Question about Microsoft Xbox Console
Error message My Microsoft XBOX is showing an error message number07 saying my xbox needs service sometimes i tried turn it off and on a long time and it work and sometimes it don't.
  • 32 Answers
Your hard drive in the xbox is failing the only solution is to either mod the xbox and replace the current 10gb drive with a replacement hdrive of a bigger size..or just buy a secondhand xbox as it would be a cheaper solution
Posted on Jun 25, 2007
SOURCE:
On the circle 1 part red says systemm error e74
You are experiencing a hardware failure, better know as the red ring of death. Microsoft recomends the following
Step 1: Confirm the E74 error loadTOCNode(2, 'moreinformation'); To verify that your console is displaying the E74 error message, follow these steps:
  1. Turn off the console.
  2. Turn on the console.
  3. Verify that your console displays the E74 error message.
Step 2: Submit a console repair request loadTOCNode(2, 'moreinformation'); If you are experiencing this problem, your Xbox 360 console must be repaired at our service center.
Start the repair process online. (http://service.xbox.com/)
For more information about how to contact Xbox Support directly, please visit the following website: www.xbox.com/support/contact (http://www.xbox.com/support/contact) Microsoft covers repairs for the E74 error for a period of three (3) years from the original purchase date of the console. If you are outside the initial three-year warranty period, you can still receive console repair service from Microsoft for a fee for the E74 error. For more information about the E74 warranty extension, see the following article: 969905 (http://support.microsoft.com/kb/969905/ ) About the E74 warranty extension for Xbox 360 consoles
Jul 30, 2011 | Microsoft Xbox 360 Console
My xbox cuts on abut wont connect
I'm thinking bad AV cable or bad port on your TV. I assume the Xbox dash board won't come up, if so the "no signal" message is a TV error message not an Xbox error message.
Try a different port on the TV and/or a different TV; also try a different AV cable.
Good luck. Please rate, thanks.
Mar 05, 2010 | Microsoft Xbox 360 Console
My xbox is saying error e74
CAUSE This problem occurs when the Xbox 360 console experiences a general hardware failure.uparrow.gifBack to the top
MORE INFORMATION If you are experiencing this problem, you can submit a console-repair request online by using the links in the "Additional support" section. To confirm your console is displaying the E74 error message, follow these steps: 1. Turn off the console. 2. Turn on the console. 3. Verify that your console displays the E74 error message.uparrow.gifBack to the top
Additional supportIf your console continues to display the E74 error message, it requires a repair. For more information about how to start the online repair process, please visit the appropriate Web site: United States Customers
http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair
Outside the United States http://www.xbox.com/support/ Note Online console repair service is currently not available in all countries and regions.For more information about how to contact Xbox Customer Support directly, please visit the following Microsoft Web site: http://www.xbox.com/support/contact
Feb 10, 2010 | Microsoft Xbox Console
One red light
The lower-right quadrant of the Ring of Light flashes red on the front of your Xbox 360 console. You also receive the following error message in multiple languages on your television screen or monitor:
System Error. Contact Xbox Customer Support. This message begins with an error code in the format "Exx," where xx is a two-digit number.
The following indicator will flash on and off repeated on the front panel of your Xbox 360 console:
If one red light is flashing and you receive a different error message or error code than those that were described previously or you don’t receive an error message or code, your console may be experiencing a different issue. In this case, see "References/links."
This problem occurs when your Xbox 360 console experiences a hardware failure.
  1. Turn off your console, disconnect and reconnect all cables, and then turn on your console.
  2. If an Xbox Hard Drive is attached to your console, turn off your console, and then remove the Xbox Hard Drive. Turn on your console, and test for the error. If the error does not reoccur, turn off your console and reattach the Xbox Hard Drive. Run alternate additional tests by having the Xbox Hard Drive connected and disconnected to see whether the error occurs only when the Xbox Hard Drive is connected. For more information if the on-screen alphanumeric error is E67, click the following article number to view the article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/ ) One of the lights on the Ring of Light on the front of your Xbox 360 console flashes red and you receive one of the following error codes and message: "E67, or E68, or E69. System Error. Contact Xbox Customer Support"
  3. If an Xbox Memory Unit (MU) is plugged in to your console, turn off your console, and then remove the Memory Unit. Turn on your console again, and test for the error. If the error does not reoccur, turn off your console and reinsert the MU. Run alternate tests by having the MU connected and disconnected to see whether the error occurs only when the MU is connected.
  4. If this problem continues to occur, contact Xbox Customer Service. Note If the agent cannot help you resolve this problem, you must return your console to Microsoft for repair.
Additional support loadTOCNode(2, 'moreinformation'); If the steps in the previous section did not resolve your issue, your console may have to be repaired. For more information about how to start the online repair process, please visit one of the following Web sites:
U.S. customers - Online console repair
http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair (http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx? redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx? step=repair)
Outside the United States - Online console repair
http://www.xbox.com/support/ (http://www.xbox.com/support/) Note Online console repair service is currently not available in all countries and regions. For more information about how to contact Xbox Customer Support directly, please visit the following Microsoft Web site:
Oct 08, 2009 | Microsoft Xbox 360 Console
Xbox
Some times a DVD cleaning disk will work. If that don't work try a can of the keyboard cleaner to blow out the dust and debris. Thank You for using FixYa.Com........... : )
Jun 18, 2009 | Microsoft Xbox Console
None of my games are working, they all say unreadable disc. I bought a new game to see if it was the xbox and it said unreadable disc as well what do i do?
# Turn console off and then on. # Clean the disc and examine it for flaws or scratches. # If this behavior occurs with one or two discs, search the Microsoft Knowledge Base for the specific game title(s). If you find a known problem, follow the information outlined in the article. # Delete the appropriate saved games. See Note 1. Copy a saved game to a Memory Unit (MU) if you have one available. # Try three other games, and then try the original game again. # Try the game on another console if possible. # Replace the disc at retailer. # Repair the console Note 1 If a saved game file is corrupted, it can produce a disk error message in that game, particularly when the game starts. You can resolve this issue by deleting all saved game files for the affected game from the Xbox hard disk. This method is effective approximately twenty-five percent of the time. If you experience this disk error message with more than two games, this procedure will likely not resolve the issue. Another trick to try is to turn your console so its vertical( sometimes works)
Jun 04, 2009 | Microsoft Xbox 360 Console
My xbox 360 shows a message"incorrect regional code"
thats because your console is set to where you live,even if its flashed you need region free or your country!!!
May 27, 2009 | Microsoft Xbox 360 Pro System Console
Switch computer on and the light is red but on the screen it says system error contact xbox customer support
SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following error message in multiple languages: System Error. Contact Xbox Customer Support. CAUSE loadTOCNode(1, 'cause'); Typically, this error message is caused by a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Note If you receive an error message and see one flashing red light on the front of the console, see the following article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/) Xbox 360: One red light flashes on the Ring of Light and you receive an error message 1. Turn off the console, disconnect and then reconnect all cables. Turn the console on again. 2. If an Xbox Hard Disk Drive is attached to the console, turn off the console, and then remove the Hard Disk.
For more information about how to remove the Hard Drive, click the following article number to view the article in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive Turn on the console, and then test for the error message. If you do not receive the error message, turn off the console, and then reattach the Hard Disk. Alternate testing with the hard drive connected and removed to see whether the error message occurs only when the hard drive is attached. If the on-screen alpha-numeric error is E67 in the error message, see the following article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/) Xbox 360: One red light flashes on the Ring of Light, and you receive error E67, E68, or E69 3. If an Xbox Memory Unit (MU) is plugged in to the console, turn off the console, and then remove the Memory Unit. Turn on the console again and test for the error message. If the error message does not reoccur, turn off the console, and then reinsert the MU. Alternate testing with the MU inserted and removed to see if the error message occurs only when the MU is inserted. 4. If you continue to experience this behavior, contact Xbox Customer Service.
Jul 17, 2008 | Video Game Consoles & Games
Xbox 360 malfunction
call 1-800-4myxbox see what they say, you might be under a warranty that will cover it.
Mar 28, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox Console Logo
24 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
