Question about Canon Opteka 650-1300mm F8/16 Super Telephoto Zoom Lens LR 1300HD
Instuctions for opteka 650-1300 lens for use on konica minolta
Trying to use the lens on konica minolta DSLR, i have the correct adapter but screen says "no lens attached" i am trying to find out where in the menu i need to change something
Try turning off the shutter lock.. In my Dynax 7D manual it tells you to turn off shutter lock when attaching to a telescope or microscope this is what this lens basicly is .The shutter lock is turned on and off in section three of the custon menu on my Dynax ,check your manual for your camera to find out where to turn on and off shutter lock, hope this helps
Posted on Jan 27, 2009
Why is the opteka 500mm f8 for minolta/sony not working with my konica minolta maxxum 50
you have to put your camera to manual, and do all settings manually. Be aware there has to be enough light, because of the f8
Jul 13, 2014 | Cameras
My opteka zoom lens is not recognized by my Nikon d300
First, make sure that you have the right adapter to couple this lens to your Nikon. A universal adapter may actually fit and properly click into place but the electrical contacts may not match your Nikon. Make sure the electrical contacts on the adapter match the contacts on the camera body.
If they don't match, get an adapter specifically for Nikon and perhaps, specifically for your camera.
Once you have verified that it is a Nikon adapter, you need to make sure the electrical contacts between the adapter and the camera body are clean. Many people clean the contacts by holding the lens release button down and twisting the lens or in this case, the adapter, on and off ten or more times.
If neither of these options work you may need to contact Opteka, Nikon or both.
May 02, 2014 | Opteka 500mm f/8 Telephoto Lens fr Nikon...
Will a opteka 500mm mirror lens fit onto a nikon d3100?
When you go to the Opteka page here
You can select "options" for the camera company (there are 6) which you have. It may mean that the lens uses an adapter for the different pin and thread patterns, so the lens if bought new will fit with the selected option, a used one, you may need to get an adapter.
Best bet is to try before you buy.
Apr 11, 2014 | Opteka Cameras
I have a Soligor C/D 28 - 200 mm, f3.5 - 5.3 Macro lens used quiet well on a Minolta XG1 and want to know whether I can use it on a Nikon D90 DSLR and if so, where can I source an adapter. Is it worth the...
The lense will probably work with an adapter. try ebay. i purchased one for my canon lenses for macro work. note that the focal length of the nikon is 46.5 and the minolta is 43.5 and infinity will not work with out an adapter with a correcting lense. you will find a adapter with out a lense will work fine for macro.
Jul 19, 2010 | Cameras
The shutter button does not work, the camera is on but it wont take the picture
this could be caused either by no memory card or a lens error , remove the power , press the lens release button , unscrew the lens , clean the lens contacts with a little bit of alcohol on a lens cloth , do not touch the contacts inside the camera , remount after it is dry and insert power and try agian . if this doesnt't work go see a repair guy
Jun 18, 2010 | Sony Alpha DSLR-A100 Digital Camera
I have been offered a SiGMA 400mm F/5.6 manual lens for a minolta mount. Will it fit my camera? Cheers Pete
Minolta had two lens mounts. One for manual focus SLR film cameras and one for Auto Focus SLR Maxxum film and digital SLR cameras. Sony uses Minolta Maxxum lens mount.
If the Sigma 400 f5.6 lens was made for Minolta X-700 series, XG, series, XD series, SRT series, then it will not fit on your camera.
Jun 17, 2010 | Sony Alpha DSLR-A200K Digital Camera
How to mount Minolta AF 28-80/3.5-5.6 on pentax
Unfortunately, it is not possible to mount Minolta lenses on a Pentax K mount camera and retain either auto-focus, metering, or the ability to focus at infinity.
The reason for the loss of the ability to focus at infinity is because the distance from the mount to where the image forms on a Minolat lens is 43mm, whereas on a Pentax it is 46mm, so the Minolta lens glass would need to be 2mm into the body of the Pentax camera in order for the image to form on the sensor (i.e. have a clear image that is in focus).
The only solution to this is to purchase an adapter with an optical element such as this: This will allow you to focus at infinity, however you will have to use stop down metering and manual focus, as the electrical contacts will not connect. Also, you can expect a slight loss of image quality when using an adapter.
I personally have a few Minolta lenses that I have wanted to use on my Pentax, so I understand your pain. It is a shame they don't work better.
Thank you for using FixYa!
Apr 18, 2010 | Pentax *ist DL Digital Camera
I have a Minolta Maxxum 450si with several lens. What Digital camera would these lens work on. John
My best assumption would be Sony DSLRs since Konica/Minolta's camera division was acquired by Sony. I believe Sony is using Konica/Minolta lens mount for their DSLR line.
Aug 07, 2009 | Minolta Photography
Sony a100 match ups
Yes, when Sony took over Konica Minolta they inherited the Maxxum lens mount (Minolta's AF lens mount system). the only Minolta lenses which don't work are the earlier manual focus type.
Sony have finally launched three new models which are the first to be clearly Sony designed, but they have still retained the Maxxum lens mounting.
Jul 03, 2009 | Sony Alpha DSLR-A100 Digital Camera
Cameras compatible with Quantaray AF 70-300mm lens
Depending on how new your Minolta SLR film camera was, the lens may or may not work on a Minolta Digital SLR. In many cases, a lens with the correct mount (in this case, a Minolta mount) can be used on the same brand of camera in the digital format.
One thing you should know is that DSLR sensors are, generally speaking, smaller than the size of a 35mm film negative. Long story short, that means that your lens will have a magnification factor on the DSLR. Usually, it is in the range of 150%, so a 70-300 lens from a film camera would cover 105 to 450 on a Digital SLR.
To be sure about the mount, you'll need to seek advice specific to Minoltas -- probably best to take your lens to a local camera shop and see for sure if it fits and what features will work (aperature, auto-focus, etc) and which won't work on the DSLR.
May 31, 2009 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Cameras Logo
416 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
