL BEGIN TO GRIND ON THE HOUSING. THE PLASTIC, HOLDING THE MOTOR IN PLACE,WILL BREAK DOWN AND PUSH AWAY FROM THE ATTACHMENTS.
Sep 30, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
89 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
