Question about Sony DVP-SR160B DVD Player SVC2340/10 Lens Cleaner SONY
I'm trying to set up this DVD player but I can't get any sound
    Problem Solver:
  • 9 Answers
What are you connecting it to your TV with? Is there a separate volume controller on the DVD player itself? Make sure all plugs are properly connected. Hope this helps. Get back in touch. Steven :D
Posted on Jan 01, 2013
I have a 39 inch Emerson hdmi led tv and it is hooked up to Directv. I'm trying to hook up my daughters DVD player it is a Sv 2000 DVD CD player e everything is hooked up we get sound no picture.
hi try using RCA cables to make sure youre connections r not the problem..plug the rca cables n the output of dvd then into tv input & set tv input to AV .good luck
Sep 02, 2015 | Emerson Televison & Video
Koss DVD with surround sound speakers and I can only hear the background music?
You need to change to sound setting on your amp to 'multi channel in' or dts, depending on what you are trying to watch. Also make sure all speakers are polarised correclty ie +/+ -/-.
Jun 16, 2012 | Koss KS4125 DVD Player
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
Dvd, sound, no picture
If your DVD is external, I'd check TVs input settings: if your DVD on "progressive scan" mode, it delivers video signal via "component" connections: green, blue, red plus 2 separate red/white for the sound. If you trying to use 3 wires: yellow, red, white( composite), good chance, that the only sound is delivered. Try to switch DVD off 'progressive", if you only have 3 wires. It will deliver "picture". Or, verso-visa: using "component", 5 wires, but DVD set off "progressive scan". I've seen that confusion many times! Unless you have 'built in" DVD player. no matter what, it's must be broken! Use external DVD player, instead! $30 and trip to the store, will solve your problem. Don't want to fix TV, if everything else is alright. Myself, I never liked those "combo" units. You got stuck with mediocre TV and lousy DVD player. Better: separate them!
Good luck,
Alex.
Dec 25, 2011 | Toshiba Televison & Video
Hello, I recently bought an Onkyo HT-S9300 home theater system. I am trying to get it to work with my DVD player using optical cable for the sound, since the DVD player does not have HDMI output, but I...
In your DVD player audio setup change the digital output to bitstream. You have not mentioned which DVD player you are using.
Some players it will be given
Digital Out - Off/ On select On
Dolby Digital - Dolby / PCM select Dolby
DTS - On/Off select ON
Jun 19, 2011 | Audio Players & Recorders
I can't get the sound to work from my tv to my dvd/vcr player. i have it plugged into the right spots on the tv & dvd/vcr player stil no sound
Tries another set of cable,some time the cable have bad shorted at the cable neck flexable and not working correctly are the causes.Ur DVD/VCR player have a HDMI hub connection,used a HDMI cable for connection will work better for a HDTV.
Jun 09, 2011 | Insignia 42" LCD Flat-Panel HDTV
No sound
hi! press the audio setting and set on the audio set on
Sep 08, 2009 | Jensen VM9020TS Car DVD Player
My dvd player has no audio sound at all daewoo dvd player perfect picture but no sound any ideas
is the connectors ok?try swapping your connectors.are you using a stereo amp?connect your rca plugs to ML and MR for stereo.check the audio settings of the DVD just to be sure.
May 31, 2009 | Panasonic DVD-S52 DVD Player
I cannot see the video when i plug the DVD Player to my TV set. The model is AKAI ADVC-7013
start with the sound , do you have some speakers or amp that can take rca connnectors if so plug in to audio out and if you hear sound then the video is presumed ok too , likely some setting or cable issue then.
if no sound the the proc amp is shot.
Apr 26, 2008 | Akai DVDP5851 DVD Player
Sony DVP-SR160B DVD Player SVC2340/10 Lens Cleaner SONY Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
