Hi i also have an LG WM12225fd direct drive machine and the pump has stoped working and is making a humming noise. have emptied water drained system and blew through pipe and there is no blockage but filter had two very chewed up 1penny piece in it! how do i get the pump out? i have taken off the front cover etc and can see the pump clearly but wanted to check the easiest way to remove it so i can clean it and hopefully it will work!
stradeteox
  • 88 Answers
SOURCE: LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Posted on Jan 11, 2009
beltronic205
  • 1474 Answers
SOURCE: water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
Posted on Nov 25, 2009
SOURCE: Hi, good evening. I have a zanussi iz12 washing
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
Posted on Aug 14, 2010
livewire874
  • 618 Answers
SOURCE: My washing machine( he2 plus) stoped working I
Two screws under the front panel.
Posted on Nov 22, 2010
  • 6277 Answers
SOURCE: HOW DO I GET AT THE PUMP I have cleared all the
(try this!)
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
John C
Posted on Apr 07, 2011
Hi. Have a wd-12392TD Direct Drive LG washing machine,gives OE error code and makes a lot of rattling noises, water won't pump out,
take the back off
see if the water pump making that noise or is broken
should look something like this one
May 18, 2016 | LG WM Washing Machines
Lg wm2277 does not drain or spin
if it does not drain it will not spin humming noise is probably something jammed in the drain pump if youre machine has a clean out you can access the inlet to the pump and clean out the debris from there if not you will have to pull the hose off . if you bail as much water as you can from the tub and tilt the machine back at a good angle it will be possible to get to the pump without having to get a shop vac to clean up the water after words.
Apr 07, 2014 | LG WM Washing Machines
Machine had been giving E20 error code - filter cleared and it re-started ok. When wash was in progress - jammed at rinse stage and all lights came on (except spin speeds) and humming noise and nothing...
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
Doesn't seem to be draining water out after the rinse cycle. Just seems to make a humming noise.
Have you checked the pump for blockages? very common on these machines and has symptoms as you describe. Try blowing back down drain hose while it is humming (be prepared for a possible rush of water)
Oct 25, 2010 | LG WM-1832C Front Load Washer
My lg wm12225fd direct drive error 1E
Is it 'IE' ? There is no '1E' error code. Input error. Is water turned on? Are waterline filters clear, the ones between the hose and the unit?
Apr 07, 2017 | LG Washing Machines
Lights flashing water wont drain but making a humming noise
hello sir,
Please do the following checks
  1. nspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch (some models)
  4. Inspect the water pump
  5. Inspect the drive belt (belt drive only)
  6. Inspect the motor coupler
Click on the highlighted words for details on how to check.
Jun 04, 2009 | Maytag MAH2400A Front Load Washer
Whirlpool direct drive top loader will not spin
Hi, Is the humming noise coming from the timer area? Do you know if it agitates ok?
When you have it in spin cycle, Try lifting the lid and see if the hum stops.
The reason for these questions is that on this model, if it drains the water out but does not spin, it is either lid switch, coupler, or transmission.
If it's the coupler, it will not agitate either.
Please let me know so I can assist you further.
Thanks
Vic
May 30, 2009 | Whirlpool LSR8433K Top Load Washer
Whirlpool duet washer will not spin. pump drains well. low humming noise.
"low humming noise??" soundslike the pump trying to pump, did you try removing the lower acess panel and physically cleanout the drain pump filter?? sondsas if its still trying to empty water
Mar 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
New Garbage disposal, washing machine and dishwasher won't work.
Does not sound like these problems are directly related to the disposer. Grinding sound is most likely the impeller on the washer's pump. The washer gets to the first pump out and is unable to pump due to bad impeller or an obstruction. Bad impeller means replace pump motor. (not very hard) Check water supply to dishwasher. Valve turned off or line kinked? Filter screen at solonoid valve plugged?
Aug 15, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
