Question about Samsung Televison & Video
Samsung HL-S4676S- changed bulb (as I have before) but new bulb won't come on and still getting flshing LEDs
I replaced the cover, but also tried with the cover off while manually holding down the cover switch. Still nothing.
  • Samsung Master
  • 8,617 Answers
Check the lamp door switch for continuity bewteen the two wire when the switch is in the closed position if thers continuity then the switch is good. If there is no continuity between the two wires with the switch closed then the switch is bad
Posted on Jan 02, 2013
ctf1800
  • 4402 Answers
SOURCE: Yellow blinking status light
I would make sure you have it seated correctly into the ballest some times the connector will come undun
Posted on Jan 18, 2008
SOURCE: Samsung HL-R5067W no picture or sound.
I have an HL-R5067W  no picture, no sound.. What is the solution
Posted on Mar 13, 2009
  • 3 Answers
SOURCE: my samsung hl-p5067w does not work
I would see if it's the lamp ballast only about $100.00 and easy to replace, it's the part underneath the lamp that fires up the bulb. The light engine itself is over $900 to buy and not worth it! I have same T.V.
Posted on Apr 15, 2009
Slinteriors
  • 8617 Answers
SOURCE: Obtain repair manual for Samsung DLP projection TV's.
You can get the service manual by download link within minutes from the following link. Just scroll down the page and you will see your model listed.
http://www.tvrepairworld.com/service_manuals
Posted on Dec 24, 2009
Testimonial: "Your solution was very timely and helpful. Thanks"
SAMUEL011
  • 39 Answers
SOURCE: my samsung hl-p5085w is humming all the time and
Samsung is known for bad color wheels and for what you describe it surely sounds like the color wheel bearing if going out on you,you will need to replace the color wheel you can find more help @ fixyourdlp.com and if you want to buy the part you can find it @ http://www.discount-merchant.com/SearchResults.asp?Search=color%20wheel?click=52978 or @ http://www.samsungparts.com/search/search.asp , just so you can be 100% sure you will need to get the part number from the actual color wheel that you already have,
Please rate this if it was helpful,as a do this for free
Regars
Posted on Jan 07, 2010
I changed the new drum for my HL-2040 printer. But the LED light shown orange. Can I know how I going to do reset for the new drum. Thanks!
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000300/000055/faq000355_007.html?reg=eu&c=eu_ot&lang=en&prod=hl2040_all
May 05, 2011 | Brother HL-2040 Laser Printer
Getting a loud popping noise thur speakers till it warms up , samsung dlp hl-s4676s
Check the highvoltage board for a loose solder joint. Sound like a loose solder joint.
Jan 27, 2011 | Samsung HLS4676S Television
Trying to connect PS3 to Samsung HL-S4676S tv using HDMI cable. I get message saying mode not supported
So I had this same problem. I found that when I hooked to a 1080p TV my PS3 was working, however when I hooked to my 1080i it said Not Supported Mode. So I then hooked to the 1080p and told my PS3 to limit it's self to 1080i mode and hooked it to my Samsung TV and it worked just fine. Give that a try and it should solve the problem. Hope this helps.
Oct 09, 2010 | Samsung HLS4676S Television
HL 2170W can't detect new drum
Oen the front cover of the printer.
Press and hold down Go button until all 3 LEDs are lit. Once all 3 LEDs are lit, release the Go button.
Close the front cover. This resets the drum life counter and should be done each time the drum is changed.
Nov 10, 2009 | Brother HL-2170W Laser Printer
My samsung hl-s4676s slim dlp wont turn on. the green light lights up and the normal sounds of start up come on. just a high pitch wine comes in after a few seconds and the screen dont light up at all....
Most likely, there is a capacitor swollen on the lamp starting ballast. If this is the case you will need to replace both the ballast and the power supply.
Aug 09, 2009 | Samsung Televison & Video
Dlp tv
you may have defective dlp light engine contact samsung for more info
Sep 09, 2008 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
21 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
