Question about Porter Cable PCL318IDC-2 Tradesman 18V Cordless Lithium-Ion 3-Piece Combo Kit
18 V Ni-Cad charger repair
Battery charger not charging, could it be a simple fuse?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
From what I've seen.....usually when Lithium batteries won't charge it's because they lost too much of there charge. As soon as a Lithium battery shows signs of weakness they should be charged. But to answer your question most chargers do have a fuse soldered to a circuit board so yes it's possible to be a fuse but not usually "simple".
Posted on Jan 04, 2013
  • DAVID MALDONADO
    DAVID MALDONADO Oct 28, 2013
    CAN YOU SHOW ME WHERE TO LOOK FOR IT!
  • Craig Becker Oct 30, 2013
    If you seperate the houding of the charger it should be pretty easy to see. They usually look like a glass tube style fuse. It could be a slow blow so instead of glass it would be paper looking. Again I haven't seen the inside of this one so it's just a guess.
Bosch al1860 18 v charger shows battery is charged but battery flat and doesn't charge... any suggestions. Switches to charged full solid green light as soon as battery placed on charger.
Battery might have gone high resistance and/or dry. Depending on what type of battery it is, try checking to see if it needs distilled water.
Mar 12, 2017 | Miscellaneous
Is the Dewalt DE9108 battery charger suitable for charging Ni-Mh batteries?
  • For Battery Type: Ni-Cd Ni-MH
  • Input Voltage: 110V-240V
  • Smart Charger for Dewalt 7.2V ~ 18V Ni-Cd Ni-Mh Li-ion Battery
  • For Brand: DEWALT
  • Color: Black
  • Brand New: A brand-new, unused, unopened, undamaged item in its original packaging
May 04, 2015 | Dewalt Drills
Icom bc-179 do not charge the battery
Charging a battery requires two components. A working charger and a functioning battery. The concept is simple. A battery charger must output more voltage than the battery does, and at an acceptable current level. First determine the battery output from the ID sticker, then measure the charger output. It must be 1 or 2 volts more than the battery output. If the charger is working, charge the battery overnight. If the battery does not charge or runs down quickly, the battery must be replaced. All batteries have a limited number of charge cycles. The most common problem with Ni-Cad batteries happens when they are re-charged before they are completely discharged. Recharging a half used Ni-Cad sets up a short term memory and the battery discharges faster than normal.
Nov 17, 2013 | ICOM Informatique Radio Communications
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
I just bought the Lithium - ion batteries for replacement for my 18.0 volt ni-cad battery. when I put it (ion battery) in the charger (ni-cad charger) no lights come on. what's up?
Lithium Ion batteries don't charge the same way ni-cads or ni-mh do. You need a lithium ion specific charger to charge them. (Some chargers do multiple types.)
Apr 22, 2012 | Ryobi Multi-Volt Battery Charger
How do you know when a black and decker battery's life is over
Normally when it will no longer hold a charge, that is, no matter how long you charge it, the battery goes flat very quickly. This happens sooner with Ni-Cad batteries than with Li-Ion.
Nov 19, 2011 | Black & Decker 18 Volt Cordless Drill...
How many hours we should charge the battery fist time Nokia-2700
There are basically 3 types of chemicals currently being used for cell phone and laptop batteries. Ni-cad, Ni-mh and Li-ion. There is a fourth makineg its way in Li-ion polymer. A couple things are consistent for all types of batteries no matter what chemical is inside. You must initially give the battery a 12-14 hour charge on the home charger. (Don't use a cigarette adapter for the first charge. This conditions the battery and don't take it off the charger that first time even if the charging indicator says it's full after 3 hours. Also the manufacturer's also state to run it thru 3 charge cycles. What that mean's is that you fully charge and fully drain 3 times. 1 full charge + 1 full drain = 1 charge cycle. Here's where the way you charge the battery starts to differ.
Ni-cad: Mostly only on older devices, has a "memory" effect, should be drained before a full charge is put on it, should be removed after overnight charge or can be overcharged and burnt out.
Ni-mh: Still used for some devices, has slight memory effect but not enough to have to fully drain before the recharge, should not be consistently left on charger after full charge that can eventually burn out battery and shorten usage time.
Li-ion and Li-ion polymer: Used on a lot of newer devices, has no "memory" effect, should be recharged as often as possible, actually likes to be charged and draining it regularly can cause the usage time to be shortened, can NEVER be overcharged so whenever you're near a charger put it on there. Besides those benefits a li-ion battery is lighter and smaller but the chemical can hold more charge than Ni-cad and Ni-mh.
So the one reply to your question said to error on the side of draining the li-ion batteries. This is incorrect information. You want to charge the battery before it gets below a 20% charge. Also batteries will not go bad from accidentally doing the incorrect charging procedure here and there but normally follow the correct procedure. One last note try to use the home charger more often than the cigarette lighter charger for best long term results. Cigarette lighter chargers do not give a full charge (about 95%) which in the long run can damage any type of battery listed.
Oct 07, 2010 | Nokia N70 Cellular Phone
I need ni-cad battery specifications for Acoustic Research AW-721 headphones. I bought replacement ni-cads but they don't charge when the headphones are placed on the headphone cradle/charger.
The AR AW721 headphones require 3 AAA NiMH batteries, not Ni-Cad. The original batteries are 1.2 volt, 550 mAh. I replaced mine with Energizer 850 mAh AAA batteries, which work well and actually last longer per charge than the originals.
Sep 20, 2010 | Acoustic Research AW-721 Consumer...
Switch and bateries
Makita makes two 12V Ni-Cad pod batteries: Battery 1222/2.0Ah (PN: 192598-2) and Battery 1220/1.3Ah (PN: 192681-5). Makita's universal charger (PN: DC1804) will charge any Ni-MH or Ni-Cad pod or stick battery from 7.2V to 18V.
Aug 18, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
I bought a new highter current ni cad for my makita; however, the
As long as the charger voltage and the battery voltage match (7 volts) there should be no problem. A fast charger just runs more current thru the battery (per unit time) than a not-so-fast charger. If you notice the battery getting really hot when it's charging (like too hot to touch), stop using it.
Apr 28, 2009 | Makita 6019DWE 3/8 Cordless Drill Keyless...
Porter Cable PCL318IDC-2 Tradesman 18V Cordless Lithium-Ion 3-Piece Combo Kit Logo
634 people viewed this question
Top Porter Cable Drills Experts
LINDEN DAVIES
Level 1 Expert
Tom Chichester
Steve P
Steve P
Are you a Porter Cable Drill Expert? Answer questions, earn points and help others
