Question about Samsung Washing Machines
My Samsung WD7704 washing machine. i opened the door with the emergency release (the yellow pull lever at the bottom). Now when I shut the door it keeps making a clicking noise (which it always does w
I have turned it off at the wall. to see if it would reset I have tried to push the lever back up to reset it but it is soft and just bends
3 Suggested Answers
FitzOriginal
  • 842 Answers
SOURCE: Lamona HJA8553 Washing Machine door
You almost had it with turning it off at the mains. It's usually a matter of patince. UNPLUG from the mains (sometimes there's a sneak circuit and the interlock switch is still powered up even when switched off). Depending on the machine, you will have to leave it quite a while. I've not heard of a machine that, once unplugged will not let you in after 20 minutes.
Unplug, walk away and don't try the door for a full 20 minutes. It will open then.
TIP: If the machine is full of water, pull it away from teh wall and tip gently backwards until the water is no longer lapping against the door. Now you can open the door and bail the water out without getting a wet floor.
Posted on Jun 30, 2011
carolemackie
My Lamona integrated washing machine HJA 8553 has a nasty smell coming from it like an old damp mop its making the whole of the house smell any ideas why
Posted on Jan 10, 2013
How open the door when it is loocked
You need to unplug from power and pull the emergency release from the bottom of the machine near the filter door and also operate the lock. If there is water in there it will still open.
Sep 24, 2014 | Washing Machines
Ghw9400plo
Your unit has an access panel, at the bottom of this panel are 2-4 screws. Remove them and the panel also, unplug the unit, with your right hand and to the right of the door, use you hand to go inside the unit toward the door latch. At the bottom of the door latch is a pull down looks like a tear drop but can only be felt. This is the door release, when you pull on this gently you should hear a click. This is the emergency door release for this unit. Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 04, 2014 | Whirlpool GHW9100L Front Load Washer
My washer door will not open its a wd645 model i cant find the lever when i took lid off
Hi.
The door latch is probably broken. Emergency opening can be done accessing the door latch from the inside of the washer assembly.
Before attempting an emergency opening, disconnect power cord and empty water inside the machine through the filter located at the bottom front side of the machine.
After removing water connect back the machine and try opening again.
If that does not work, then the machine must be disassembled. Most models have an emergency cable located on the inside of the door latch. Pulling the cable will release the latch.
The inside of the door latch is reached either from filter housing or from top of the machine. Either the filter (usually held by screws) or the top panel must be removed to access the inside of the lock mechanism.
Power must be kept off while doing maintenance. Due to the safety issues involved the door latch emergency opening and repair must be done by a trained technician.
Regards.
Ginko
Dec 15, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
Door doesn't open
There is an emergency door release tab/pull ring attached to the bottom of the door lock assembly.
The lower access panel can be taken off by removing the screws and then reaching up under the door lock and pulling downwards on the pull ring. Pull down and then you can open the door.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The door lock will not release so I cannot get my washing out
Hi
these door locks usually work with solenoids (sp) if you unplug the machine( leave it unplugged). the door lock should release in no more than 10 minutes. there is also an emergency released built in somewhere, not being familiar with this modl i will guess if you remove the front panel there might be a string you can pull to release it.
Thanks for contacting fixya.com
Nov 13, 2009 | Dyson Memory CRO1 Front Load Washer
The lock for the door is stuck how can i unlock it
You need to remove the top cover, and release the door catch from inside with a screwdriver or similar.
Please rate my solution.
Thanks.
Nov 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The wash is finished but the door will not open?
You door switch is most likely faulty.
Open the drain filter door in the bottom corner of the machine. See if you can locate a lever or ring to pull down. This will manually release the door.
Regards
Ash
Oct 21, 2009 | Miele Washing Machines
Door Wont open on my Samsung J845 washing machine
yes its the door mechanism Unplug the machine for 4 hrs the try opening the door.Don't try to force it you will make matters worse
Sep 07, 2009 | Samsung WF203ANW Front Load Washer
Zanussi FL884 Washing Machine
there is no emergency release.
two ways of opening door.#
break handle off and you can lever door peg with a small screwdriver
or
disconnect from mains
take top off. feel down to the door interlock and feel for the end of the door peg. push this sideways and you can sometimes release the door
Oct 03, 2008 | Zanussi Washing Machines
Maytag 9600
yes open the dispenser drawer push down on the flat tab and pull the drawer out in there will be a yellow pull rope made of plastic will say emergency door unlock pull that
Feb 16, 2008 | Maytag Neptune MAH9700 Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
