Question about Gateway HD2201 22" LCD Monitor
Gateway hd2201 backlight - Gateway HD2201 22" LCD Monitor
3 Suggested Answers
  • 401 Answers
SOURCE: My Gateway HD2201 turns on and off
change the resolution of vga to 1024x768
Posted on Mar 17, 2010
  • 80 Answers
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Posted on May 15, 2010
Is there a special driver for hd2201 or is the 'generic pnp monitor' driver the best/only one?
If your monitor is a Gateway FHX2201Q, then your driver is at:
http://www.support.gateway.com/product/default.aspx?tab=1&modelId=3261
If your LCD monitor is an HD2200 series LCD monitor, then "generic PNP monitor" is it.
You can confirm by spending some time at the Gateway support site:
Feb 13, 2011 | Gateway HD2201 22" LCD Monitor
I purchased a gateway HD2201 monitor all I see is white screen
Maybe your resolution is not set to the right settings for your new screen, set the resolution and refresh rate lower with the old screen attached and try again with the new screen
Jul 18, 2010 | Gateway HD2201 22" LCD Monitor
Good Luck!
May 09, 2010 | Gateway HD2201 22" LCD Monitor
Mar 17, 2010 | Gateway HD2201 22" LCD Monitor
Gateway HD2201 monitor, the touch menu buttons are not working. The menu is up on the screen but cannot get it to go way since the touch buttons do not work. Any ideas? Is there a way to reset that may...
kruwv, Use Gateway warranty first!!! Else gateway swapout+ cash for a factory refurbed unit if program exists. Did you un-plug unit from wall outlet and then reconnect power? Problem same? How old is unit? Approximate total "ON" Hours does unit have??? Do any of the buttons appear to be "stuck"?? Was unit working perfectly the "day" before? When strange things occur with CCFL backlit LCD displays I would first suspect the "switch-mode-power-supply" as area to look first. Read some of my other responses in my FIXYA profile for more options for repair. 12fixlouie
Jan 04, 2010 | Gateway HD2201 22" LCD Monitor
Where i download the driver xp for gateway hd2201 monitor
Download from the gateway site. You will need your serial number.
Dec 20, 2009 | Gateway HD2201 22" LCD Monitor
My monitor turns on but instantly the screen goes black its like the light doesnt work
If you look at the screen from an angle with video supplied, you will probably see a 'ghost' of the image. If that is the case, then either the fluorescent backlight itself or the inverter that supplies the high voltage for it has died. If you are somewhat careful and handy and have the required tools, this could be a DIY repair.
The fluorescent tubes are available form multiple sources and the inverter which is likely on a small, separate board, is probably available via Gateway or the original mfr.
You won't be saving a whole lot, but if the monitor was otherwise satisfactory, have at it.
Nov 29, 2009 | Gateway HD2201 22" LCD Monitor
When I turn on my monitor I can see the Gateway letters come on the screen but then it just goes dark again. It comes on for a split second and then goes dark again.
joel_herrera, Yes, this is a very common symptom of a failing Switch-Mode-Power-Supply and/or Inverter circuit! Very common in 2-4 year old lcd/fpd's. How old is your's? Do you have warranty? Have you tried the Flashlight test? DO THIS! Reconnect lcd monitor to your fully booted PC with a known good WIN desktop screen. Then power "on" the HD2201 and tell me what happens and what you see or don't see after the screen goes BLACK! Shine a bright flashlight onto the screen at different angles and let me know the results. I'm louie12fix on fixya or lmistyrel @aol.com BYE
Apr 07, 2009 | Gateway HD2201 22" LCD Monitor
Display rotation on monitor
Hi, the shortcut to change the orientation of your display is:
<ALT>+<CTRL>+<ARROW>
Mar 18, 2009 | Gateway HD2201 22" LCD Monitor
Gateway HD2201 22" LCD Monitor Logo
44 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
