Question about Hampton Bay 52 In. Indoor/Outdoor Tahiti Breeze Ceiling Fan
Need 42" and 52" same style ceiling fans
I need to replace 42" and 52" same style ceiling fans for living room and kitchen for open floor plan - like the tahiti breeze or similar style
    New Friend:
I have two model #344476 Hampton Bay Tahiti Breeze indoor/outdoor ceiling fans still in sealed boxes that were meant for our enclosed porch. Never got around to installing them as porch was turned into storage area instead, Email me at bensparent@bellsouth.net if interested.
Posted on Jan 29, 2013
SOURCE: Mounting a Hampton Fan Model 52-CL
hello d,
1. yes, with the proper rod, longer wires(3,4) and the blades must be over 2.5 metres (8 foot) above the floor.2. you need the proper type box; the mount/s and ball; the longer wires (3,4)with slender but connertors; and especially the safety pins, etc. with the proper rod, the fan will hang straight. and about 3 chock hours to do this here task. hope this helps.
Posted on Jan 16, 2009
  • 323 Answers
SOURCE: we have a light kit on the hampton bay tahiti
Home Depot should stock them. If not, you should be able to order it online from them. Hampton Bay make fans exclusively for Home Depot.
Posted on May 26, 2009
gary1121
  • 332 Answers
SOURCE: looking for a replacement globr for a Harbor
you can write to the company and they will more then likely have a replacement one for you
Posted on Aug 01, 2009
  • 10865 Answers
SOURCE: Need new glass shade for hampton bay tahiti breeze
Hampton Bay is a Home Depot product. Many Home Depots carry these replacement shades in stock. If your Home Depot doesn't have this shade in stock they can order one for you. Regards, Joe
PS Please rate my answer. Thank you.
Posted on Jan 06, 2010
  • 207 Answers
SOURCE: how to install a ceiling fan
very simple make sure power is off take old one down and hang new one hook up wires black to black white to white and ull have probably a blue wire from light hook it up to the black wire also then screw fan to the electrical box and lastly put on blades and sometimes u have to balance it with lil weights this is a pain and tedeous but usually dont have to do this turn ur power on and check
Posted on Feb 24, 2010
I bought and installed my new Westingouse turbo swirl in my kitchen. The blades are knocking my cupboard doors when I open the doors. Is there a way to shorten my fan so that it stands nearer to the c
Ceiling fans often come with two lengths of tubing to mount on different height ceilings. If you have it mounted with the long tube you may be able to remove that and install a shorter one. Alternatively you may be able to shorten the tube. If you are hitting the cupboards you are not centered in the room and it really should be, to be most effective.
Sep 14, 2014 | Westinghouse Ceiling Fan. Turbo Swirl 30...
Why does a fluorescent light turn the ceiling fan on
Hi tom,
It sounds like someone has wired the electric fan into the switching live of the lighting circuit.
You need to disconnect the fan and wire in correctly.
I would start at the kitchen light fitting as thats where the power to run the fan seems to have been taken from.It may only be 1wire incorrect but you need to be confident with 2way switching and household wiring.
If your not dont attempt to fix,call an electrician
hope this helps
Stewart
Apr 10, 2012 | Hunter Dryers
Clockwise, counterclockwise which is the summer setting?
Ceiling Fan Direction These recommendations depend actually on the height and size of the room; the season; and the activity taking place in the room.
The basic fact of nature is that warm air rises to the top and cold air settles on the bottom. Air settles in layers from warm at the top to cold at the bottom, if left alone at equilibrium.
Ceiling fan recommendations:
In the winter
Set the fan to run counterclockwise (reverse; this looks clockwise as you are looking up). This will redirect the warm air from the ceiling and down the walls and into the living space where the people actually are. In a house, you would run the fan at a low speed so that you don't actually cool the warm air that you are moving downward. If you have a high ceiling, or are trying to heat a hall or a church, you may want to increase the fan speed so that the warm air will reach the living space as long as the fan speed does not create an unwanted downdraft at the people below. In the summer
In a room of normal height (8 - 10 ft), you should operate your fan so that it turns clockwise (this looks counterclockwise as you are looking up), causing a more directed downdraft, especially with the fan running slightly faster. This causes a wind-chill effect because the skin evaporates slight amounts of water from the sweat glands and thereby provides cooling through the skin's surface. However, the air is only moved but not cooled! You may find that you can turn your thermostat down a degree or two and save more money on energy costs. The air blowing down won't actually cool the room though, so you should turn the fan off when there are no people (or animals) in the room. In a high hall or church
It may be best NOT to run the fans at all in summer. This lowers the demand for cooling since the hot layer on top is an excellent insulation between the cool air near the floor (and the people) and the hot roof and outside.
A large, tall manufacturing hall would typically have different goals. There one would have a floor full of heat producing machinery plus the people operating it, working hard and welcoming a bit of a breeze. Then it would make sense to run the fans at fairly high speed to create a certain and directed downdraft. And with the shifts going throughout the days of the week, the fans should be running all the time and maybe in all seasons.
Finally, fans typically use 80-100 watts. When used properly, ceiling fans can really help to optimize the comfort level of the people and save energy and money.
Good Luck and please rate 4 thumbs up for the free answer
Jun 13, 2010 | Hampton Bay 13087 70450 Carousel II...
4 ceiling fans functioning intermittantly
Either that or there is some kind of RFI (Radio Frequency Interference) coming from somewhere in the house or maybe from outside.
Have you installed new cordless phones, two way radios, remote controlled devices, wireless internet access, wireless intercoms, garage openers or something that emits some kind of radio signal?
Have your next door neighbor? (If he lives close enough) Good luck!
Oct 25, 2009 | Dryers
Need website to register hampton bay ceiling fan? Please help.
You can change the entire appearance of your fan by simply changing the ceiling fan shades. If your ceiling fan is outdated, you can change its look with new shades and even new blades, no need to take it down.
Replacing the ceiling fan shades is an affordable and practical alternative to purchasing a new ceiling fan. The amount of work in removing the old fan and installing the new one is enough to have you considering replacements of shades and blades as the best answer.
The Many Styles of Ceiling Fan Shades
Ceiling fan shades come in a variety of shape and size. With the huge selection, you are sure to find one that is right for you and your décor. In addition to the different sizes and styles, the materials can come in various styles, such as:
• Smoked Glass
• Etched Glass
• Beveled Cut
• Smooth Surfaced
• Ridged or Bumped Glass
There are an endless combination to the ceiling fan shades styles and materials.
Apr 10, 2009 | Garden
Wiring a ceiling fan with a remote sensor
since you have a remote, you don't need that extra wiring for the light/fan. just wire nut it off.
the switch at wall has 2 switches but only one will work now.
Mar 31, 2008 | Dryers
Two fans, remotes work with one, not the other
YOU MUST TRY CHANGEING THE CHANNEL ON THE REMOT AND TRY IT THEN IF IT DOES NOT WORK YOU MUST TAKE DOWN THE FAN AND CHECK WHAT CHANNEL THE RECIEVER HAS AND MATCH IT TO THE REMOTE.
Nov 04, 2007 | Hunter Vaulted Ceiling Mount - Antique...
Hampton Bay 52 In. Indoor/Outdoor Tahiti Breeze Ceiling Fan Logo
125 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
