Question about Kenmore Elite HE4 Electric Dryer
Control panel on front of kenmore elite he4 unresponsive. 2 lights faintly glowing, "control locked" and "check lint screen". Have removed exhaust hose and cleaned it. Lint screen is clean.
Two lights remain on even after the lint screen and exhaust hose were cleaned. Have not yet dismantled the lower front of the dryer to see what is below. Will try that also. How will I know if the electric panel has a problem? Will cleaning out the bottom of the dryer resolve my problem?
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
Daniel S
  • 4323 Answers
SOURCE: I HAVE A KENMORE ELITE
Hi
When dryer won't heat or won't turn on or will behave as its behaving with you it means that the Thermal fuse which is located inside duct on the back has gone bad and should be replaced as it cannot be reset. If their is continuity when you check the fuse then it means that the control board is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 14, 2010
Our Kenmore Elite HE4 gas dryer will not start although all controls on front are lite and appear to be functioning properly (settings can be changed, etc). I has been working fine for several hours until...
check the door switch and door latch. Open door, set the dryer to air fluff cycle, and manually depress the door switch. Press start button. If it started - door needs alignment to fix it.
If it did not start:
If your dryer has light inside - check if light turns off when you press the switch. If not - switch needs replacement.
If all that checks out ok - the problem is more serious, and you might need a tech to come out and diagnose it.
Mar 04, 2010 | Kenmore Elite HE4 Electric Dryer
My dryer check lint screen light continues to blink and the dryer wont work even after cleaning lint screen
Airflow through the dryer vent is restricted. Blow through the filter opening with a reversed vaccum cleaned. Set it BLOW instead of **** usually by putting the hose on the exhaust end.
Dec 14, 2009 | Kenmore Elite HE4 Electric Dryer
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Display shows E1 and shuts off
thermister shorted code just replace the thermister and you will be back drying again// thermister is located in the front behind toe panel and then remove lint screen housing
Sep 25, 2009 | Kenmore Elite HE4 Electric Dryer
Control Panel Kenmor Elite HE4
that sounds weird to have all those lights on...
first thing is to try and remove the "lock"light...
push and hold the button, for 5 seconds, below the "lock" light,
that should get the control back to normal operation. then if you still cant get the unit to turn on, try to unplug the dryer for a few minutes.
if you still cant get it to turn back on, call sears "customer service" and complain since your machine should not have failed at this early in its life.
Sep 15, 2009 | Kenmore Elite HE4 Electric Dryer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer not heating
what is the model #the heater is not in the back of the he4.
Oct 21, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer help?
Sounds like motor is stalled. Remove the lint filter, look inside down toward the bottom left corner at the blower wheel. Something may be jammed in the blower wheel. If difficult to see, TURN OFF POWER TO MACHINE, remove bottom access panel. 2 to 3 screws on bottom of panel. Remove lint housing (3 to 4 screws) and inspect blower wheel for debris.
May 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
