Question about Nintendo Wii Console
We are connecting wii but in the moment as soon as apprear on the tv that press A, does not happen anything?
Its the blue console
Well it takes a while to connect besides it should ask you if you want to use that internet thing that setsup internet hope this helps you out.
Posted on Jan 02, 2013
frankgant
  • 250 Answers
SOURCE: HELP PLEASE!!!!!!!
I've had this same problem. Remove the batteries from the remotes. Then disconnct the power cord from the back of the Wii and disconnect the power cord from the wall. Let it sit for 5 min. Double check that the sensor bar is plugged into the Wii and check the cord for any breaks that might stop the signal. After you are sure that the sensor bar is connected and the 5 min. have gone by plug it all back in, install your batteries and re-sync it.
Posted on Mar 29, 2008
john_n4
  • 73 Answers
SOURCE: wii remotes lost connection with console
You need to open the small compartment on the front (located between reset and eject) were your can insert a sd card. Above the slot will be a red button labled sync. Press(maybee hold) the button and press the 1 and 2 buttons on the remote. This should get your remote working with your wii.
----John
Posted on Nov 26, 2008
  • 87 Answers
SOURCE: my wii console will not turn on.
it could be the power suppy mine went wrong after about 18 months, try ebay there the cheapest. you can test if its the power supply if you know someone with a wii and use there power supply or know how to use a multi meter and check if you have a voltage coming out of the wii plug end. if you dont first try replacing the fuse in the wall plug. hope this helps.
Posted on Nov 11, 2009
  • 133 Answers
SOURCE: how to connect a wii to my tv
Please take your AV Cord and hook it up to your wii and your tv. There are 3 colors. Red/White/Yellow
Once hooked up, take your remote and switch the Video Input on your tv. (look for the input button)
Make sure the Wii is powered on and you should see it pop up on the screen.
Posted on Dec 31, 2009
  • 90 Answers
SOURCE: My Wii comes on but TV screen stays blue, worked
Plug in cords. Replug in
Posted on May 11, 2010
The tv screen stays blue ?
You mentioned you do not have a connection issue, however, I want to verify what type of cable connections you have.
Wii Fix Guide
Jun 30, 2012 | Nintendo Wii Console
The Wii console light will turn green
Hi sharonkayh,
Try the following:
1) Completely power down your system by pressing the power button for 10 seconds. If that doesn't work, unplug the AC Adapter from the Wii for a moment, then plug it back in.
2) Make sure your Wii console has the most current Wii system menu. Download the latest update, and then test your Wii console to determine if the problem has been resolved.
This is done by:
  1. Make sure your Wii console is successfully connected online.
  2. Access the Wii System Settings.
  3. Click on the blue arrow twice to reach the Wii System Settings 3 menu options.
  4. Select "Wii System Update" and press the A Button.
  5. Select "Yes," and read any messaging regarding obtaining the update. If you agree to the messaging, select "I Accept."
  6. The Wii console will now search for the latest Wii System Update.
  7. If an update is available, it will be downloaded and installed automatically.
I hope this can help you - Source: Nintendo Website.
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 05, 2011 | Nintendo Wii Console
My wii fit board won't connect with tv is the blue light suppose to stay on all the time or flash
Hi, thanks for using Fixya!
  • Open the SD card slot on the nintendo wii, open the battery panel on the wii balance board.
  • Press the two red sync buttons on the wii console and the balance board and hold for 3 seconds.
  • The blue light on the back of the wii balance board should flash for 5-10 seconds and then stay blue.
  • If this doesn't work then try changing the batteries and trying again.
If it still isn't connecting then the problem is something a proper nintendo expert will have to help fix.
Thanks, I hope I have been of assistance.
Jan 28, 2010 | Nintendo Wii Fit - Balance Board + Game...
Wii is suddenly only playing in black & white. I've unplugged and replugged at wii and at TV, but not worked - any ideas?
From the Wii, the Audio-Video (AV) cable is Red White and Yellow. Now, those R, W, Y should connect to the R, W, Y inputs of your TV. At times, the inputs to the TV have a Red, Blue, Green input - DO NOT USE those inputs. This is precisely what happened in my case. Now, it is fixed.
Dec 02, 2009 | Nintendo Wii Console
What does blue flashing on the nunchuck
this is what happens when the device attempts too connect to the console. the solution is very simple as well. simply remove the battery cover on the the wii-mote. now open the memory card door of the front of your wii. note the red button on both the wii and the wii mote. now simply press and hold both and then the wii mote should automatically pair to the console. repeat whenever needed. Hope i was a help to you today.
Mar 17, 2009 | Nintendo Controller add-on Nunchuck for...
Wii
check wii console is connected then insert wii fit cd and see what happens put new batterys in remotes and make sure wii works before installing wii fit
May 26, 2008 | Nintendo Wii Console
Wii sensor bar
possibly, or low batteries in the remote. Try placing the bar under the tv if its above at the moment, or vice versa if currently below. Also make sure sensor bar overhangs tv slightly too...
Mar 08, 2008 | Nintendo Wii Console
Remote not working
press the red button under the front door then press the button under the battery compartment of the remote.
good luck
please mark the post with a fixya
Feb 12, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
24 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
