Question about Uniden DECT 6.0 Cordless Phone ID
Uniden sect 6.0 silent on, I want to turn the ring tone on again.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Uniden Master
  • 102,366 Answers
Since you didn't specify the model of your Uniden DECT 6.0 phone I can only suggest you select it from the list beginning here to download a copy of the manual.
Posted on Jan 02, 2013
5 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: Uniden Phone
goto the name and hit store it will restore the name and when going threw the store process it should show you old parameters
or goto phonebook find name and edit its preferences for that name phone ringers are set ringers so when you pick one for gereral use thats going to be the general use ringer but special ringers is what i descriped in first part
menu handset setup then ringers for a general ringer you can change to a more pleasing ringer but over all cant turn off
Posted on May 10, 2008
youngjuls
  • 3 Answers
SOURCE: No dial tone and no ring on Uniden 5.8 GHz
I have the same handset and the 2nd one seemed to stop working after working great for 2 yrs. I placed both sets together and hit the PAGE button on the main handsets cradle. Both phone's were paged and, for some reason, the 2nd handset reset. It worked for me...or at least, something in what I did worked. BTW, H1 and H2 shows in upper right side (or at least it did after I paged)...and I made sure to put the phones in the correct cradle (H1 is the main handset). I just did this so hoping it continues to work!
Posted on Oct 23, 2009
  • 102366 Answers
SOURCE: I accidentally shut off my
Since you didn't tell us the model of your phone, pick it from the list beginning at
http://www.uniden.com/scat/cordlessphones_mnl
to get the manual.
Posted on Aug 30, 2011
  • 102366 Answers
SOURCE: my uniden cordless phone model D1660-3 is in mode on,and its not ringing
Press and hold the # button. The silent mode instructions begin on page 9 of this manual.
Posted on Dec 08, 2012
Turning the ringer on my phone. uniden 6.0
Without the model number of your Uniden phone, I don't know which silencing feature you are dealing with.
Some Uniden handsets have a Silent Mode. To toggle this on and off, press and hold the # key (below 9) for 5+ seconds when the phone isn't in use. When the silent mode is enabled, the handset will ask for a length of time for the 'no-ring' option. If no key is pressed, then the Silent Mode will continue until the # key is held again.
Other Uniden phones have Do Not Disturb. The button to enable/disable this will be on the cordless phone base. The answering system will automatically turn on and none of the handsets will ring when this feature is enabled.
You can also set the ringer volume to zero. Depending on the phone, you can reset this by pressing the volume up/down buttons or going through the menu. Look for the Ringer Volume in the same section of the menu as the Ring Tone options.
If you need additional information, please add a comment with the model of your phone. I hope this helps.
Jun 13, 2016 | Uniden DECT 6.0 Cordless Telephone...
How do I turn off the silent mode on a Uniden 6.0 dect phone, so it will ring?
For the Uniden model D1680 & similar...
You ENTER "Silent Mode" by pressing and
holding the [ # ] key on the handset for a few
seconds until the display reads "Please Wait".
It will (chirp) and display "Silent Mode ON".
You can EXIT "Silent Mode" by pressing and
It will (chirp) and display "Handset #".
Another easy way to end "Silent Mode" is to go
to the BASE and press the [ANS ON/OFF]
button to turn off the answering machine system.
(Push the [ans] button, do not unplug the power)
"Silent Mode" will clear a moment later while the
control voice tells you "Answering System is OFF"
Now you can again turn on the answering machine
system as desired.
How do I turn off the silent mode so the phone will ring?
system as desired.
Got a telstra easy touch dicovery 3. Cant turn silent mode off
Hi Shannon,
TELSTRA EASYTOUCH
DISCOVERY 3
SYMPTOM = No incoming ring or alarm tone
RESOLUTION:
- Check the ring tone and ring volume settings under
Profiles
- Check the handset is not muted (Long press the #
key
Apr 30, 2014 | Cell Phones
I have the uniden D1688 phone and the ringer will not ring
I went into the menu and turned off the personal ringer. And that worked for me. When you set up a caller into the phone book it ask you for a personal ring tone. If none is selected none will ring.
Jan 01, 2012 | Uniden Lands Phones
Low volume with ring tone. Also when on silent it still rings?
1st silent your cell then go to setting> tone setting> ringing volume>off..
May 21, 2010 | Nokia 2630 Cell Phone (Unlocked) - Black
Motorola Razor -Silent Mode
what you have to do is customize it as silent mode by turn the ringing volume down and turning the sounds off. this can be done in profiles.
please rate me. thank you.
May 26, 2008 | Motorola Mobility RAZR V3
Silent Turn-On
Hi:
Before turning your phone off each time, reduce your phone's volume to 'Silent'. Each time you turn your phone on, the tone will not sound. Once you turn your phone on again, raise the volume again to hear the ring tone. You can also leave the volume in the 'Vibrate' mode, and it will vibrate each time you turn it off or on.
Tgillen4
Apr 22, 2008 | Motorola Mobility TracFone C139-4 Cellular...
Uniden DECT 6.0 Cordless Phone ID Logo
23 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
