Question about Kenmore 15864/15862 Top Load Washer
Washer only spins light loads
My son overloaded the washer with a duvet. Now it will spin light load ok but you have to be standing there and give it a spin when you hear the click with a full load.
The washer is only 18 months old GE model WLDSR416F3WC
    Novelist:
  • 101 Answers
Sounds as though your son damaged the transmission. If I were you I would take it out of his allowance...just kidding. A cheap thing that it could be that you may want to check though is your agitator dogs. Inside the agitator at the top are agitator dogs that have little teeth on them to catch the agitator and make it spin and agitate. Pop off the top where the fabric softener goes in and check them and see if they are catching. If not, if they look damaged and the teeth look worn then easy 5 dollar fix. Buy some new ones and replace them. If they look good though then your son damaged the transmission by overloading it and that is going to cost you between 150 and 250 dollars depending on if you get a refurbished one or not. If it's only 18 months old though you may still have a warranty on it and in that case take it back and don't say anything about the duvet. Just say one day it stopped working. You may be able to at least get it fixed for cheaper or free in that case. Again, just don't say what happened, as far as you know, it was working and then one day it just stopped. Hope this helps you and if you have anymore questions let me know. I will get a notification if you post something else to this. Good luck.
Posted on Jan 22, 2009
Sometimes it spins sometimes it doesn't had a problem this morning with a king size quilt, it came out soaking so I tried to spin it again & its still wet, I put in another load & then it...
Duvets/quilts are very heavy when wet, causing a very unbalanced load. If the machine could spin such a large uncentred (UK spelling!) mass it would shake itself to pieces, so all modern domestic washing machines have unbalanced load detection systems. In use these systems will vary the drum rotation to try and get the load evenly distributed before going into full spin, but if they can't then no spin occurs.
Very few domestic washing machines can take a duvet or quilt (certainly no front loader which I'm aware of, and only a few top loaders), and those which can fit them in are usually overloaded. There's nothing wrong with your machine, you just need to use a commercial launderette machine to wash and spin your duvet/quilts in future.
Feb 16, 2011 | Washing Machines
Washer is not spinning fast - so the clothes are more wet when done
sounds like washer is load sensing either overloaded or unbalanced when it decides to low spin insteasd of high spin dose it stop for second rotate 3 times and change direction 3 times the just spin slow.... if so either u have misloaded the machine by overloading orthe clothes are unbalanced in load may need add a towel or something to balance the weight evenly in the tub
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Maytag neptune error code lr
i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
Feb 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
My front loading washer (ewf272el) spins violently during the spin cycle _ I am not overloading it.
When the wild spinning is not caused by unbalanced/overloaded (wet) clothes in side, the first thing to check is that the washer is propery leveled, with all 4 feet on the ground.
If that is not the problem, on a front loading washer, the next most common problem is failed bearings that turn the whole inside basket.
Please report back what you find, OK?
Aug 05, 2009 | EuroTech Washing Machines
Door will not unlock, cycle did not finish.
Unplug the power cord let it reset..It should unlock
May 21, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Whirpool Duet "walking"
Hi, most of the time this can be a simple as a overload that will dramatically shake this type of washer. due to its front load design, it is recommeded to load accordingly to specs. overloading this type of washer will induce walking/excessive vibration during the spin cycle.
Mar 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer will drain but will not reach full spin in spin only mode
they dont spin full speed if they are overloaded, try it with less clothes.
Feb 11, 2009 | Frigidaire Affinity ATF7000ES Front Load...
It appears your clutch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 18, 2009 | Washing Machines
LG 1285
Lg washers used to carry a 3 year warranty.check warranty as requires a new stator.
Jan 05, 2007 | LG WD-1280FHD Front Load Washer
Kenmore 15864/15862 Top Load Washer Logo
53 people viewed this question
Sal De
fordexpert
Robert Rankin
