Question about Compaq Armada 1700 Notebook
Can't get the set-up screen to come up with F10 or anything else!
I have two of these 1700's and they both have this problem. They are both set up with Xp and have been working very well. I have never had the original software, since I bought both as USED, with the original books and with the hard drives, wiped clean. What could it be?
Thank you for your help.
  • 3 Answers
There are many solutions for your problem. The one I know is to download the soft pack from the section "Software - System Management " that let you create a bootable floppy setup.
It is common for Armadas get the hidden partition with diagnostics and setup erased in formatting tasks.
Well then, download the "Computer Setup for portables" in that section. Before that you need to know the code of your laptop, that comes underneath it.
For example:
Compaq Armada 1700 Notebook PC 6233/S/3200/D/M/1
then
Microsoft Windows 98
then
Computer Setup for Portables
download sp and extract files, and use Make Disk.
If you use XP, try download version Win98 / Win2k.
Good luck.
Lucas from Argentina
Posted on Jun 27, 2009
  • ClamaKlem
    ClamaKlem Jun 29, 2009
    Well, you need to create the disks:
    Disk 1 - Diagnostics
    Disk 2 - Setup
    One option in Disk 1 will format and create the hidden partition that will contain the diagnostics tools. In POST (power on self test) later you will have the option to go to diagnostics with F10.
    But remember that you also need to format the space remaining of the drive to put a system there, Win98 for example.
    Bye.
I caNT RESET MY FACTORY DEFAULT SETTINGS FOR MY ACER ASPIRE 3680 COMPUTER
How to restore your computer to factorysettings without a disk?
If original andfairly new: While Booting Up.
Dell XP = Ctrl+F11
Dell Vista = F8
EEEPC = Esc
Compaq = F11
HP Desktop Vista = F11
Emachine = F10
Acer = Alt+F10
Every manufacture has or uses different Function Key combinations to do a Factory Default Recovery. Also if it didn't come withdisks there is normally a program in the menus to create your own set of recovery CDs. This must be done before you ever putanything on the recovery partition d:, if you used d: for anything you need toremove what you put there or the recovery will not function.(As soon as yourcomputer is turning on press the F10 key and it will take you to the systemrecovery screen, click on the advanced option and click Destructive recoveryand click next. WARNING: before doing this backup anything on your computer youwant to keep pictures, videos, music etc. This will delete everything that didnot come pre-loaded from the factory, so if you have pictures of Aunt Fae'sClass reunion you should probably back those up if you want to keep them.)
Oct 22, 2011 | Acer Aspire 3680 Laptop
Printer will only print from one program (it will not print from microsoft office or anything), however when it does print from this program, the document is overprinted with either computer code (I am...
have you set the dell 1700 Laser Printer as your default printer? Go to printer & faxes, right click on dell 1700, choose "set as default printer"
Apr 10, 2010 | Dell 1700n Laser Printer
Acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jun 22, 2009 | Acer Aspire 6920 Notebook PC
Compaq presario 1700 LCD issues
i have the exact same problem. try connecting the laptop to an external VGA screen. if it works, then the problem is most likely a loose cable (connector). It turns out that the connector (which connects the motherboard or gfx card to the LCD screen) on my laptop is torn and cut. see if u have the same problem. this link might help u check out ur problem:
http://www.laptopparts101.com/lcd-screen-video-cable/
Nov 21, 2008 | Compaq Presario 1700 Notebook
LAPTOP HP G5000
When you press F10 to enter the set up nothing happens, is that correct, and what does the beep sound like? Also, does it beep if you don't press anything, and after the initial screen with the F10 message, what does it do?
Jul 04, 2008 | Computers & Internet
Compaq armada 1700 only starts on safe mode
If this is your notebook - Compaq Armada 1700 (316320-056) PC Notebook. The system memory only came with 32MB's of memory. Your not telling me enough. Have you recently upgraded your operating system? If I have this wrong please post which Compaq you have from the list I'm providing from this link:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=96221&taskId=135
If you are trying to run a XP version your memory will need to be increased to at least 512MB. You still have the Compaq's splash screen loading when you turn on your notebook which blocks you from seeing the amount of memory installed in your notebook. So when you start your notebook press the F12 key on your keyboard. You need to enter the bios. If F12 does not get you there than try F10 or F1 key. At startup. Repeat hitting the key every two seconds till the Bios screen loads. Look for the amount of memory installed. At the bottom of the bios screen is instructions on how to navagate while in the bios. You'll need to post back with what you found If I'm to help further.
Feb 07, 2008 | Compaq Armada 1700 Notebook
Cmos
try del f4 f10 f3 f6 f8 f9 tab
Feb 02, 2008 | Compaq Armada 1700 Notebook
Compaq Armada 1700 Notebook Logo
203 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
