Question about Canon PowerShot S80 Digital Camera
Taking a smaller image from S80
How do I reduce the size of the image of the picture I'm taking?
In picture-taking mode, hit the Func Set button. You will see menus of options along the left side and bottom of the display. Tap the bottom of the scroll ring (the ring around the Func Set button) until the bottom option of the left menu is highlighted in red. This option sets the image size of the pictures you are taking. Change this size by rotating the scroll wheel. The 5 options are Large, Medium1, Medium2, Medium3, and Small. The image size in pixels is displayed above the bottom menu as you switch between sizes. When finished, hit Func Set again.
Posted on Jul 27, 2007
SOURCE:
How to reduce picture size?
Not sure what you mean - if you wish to produce images taking up less storage, then reduce the resolution; if you wish to reduce the size of printed images, use image-editing software on your computer.
May 04, 2016 | Cameras
What is the difference in the optical and digital zoom?
Find the difference below
Digital Zoom
1. Digital zoom is a part of digital cameras, and camcorders, which helps to crop the entire image, and then digitally enlarge the size of the viewfinder of the portion that is needed to zoom in on
2. Digital zoom crops the image down to a centred area with the same ratio as the original, and also interpolating the result back up to the pixel dimensions of the original. this method involves cropping, hence the resolution and quality is reduced
3. Digital zoom, crops a portion of the image and then enlarges it back to size. And due to this, image quality is reduced in comparison with the original one.
4. Using the digital zoom allows the user to get closer to the subject when the photographer wants to be discreet about taking pictures, like taking a picture of a person in a graduation ceremony.
Optical Zoom
1. While taking a picture using a Camera to want to get a close shot of the subject without moving physically closer, photographers use the optical zoom.
2. The optical zoom ratio of a digital camera measures how much the lens can actually zoom in to make subjects appear closer. Optical zoom, enlarges a picture while keeping the resolution and sharpness of the picture high.
3. There is no relation between optical zoom and the resolution of the photo, as optical zoom only enlarges the whole image or the subject to a certain range. So image quality only depends upon the mega pixel (MP) of the camera
4. Optical zoom is very useful, while taking a picture of a landscape, or to get a closer view of a subject, without reducing the quality of the entire image, like taking a picture of a Rainbow in the sky.
Regards,
Ron
// Rate the solution with 4 thumbs up if the answer is satisfactory
Jul 01, 2011 | Nikon Cameras
I have my S610 set to take photos @ 5MB. But when I download them to Picassa, they are ~1.2 MB. Is this a camera setting or Picassa?
Neither. The camera is taking pictures at 5 megapixels resolution. The file size of the image is only loosely related to the resolution. You'll note that your pictures are all different sizes. The size is dependent on the content of the picture. If you take a picture of a blank wall or a plain blue sky, the file size will be smaller than the file size of a picture of a cluttered scene, because it takes more bytes to record detail.
If you look at your pictures in your image viewer, you'll see that the pictures are all the same dimension (width and height), regardless of the file size.
May 15, 2011 | Cameras
Hi, I have Sony Cybershot DSC w320 digital camera of 14.1 MP. Can you please tell me how I can take the pictures on less Mega Pixcal so that the size of file get reduced. Thanks, Prateek
The image size determines the size of the image file that is recorded when you take an image. The larger the image size, the more detail will be reproduced when the image is printed on large format paper. The smaller the image size, the more images can be recorded. To change the Image Size in the Camera, press and select the MENU-->Image Size-->Desired Size [(640×480)VGA or (2592×1944)5M] The quality of the VGA Image is very less when compared to the 14M.
Good Luck
Nov 09, 2010 | Cameras
I have a nikon d40 that works great ewxcept for one day i was taking pictures and all of a sudden the camera would not take a picture in auto or manual and theres a warning sign flashing "r11" where the...
Slow down your shooting. The "R11" indicates that you can take 11 more images before the buffer is full and the camera will stop functioning until the images are moved to the memory card.
Select a smaller file size. Nikon cameras allow you to select from several sizes of JPEG as well as a RAW and a RAW + JPEG file. These files vary in size. If you select a smaller file size, the buffer will take longer to fill, allowing you to shoot longerTurn off long exposure noise reduction. This function causes the camera to expose twice for every image, and this can fill up the buffer quickly as those images are processed and written to the card.
  • Step 3 Select a smaller file size. Nikon cameras allow you to select from several sizes of JPEG as well as a RAW and a RAW + JPEG file. These files vary in size. If you select a smaller file size, the buffer will take longer to fill, allowing you to shoot longer.
  • Step 4 Turn off long exposure noise reduction. This function causes the camera to expose twice for every image, and this can fill up the buffer quickly as those images are processed and written to the card.
  • Read more: How to Fix the R11 Error on a Nikon D40x Digital Camera | eHow.com http://www.ehow.com/how_6327343_fix-nikon-d40x-digital-camera.html#ixzz0wC3WxqrT
    Aug 10, 2010 | Nikon D40x Digital Camera
    How can I increase the total number of pictures to
    Purchase at least one xD-Picture card up to 2GB in size. Or you can use microSD and microSDHC cards using the supplied adapter.
    The number of pictures you can store depends on the size of the card, image resolution, and other factors. Obviously, with more cards you can take more pictures.
    Mar 19, 2010 | Olympus Stylus 7010 Digital Camera
    Changing the size of pixs for posting online or otherwise!~
    wen eva u want to change the size of the picture...try reducing the pixels of the picture or the resolution....eg.in photoshop..after opening the picture in it go to Image on top bar and then go to image size and u can reduce the pixels ....mostly pics of 3.2 mb will have morethasn 1000 * 1000 pixels try reducin it to 480 x 820
    Sep 11, 2009 | Cameras
    Want to make pictures on my dslr-a2oo camera smaller to upload them to my computer
    You will be guided by the instruction above. Let me know if this works. Usually you should set that to S2:1M.
    Aug 28, 2009 | Sony Alpha DSLR-A200K Digital Camera
    Reduce photo size
    If you want to take lower resolution photos, it's pretty simple.
    Go into the Menu on your camera, and look for "Quality".
    Canon does "Large" "Medium" or "Small", if you change to "Small", you'll fit more images on your memory card.
    However, "small" will make the photos not look as good as "large", keep that in mind.
    Mar 17, 2009 | Canon PowerShot A650 IS Digital Camera
    Sony Super Steady shot DSC-H2 image size
    while in camera mode, press menu, there is option for picture quality, email size is there.
    Aug 25, 2008 | Cameras
    Canon PowerShot S80 Digital Camera Logo
    66 people viewed this question
    Top Canon Cameras Experts
    old marine
    old marine
    Doberman
    Ekse
    Are you a Canon Camera Expert? Answer questions, earn points and help others
