Question about Tappan Ovens
My oven isnt working but stove burners are.....electric
Oven not working
Posted on Jan 07, 2014
fridgetech
  • 473 Answers
SOURCE: KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 11, 2007
  • 10 Answers
SOURCE: burners on gas stove work but oven and broiler not working
Most ovens, unless they have an electric igniter (does it go tick tick tick when plugged in and turned on? If so, it has an electic ignition.) have a pilot light. In order to keep gas from flowing out, and to prevent a possible explosion when the pilot light has gotten put out, they have an electric thermocouple on them that shuts off the gas when it gets cold. Plug the cord back in, and relight your pilot light by holding the lighter (I recommend a fireplace match or bbq lighter, not a cigarette lighter to prevent singed knuckle hairs!) over the thermocouple for a couple of minutes.
Posted on Nov 19, 2007
SOURCE: MY HOTPOINT SELF CLEANING STOVE
how do I get my self cleaning to come on in my hotpoint stove
Posted on Oct 13, 2008
  • 22 Answers
Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
Posted on Apr 25, 2009
  • 172 Answers
SOURCE: i have an amana electric stove (manual 35-315017-05-0)
The f3 error code is a communication error between the control and the temperature sensor. The temp sensor is a small pencil shaped thing in the top of the oven. You will see in when you look inside and at the top back part. You will have to get to the back of the oven to replace the sensor should that need to be done. First thing to do is to turn off the power or unplug the unit. Pull it out and take the back off. Locate the temp probe inside the oven. Then from the back remove the sensor and unplug it. It is an easy fix and most people can do it themselves. If you need a sensor sent to you. I do have them in stock and ready to ship. They are $65.00 including shipping. Thanks and good luck..
Michael Anderson
Anderson Appliance
(865)945-3808
Also on Ebay AndersonAppliance2009
Posted on Feb 10, 2010
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Oven quit working . Stove top burners work just
if its an electric start. then the problem is usually the ignitor for oven. if you change this yourself, be carefull they are very fragil. hold on to igniter by its base. slide ignitor into steel case then install. and hook up the 2 wires for ignitor.
May 14, 2010 | Ovens
I have a kenmore electric stove. The top burner
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
May 12, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My oven wont heat up at all. gets no gas. the top
your glow coil is wron out , need to replace it, you may see it glowing in there but it isnt getting hot enough, usually you can switch out the broil one for a quick fix to get you outta truoble. easy do it yourself problem
Feb 05, 2010 | Frigidaire FEB27S5A Electric Single Oven
Stove works fine, only the oven will not turn on.
If it's electric, it is possible that you are only getting 110 volts to the range. It runs on a 220v line, so if one leg of the circuit kicks off, you could still operate the top burners. If this isnt the problem, you may have burned out your bake element. Try your broil element.
Nov 18, 2009 | Whirlpool Ovens
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Stove (coils)
if the timer is on hit cancel or reset then hit clock and then use up and down arrows to set them also locate the serial plate and give me the mod num will be a buch of num like 106.48062890 around the bottom drawer on the body of the range or around the oven door if the eoc or clock isnt lit go turn the breaker off for 5sec and let me know
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
46 people viewed this question
Top Tappan Ovens Experts
Dan Webster
Dan Webster
ashburton
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Tappan Oven Expert? Answer questions, earn points and help others
