Question about Roland Boss RC-3 Loop Station Compact Pedal with USB
Boss RC-3 does not power on, any information about why this unit stop working. Clearly seems to be the power source section on main PCB, if somebody does have an schematic please contact.
Most likely the device has been incorrectly powered. The most easy way to check this is the following:
- unscrew the 4 screws on the RC-3 bottom
- slide the board out from the connectors holes
- gently detach all the connectors and wires coming to the board
- locate the schottky diode (SS14) close to the power input connector
- check if the diode is short
- replace the diode if it is
- if this does not solve the problem probably also the capacitors in the power section are shorted.
Message me for further info
Posted on Jan 14, 2013
Boss troubleshooting
if your using it from the battery ck that the wires are tight connected and the battery clips are tight (both ) if the electronics senses a very quick power interruption then yes it will reset the loop back
Jul 31, 2014 | Boss RC-3 Loop Station Pedal
My RC-50 suddenly won't power on.
Has the unit ever had another ac adapter plugged into it?
Mar 04, 2013 | Boss Rc 50
The Auto on my Boss RC2 sometimes doesn't seem to pick up a signal and engage. It is plugged into a multi- socket adapter and I do not have the amp turned up too loud as the room is tiny. I thought it was...
Sometimes, with BOSS pedals, the battery must be disconnected before using another power source. I ran into the same problem with my DS-1 distortion. If it's not that, then check the power rating of the power adapter. It should read, for the output, exactly 9V DC. If it doesn't, then you have to get a power adapter that has that same rating. Boss pedals will not use anything other than 9V DC (I know, I've tried).
Hope that helps!
Mar 26, 2011 | Roland Boss RC-2 Loop Station Stompbox...
Kyocera mita 5035 code 6400 c
Zero-crossing signal problem
• The main PCB does not detect the zero-crossing signal (Z CROSS SIG) for the time specified below.
Causes
Poor contact in the connector terminals. - Check the connection of connectors YC1-3 on the main PCB and YC2-6 on the power source PCB, and the continuity across the connector terminals. Repair or replace if necessary.
Defective power source PCB. - Check if the zero-crossing signal is output from YC2-6 on the power source PCB. If not, replace the power source PCB.
Defective main PCB. - Replace the main PCB if C6400 is detected while YC2-6 on the power source PCB outputs the zero-crossing signal.
Dec 18, 2010 | Kyocera Mita KM-5035 Printer
My Boss RC-50 has stopped working. I used the power chord for my RC 50 in my Boss OC 3 pedal and then tried using the chord in my RC 50 again and it won't work. It won't even work with other power...
CHeck the voltage out of the adapter. It should be around 9 to 11 volts. If it is not, it is possible that the OC3 has reversed polarity AND a protector that put a short on an incorrect supply. If so, it could have damaged the RC50 adapter. If the RC50 adapter is putting out correct voltage, then I suspect the inout connector on the RC50 may be damaged or not quite seated. Visually inspect the connector first.
Dec 04, 2010 | Boss Rc 50
Model HSB03 stopped working after power outage. Is still like new would like to keep ....any suggestions?
HI. What generally happens during a power outage, will be a serious surge. The surge will, essentially, destroy the Main PCB. Without proper PCB function, the unit will not operate. All power is controlled by the main PCB. It routes power to the compressor and fans, as well. You can, visibly, inspect the affected part by pulling the access panel on the rear side of the unit. It will be mounted on a bracket, near the compressor assembly, or just in the middle section of the rear side of your unit. Inspect the Circuits and relays that are mounted on the PCB. If burn marks are present, or a brownish discoloration is sited on the circuit board, simply replace the PCB.
NOTE_ PCB location may vary in your model Generally, they are located just behind a access panel, on the rear side of the unit. Some may be mounted in close proximity of the compressor platform.
Jan 14, 2010 | Haier Refrigerators
Whirlpool Refrigerator not working -------------------------------------------------------------------------------- Hi all, I have a Whirlpool ED22PC SxS fridge which has stopped cooling on both the...
Hi. Due to the fact that the fans are not operational, this will confirm that the Main PCB has failed. This is the main power control board. It must be replaced, asap. The general location of this affected board will be just behind an access panel, near the compressor unit, or on the backside, mounted in the middle section of the unit.
Once the Main PCB board is replaced, the unit will return to its normal operating status.
Dec 21, 2009 | Whirlpool Refrigerators
My 26" TV/DVD combo remote seems Kaputt. Nothing works from power up on. Of course new batteries added. Seems very weak design (composite buttons direct on PCB). Any solution or source for replacement...
Try a universal remote, however I would advice you to try the buttons on the set to check if it works. It might just be a problem with the TV itself..........sodeep
Oct 09, 2009 | Mintek DTV-263 26 in. LCD Television
Roland Boss RC-3 Loop Station Compact Pedal with USB Logo
391 people viewed this question
Top Roland Computers & Internet Experts
Stu Morris K
Gil Shultz
Tom Chichester
Are you a Roland Computer and Internet Expert? Answer questions, earn points and help others
