Question about Makita 3 x 24" Belt Sander
Slipping belt My Makita belt sander 9924DB has suddenly started to slip its belts. Its as if the belts (3X24) are too long. The motor works fine, the roller spins but they don't grip the belts anymore. What's going on?
  • 2,176 Answers
OK the belt tensioning mechanism is spring loaded. First what is the quality of the belts are they real flimsy or stiff. You say the rollers spin but my question does the rear roller still spin and the belt remain stationary. If so the rubber belt on motor is bad. I would take a look for excessive wear on the rear roller. Does the yoke mechanism snap forward or move slowly, look for a build up of sawdust in this area that might be restricting movement on the yoke. The wear plate in still good condition. One other thing on the belts are they directional? Do they have an arrow on the inside if so that has to point toward front of tool. I looked at a breakdown and could not see anything else to suggest. I never had this problem except with belts when I was at Makita.
Posted on Jan 19, 2009
I have a Makita belt sander,just replaced belt tensioner system including springs and roller but belt drive roller still keeps stopping on relatively light load even though the motor is running
very good trade tool
how quickly is it getting hot
slowing motor could be the cause
motor bushes and bearings can be replaced
did the motor drive belt under the cover get replaced
Jun 02, 2016 | Makita 9911 Compact Lightweight 3" X 18"...
Belt sander runs until I put pressure on it
It sounds like the sand paper itself is slipping. There should be an adjustment to tighten the pressure on the sand paper itself.
Feb 28, 2015 | Ridgid Makita 98462 9910 Belt Sander 120v...
I have acquired a makita 9924db belt sander, but not a manual. The dust bag is wide open on the bottom - shouldn't there be some sort of device on it to keep the dust in? Also, I would like to know...
there is usually a plastic clip that slides over the bottom to seal the bag, as for the manual go to "makitausa.com" and you can download a manual from there. Let me know if you need more assistance.
Jul 08, 2011 | Bosch 1274DVS 3" x 21" Belt Sander
Sander Belt keeps slipping off.
what I would do is using compressed air clean the underside as best you can there might be a buildup of dust not allowing the yoke to extend fully, then look at the condition of the rear roller, is should have a crown in the middle, make sure the belt tracking mechanism moves freely and I believe there was a plastic cap over the screw head to push the yoke. If it is not there it might be part of your problem. Lastly make sure if you are using directional belts that they are installed correctly, You can find a breakdown for this tool at Makitatools.com
Jun 09, 2010 | Makita 9404 4'' x 24'' Belt Sander
Unable to remove dust bag
Get your wife to help you remove bag. Turn and pull.
Jul 22, 2009 | Makita 9924DB Electric Sanders & Polishers
How do you replace the drive belt on a Porter Cable Belt Sander
There is a lever on the side at the front right near the roller that you can use to release the spring tension on that roller (moving it slightly to the rear).  Once the tension is released you can slip the sanding belt onto both rollers from the side.  Release the lever and the spring will put tension on the belt to hold it in place.  Use the knob on the left side to center the belt on the roller if it starts to slip sideways when in use.
May 28, 2009 | Porter Cable 361 3" X 24" Sander
Belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Mar 18, 2009 | Black & Decker Tools & Hardware - Others
The belts on my Makita 9304 belt sander are wearing unevenly
check the wear plate on the bottom and also check the front roller for being out of round is where I would start. Let me know if doesnt help
Feb 17, 2009 | Makita 9404 4'' x 24'' Belt Sander
Makita 3 x 24" Belt Sander Logo
694 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
