Computers & Internet Logo
Posted on Jan 18, 2009
Livebox L have been using a live box (wired) for along time successfully, and have just tries to connect a laptop (wireless) but I can connect to the livebox but not the net ,???? Please can any help.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
232
Points
I just paid Orange Fr to send a techy to help get my wifi working with my Laptop. All she did was access the wifi icon on my laptop. Once there she tyoed in the code; at this point she pressed the wifi button on the Livebox and hey presto I was in business. The mnistake I was making was to press the Connect button on the Laptop. I think pressing the wifi button is like pairing using Bluetooth. Now all I have to do is get the TV working. How do you connect a SCART outlet to HDMI. My TV is so new there are no SCART ports on it.
1helpful
I cannot connect my laptop as my second computer
This could be that your not pressing the association button on the LIvebox when trying to connect, i think its button two on the back, try both of them. The Livebox will flash it's light on the top when in association mode and you will be able to connect
2answers
Livebox B100 - connecting to
If your touch wont connect either then i dont think its your laptop sopunds like the Live Box . Make sure you are presseing the Association button on the live box when you try and connect to it i think its button two, try both of them the live box will flash when in association mode then connect to it. alternitavely you could log into the live box with your desktop and perfom a factory reset and put in you settings agin to connec to the internet this may help
I have a laptop that connects to the livebox ee00 device, but when i try to connect 2 wireless items rhe second item does not connect. It sees it and has good strength and i know the security code is...
you must enter in your life box configuration and allow multiple connections
go to ip address 192.168.1.10
user name and passsword admin
then you will get options to allow multiple connections
Install lexmark x4650 with provided CD,it wont print or connect w
Make sure the software you are trying to use is Vista compliant and even more so that you are not using a 64bit version of vista because a 32bit application will have issues running in that environment.
Cannot connect orange live box c908 to my pc. help
You need to connect an ethernet cable from your PC to the livebox. You should have been supplied a grey cable with red ends. This goes into the red socket on the live box and the network port on your PC.
2helpful
Wifi authentication codes using Edimax dongle
it is secure network key so it prompt u so u enter in wire less network.
for tht access your router with folowng link
http://192.168.1.1
or
http;//192.168.0.1
ten useranme and pasword is "admin" by default or password is "blank"
ten go to wireless security then u see encryptio key check it it is promptu if u enter this key u can enter in wierels network.
X box 360 wont connect to orange livebox!!!
there could be a problem with the xbox wireless adpter which it maybe a fautly item
Trying to connect xbox live to wireless laptop with full signal. xbox asking for wep address, but will not accept letters only numbers.using orange livebox. spoke to xbox told me to talk to orange.orange...
both xbox and live box hve same recieving connections,both waiting to recieve instructions.purchased cross over cable to plug in xbox and live box. lo and behold connected. works perfect.
2answers
Belkin wireless adapter g usb
WPA is safer as all in all it's a lot harder to crack due to being a lot more characters in the passkey. The easiest thing to do would be explain how i have mine set up. And you could compare the 2.. As i have XP Desktop & Vista aswell. So your Laptop connects ok now but is still an unsecure network.. On your Dektop. When you try to connect. Are you entering the 26 character key on the bottom of the livebox?
The main thing to realise with the Livebox is everything is reversible.. And to not worry about changing something..
So let's get this started, When you open up the " Connect To A Network " you can see your Livebox-XXXX. Next to that does it say "Unsecured Connection"? If this is the case then your Livebox is still not properly configured.. What i would recommend doing is starting a fresh with the Livebox, and i explain how to set it all up from Default. icon_smile.gif
IF you don't remember your internet login details then go to "Configuration.adsl" and click My Services then Internet. Your info will be in there. Hopefully you remember your password.. icon_smile.gif
If you don't know how to do a reset of your liveox. Press and hold the "1" button on the back of your livebox. Unplug it from the mains whilst still holding the "1" for 10 seconds. Then plug it back in. [ still holding the "1" ] The lights will flash a bit and after a minute or two it will go back to normal.
Go back to "configuration.adsl"
Username: Admin
Password: Password
If i start from the top section and work down it should make it easier to follow:
My Services>Internet>Connection Parameters Filled In..
Phone Over ADSL> Nothing needs changing
Digital TV> Nothing Needs Changing.
Liveprinter> Nothing Needs Changing.
Submit
Security> Associated Devices> Will Be Empty
Firewall> Medium
Wireless Connection> Channel Number> 11
Security Key(WPA-TKIP)> Same As What's On Bottom Of Livebox.
Enable Wireless Lan> Ticked.
Submit
Configuration> Update> v5.10.7-uk
Administrator> Change the password while you're there..
Submit
Advanced> Wireless> Pairing Time> 10 minutes should be fine.
Your Livebox name can be left as it is.
WPA Security Only
Wi-Fi Easy Pairing.. Might aswell leave it on..
Submit
Now if we set up your laptop first.
Go into Connect To A Network. Your Livebox should be there. It also SHOULD say Secured Network. If there is a Red Cross then you will need to do what i suggested yesterday on my previous post.
Go back to connect.. Enter the 26 char. passkey with caps lock on.. And you should be connected no problem.
Now for the Desktop.
when you log on.. In the taskbar in the bottom right should be something to do with wireless networks. Double click this.. If it mentions something about using the software that came with the device.. Then use the software.. If not then windowsXP will show your network. Double click it.. Enter the same 26 character code.. And you SHOULD be connected.
Let me know if that works.. Sorry for the really long post, but detail is something i do quite well... icon_smile.gif
Wireless Connection
press the FN button and F1 at the same time... that switches the wireless on. :-)
x Peach
Grand Canyon Tech
Grand Canyon Tech
