Question about Asko 24 in. D3350 Dishwasher
The soapcover opens when I close the front door.
Happens every time when I shall start any washingprogram.
    Genius:
  • 1,669 Answers
The spring on the soap cover is not pushing the catch tightly enough to keep it closed when there is vibration of the top cover of the machine. Remove the spring if you can and stretch it out a bit and remount it. Otherwise, replace the spring.
Posted on Jan 01, 2013
Front Doors LOCKED OPEN.. How to close?
Lift the door handle as if you were opening it
Hold the handle & use a round phillips to hook
& rotate the white door latch to the open position
May 18, 2014 | 2009 Honda Odyssey
Od error code
The Neptune Od code will come up when the unit does not see the door opened before starting another cycle following a completed cycle. Simply opening the door and closing it again will remove this code until the same incidence happens again. So if you are looking to rewash a load of cloths you must first open the door then close it before you can start the machine over. Pleazer Appliance...
Apr 13, 2014 | Maytag Neptune MAH5500B Front Load Washer
My Ssangyong Musso shows door open light but the doors are closed what shall I do
Hi Javid, The most probable problem is one of the switches on one of the doors. Open one door at a time and press the switch with your finger to test which is defective. Regards John
Oct 10, 2012 | Kia Cars & Trucks
Chamberlain 9902 won't close at times
Does the motor run? Does it make a noise. What actually happens?
Apr 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
My garage door hmmmms but will not open or close. How can I fix this?
Could be the start capacitor is bad. When this happens the motor will not start but just hums for a few seconds. Could also be that the door is open and jammed against the bolt just in front of the motor unit. Is the door open or closed?
Jul 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Panel lights are on. push on button nothing happens
I have experienced the same thing a number of times. To solve, open the door, then turn the knob, and push the start button on and off, and push the delayed start button (3, 6, 12 hour). Then close the door, and retry. This routine seems to reset the system.
Apr 22, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
Power is on, lights are on, put it to a setting and hit start and nothing happens no water(water is on) no spinning and no drying. Have checked all the hoses and cleaned the filter.
I sometimes get this happeing if the door doesn't close and seal. If you can open the door then this is the issue. THe door should seal and won't open when you hit start. Try opening and closing the door tightly
Feb 28, 2010 | EuroTech EWC177 Front Load Washer / Dryer
Door opens up for 2 ft then slowly closes down
Sounds like one of your door springs has broken or the drive gear is going bad. The gear is white nylon and is just in front of the motor.
Sep 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Asko 24 in. D3350 Dishwasher Logo
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
