Question about Whirlpool GS6SHAXMQ Side by Side Refrigerator
Whirlpool GS6SHAXMQ Side by Side Refrigerator - Ice Maker Problem
Hi, after about a year my ice maker stopped working. It's been out of service ever since (about 2 years now). I trouble shooted everything I can find. In one post you said to fill it manually and see if it makes and dumps the ice. Well, it did. So, I assume it a water supply issue, but I can't seem to find any problems with the tubing and there is no freeze over that I can see. Any suggestions on what to check next?
Thanks!
This happened to me after i had to move the freezer and it was unplugged for a while. When it was plugged back in the ice maker would not work.
Assuming both the ice maker itself and the rear water AC solenoid switch are actually not broken and are functional, and you are getting water from front door dispenser, then check the inside supply tube (black) is not frozen and blocked. Check with q-tip or feel to see if frozen.
If supply tube is frozen, thaw by holding up small full clear glass of heated water placing the frozen tube into the heated water. The clear glass will allow you to see when ice slips out.
Next try resetting the freeze cycle. Turn off the ice maker switch, remove the maker by carefully disconnecting the inside power cord. You will need to remove the inside door flap. Rinse the maker with warm water, allow to come to room temp.
Re-install maker, connect power cord. Turn on ice maker switch. Make sure Infrared sensor is not blocked. Now wait for temp change and listen for water to fill tray. It took maybe ten minutes for me. You will be able to hear the water fill with the door closed.
Again, this assumes nothing is actually broken.
This worked for me. Good luck.
Posted on Jan 19, 2009
We have a GE side-by-side refrigerator. Ice maker has stopped making ice; however, the water dispenser still works.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 17, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
The freezer, ice maker has stopped working, can it be fixed, whirlpool s20drss33-a/g
heatman101
cbxcnghd
Jun 26, 2010 | Whirlpool S20DRSS33 Side by Side...
Ice maker stopped working
heatman101
98978yi
May 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
ICE MAKER HAS STOP WORKING IS THEIR A WAY TO TROUBLESHOOT? Whirlpool refrigerator MODEL: ED5THAXMS00 SERIAL: SP2854019
heatman101
kjkjgkjgkj
May 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator dispenses ice, but does not dispense water?
Unfortunately, the housing that the water filter fits into is also the housing for the solenoid controlled water valve, and that is the most likely failure item.
Mar 29, 2010 | Whirlpool GS6SHAXMQ Side by Side...
It could be frozen up. Or, the control arm could be in the up/off position. Just look around and see if you have an ice buildup. Or if that wire arm is up. If there is ice just turn the temp up a notch or two for one day and your problem will be solved.
Mar 18, 2009 | Whirlpool GS6SHAXMQ Side by Side...
GE side by side fridge. Ice maker makes ice, but when I push the button on the front it just hums. Nothing spins.
you need to atake the ice bin out and thaw all the ice in it out. its causing the auger to be in a bind
Mar 05, 2009 | Whirlpool GS6SHAXMQ Side by Side...
Whirlpool Side by side Ice maker
check water valve for ice maker how old is the ice maker is more than 3 years then it might need replacement as well
Nov 03, 2008 | Refrigerators
Whirlpool GS6SHAXMQ Side by Side Refrigerator Logo
291 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
