Question about HP Computers & Internet
I have a lot error files i need to fix - HP Computers & Internet
    New Friend:
  • 3 Answers
Where u have the errors on u r pc are laptops
Posted on Jan 02, 2013
Hw to remove run DLL error in microsoft window 8.1
run.dll is a DATA LINK LIBRARY FILE if it is sikped in installing windows {or} other any software ,malware,adware virus problem you can fix it by using DLL suite { the dll suite download and install it will have a lot of serials keys in serial.ws.com } you will enjoy the features of windows
Apr 06, 2015 | Microsoft Computers & Internet
I'm getting an error message of 0xb900009f
Lots of issues can be responsible for your error message:-
Access deniedThis error occurs if the user has insufficient privileges to a file, or if it has been locked by some program or user.The device is not readyThis error most often occurs when there is no floppy disk (or a bad disk) in the disk drive and the system tries to perform tasks involving this disk.File not foundThe file concerned may have been damaged, moved, deleted, or a bug may have caused the error. Alternatively, the file simply might not exist, or the user has mistyped its name.Low Disk SpaceThis error occurs when the hard drive is (nearly) full. To fix this, the user should close some programs (to free swap file usage) and delete some files (normally temporary files, or other files after they have been backed up), or get a bigger hard drive.Out of memoryThis error occurs when the system has run out of memory or tries to load a file too large to store in RAM. The fix is to close some programs, or install more memory.[program name] has encountered a problem and needs to close.
Aug 05, 2012 | HP PSC 2355 All-In-One InkJet Printer
I am having problems with DLL Errors and some of my applications are not functioning correctly. Can you please help me solve this?
there are lots of error messages which can affect your pc. i don't also have this knowledge when it comes to pc errors but i am resourceful enough to have found some useful websites which helped me a lot, i once had encounter System32 DLL error and was able to fix it my self.
Apr 10, 2011 | Computers & Internet
How to check and correct corrupted files?
Corrupt files are usually caused by incorrect shutdowns ie it locks up or the program was damaged or corupted during install or downloading.
This is fairly easy to fix. You need to run the program and when you get the error look at the file name. If you then google that name you can confirm what program it belongs to. When you know that you just need to reinstal that program to correct the error. If it is particullary stubborn you may need to ininstall it first then reboot and then install a new copy. Thats the fastest and simplest way to check the files and fix the problems. you can also do it the hard way by checking the logs of dr watson of other system monitor software to find where it had the problem. then you would need to find the exact corrupted file and fine a suitable replacement. This isn;t as easy as the last file shown is usually the last good file not the bad one so you need to check registry and other things to figure out what is wrong.
Reinstalling the entire program is just easier and a lot less of a headache.
Feb 16, 2011 | Computers & Internet
Slow hard to start
I will just give you some reasons why computer starts slowly and I hope these will helps.
1.Theres a lot of program in your computer are set in Startup:
- Try to download "CCleaner", you can download this for free at filehippo.com
- As you install this, go to the tab "tools", you can find the Startup here. Delete all the programs here which you might not need during start up.
2. Theres a lot of junk files and registry errors in your system.
- Using CCleaner, clean the junk files and fix all registry errors,,do not back up during registry fix.
3. You have a lot of icons or shortcut in your Desktop.
- More icons or shortcut slowdown the startup of your pc because it times for the system to read this, other graphics and display at your desktop may also slows down the startup.
Hopes this will help...Comment if you like my post..Thanks..!
Aug 26, 2010 | Computers & Internet
Error 2123 appears when loading rosetta stone
I started getting "Error 2123" recently, and spent A LOT of time searching for the fix. Here is what finally worked:
Find the hidden file "tracking.db3". It's in the hidden folder "ProgramData/Rosetta Stone" under the "C:" directory. Copy and paste it to the Rosetta Stone install directory (Program Files/Rosetta Stone).
Error 2123 should be gone, but now there will be Error 2125. So, in the Rosetta Stone install directory, run the "service_installer" .exe file by double-clicking it.
Feb 20, 2010 | Rosetta Stone Japanese Level 1 & 2 for...
After uploading the application software for Rosetta Stone, I try and start the application and I receive: there was an error in the application. error 2123. How do I fix this problem for my iBook G4...
Feb 02, 2010 | Rosetta Stone Spanish Spain Level I & II...
Download icuin36.dll. The computer tell me that It can't find this file and I should to get it. Could you please tell me where can I get it? And very often my computer close down some programs because...
David
Try this first Click on the Start Button
Go to Run and click on it
In the Run box type the following:
regsvr32 icuin36.dll
If it is successful it will tell you and the problem should be fixed
If not try this download
http://kromann.info/icu/icuin36.dll
DLL (Dynamic Linked Library) Files:
To download and install a DLL file, you will first need to download the DLL file and register it on your computer.
Steps:
  1. Download the DLL file using the download link on this page and save the file to one of the folders as seen in step 3. .EXE files do not need to be manually registered.
  2. Backup the old version of the DLL file.
  3. Click Start > Run and type in the following command:
Windows 95, 98, or Me:
regsvr32 \windows\system\icuin36.dll
Windows NT or 2000:
regsvr32 \WINNT\system32\icuin36.dll
Windows XP or Vista or Windows 7:
regsvr32 \windows\system32\
icuin36.dll
Oct 14, 2009 | Computers & Internet
Lots of file errors, O also now can't copy files off, says i/o device error
try using a memory card with 2GB or below
the camera might be having some problems reading the 4GB that you have
if you connect the camera to your computer and file error still appears that means that the memory card is corrupted and you really need to format it
before you do make sure that you have a copy of the files saved in the memory card
*formatting the memory card will delete all the files saved in it
go to MENU> SET UP > FORMAT
May 30, 2009 | Samsung S860 Digital Camera
Dll file have error
Hi alexistech, the wininet.dll & newdev.dll are windows fies. You can try this link to fix your *.dll files.
http://www.dll-files.com/dllindex/dll-files.shtml?normaliz
Luck!
If this helps, please let me know.
Need more help just post your questions here.
Mike
Apr 17, 2008 | MSI AMD ATHLON-64 939 PIN MOTHER BOARD...
Computers & Internet Logo
16 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
