My screen on my toshiba satellite has cracked..so i hooked it up to an external monitor..so will my laptop still operate if i completely remove the lid and screen
    Problem Solver:
  • 9 Answers
Yes it will. One of my friends has done that. Just be very cautious Hope this helps. Get back in touch. Steven :D
Posted on Jan 01, 2013
  • valerie church Jan 01, 2013
    thank you very much steven...could you possibly tell me how to go about taking it off
  • Steven Dodd
    Steven Dodd Jan 01, 2013
    Personally, I don't know, but I found a tutorial for you.http://www.youtube.com/watch?v=Hibkoah0q... Good luck! Steven :D
3 Suggested Answers
paul7of9
  • 1189 Answers
SOURCE: Toshiba Satellite M300 screen problem
Hi, I can't guaranty this will help the problem, but for a quick try I say its worth it. On the Desktop, right click to open Personalize, select Display Settings; by adjusting the resolution it helps with the "Flicker effect" aswell, by selecting different settings, you can "view" the best Monitor Display. "If the solution helped, rating it is appreciated, thanks."
Posted on Mar 28, 2010
  • 47 Answers
SOURCE: HP G60-235DX--LCD screen cracked
yes, there is a way, it is detailed in the HP Service Manual found online
http://h10032.www1.hp.com/ctg/Manual/c01602064.pdf
start at page 63 of the pdf (refered to as section 4-24 in the manual text) and go from there!
Let me know if you have any questions.
Thanks,
Mike
Posted on May 17, 2010
How do i repair toshiba satellite a105 ribbon cable repair
Have you tried hooking up an external monitor to it and seeing if it works? I would try that first to rule out a video card issue. If the external monitor works fine, here is a website with pictures on how to disassemble the laptop to replace the screen:
Toshiba Satellite A105 Laptop Disassembly Guide Cooling Fan Heatsink...
Jul 23, 2014 | Toshiba Computers & Internet
My Toshiba satellite M35X-S149 shows the lights and can hear it running but there is no display on the computer monitor
Hi oysertails...
Try hooking your laptop up to an external monitor...if you can see the picture on the external monitor then your lcd screen may need replacement or the lcd inverter board.
Please take time to rate me
Sep 24, 2011 | Toshiba Satellite M35X-S149 Notebook
My screen has horizontal lines across half of the screen. I hooked up to a external monitor and it worked fine. What is the problem?
It would physically be in the LCD screen of your computer. If the monitor is working fine therefore there is nothing wrong with the video processing output or the drivers in the operating system. It would be in internal crack on the LCD or a loose connection with the LCD screen and the motherboard.
Its best to have your laptop checked by a service technician and dont just disassemble it by yourself to prevent accidents. Worst case is that the LCD needs to be replaced if really found cracked/defective.
Hope this helps.
Jul 08, 2010 | Toshiba Satellite A105-S4004 Notebook
Toshiba screen is blank ans light on under F10 key.
Is the screen completely blank, or just dim? If it is dim, then most likely your lcd power inverter is bad, and needs to be replaced, which is the cheapest part to replace. If it is completely blank then you should try to hook up an external monitor to the laptop, and don't get any video, then most likely there is an issue with your motherboard or video card. The external monitor method sometimes needs you to press a combination of the Fn key and another F key in order to switch from your laptop lcd to an external monitor.
Feb 06, 2010 | Toshiba Satellite A105 Notebook
I have a toshiba satellite laptop the screen is black
Shutting the computer down could be done by holding the Power Switch down for 10 seconds, rather than unplug/no battery "solution". A blank screen is more often than not caused by the failure of the screen's backlight. Plugging an external monitor in the ext monitor port would verify the computer still works, and I am sure it does.
Oct 10, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite P105 S6147 screen won't illuminate when on?
first try the fn+lcd/crt and see if it toggles on.if not then try hooking it to an external monitor. if you get the pic on the external monitor then you have a backlight or inverter problem.
Jul 27, 2009 | Toshiba Satellite A105 Notebook
Laptop to external monitor problems
Right click anywhere on Desktop> Properties>Settings> Try to lower Screen resolution.
Mar 18, 2009 | Toshiba Satellite A135-S4527 Notebook
Data Shows up only on External Monitor, not on Laptop Screen
If your system won't display anything w/o the external monitor. there's something wrong with the LCD's backlight. you may have to contact your laptop's manufacturer and check if this laptop is still under warranty. you may have to get the lcd replaced.
thanks.
Aug 26, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba laptop cracked screen
you can use external monitor, but best option is to replace the cracked screen. Take a tour of toshiba service centre.
Thanks and Good Luck
Iqbal
Jun 26, 2008 | Toshiba Satellite L25-S119 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
