Question about Sony SRS-D21 Computer Speakers
4 pin plug broken
Sub woofer connector broken to table speakers (for A computor)
4 pin connector need wiring diagram to resolder wires earth,red,grey, grreen blue
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
likwidstate
  • 17 Answers
SOURCE: Logitech x-230 speaker system
Ironically enough, I went on here because I have the satellites but no subwoofer! LOL, what are the odds. Anyways, if you happen to receive this information, can you please email me at ben.petrofsky@live.com?
Like I said, I'm searching for the same exact information for a similar problem and this would REALLY help as I can't power the speakers without this.
Posted on Sep 02, 2009
  • 17 Answers
SOURCE: No sound coming out of my sub woofer, power is ok
That blue wire needs to be connected to both the receiver and the amp. It is what tells the amp to turn on when you turn the receiver on.
Posted on Mar 14, 2010
  • 1768 Answers
SOURCE: X-220 cable is slightly damaged
nothing is wrong with the woofer the connect is broken at the strain relief and the cable needs to be replaced.
You can replace the connector if you know the pinouts. You will need the connector and the schematic.
you may be able to find the pin outs configuration here.
http://pinouts.ru/
As for the connector this may take a search online.
Posted on Aug 07, 2010
bronk50
  • 27725 Answers
SOURCE: The speaker plug at the
here are 2 links to some photos be very careful if you are soldering any power connectors any join of solder creates a link to power so if you get it wrong it might short circuit remember you must have both ends to be soldered clean usually the solder will have the flux built in although you might buy some soldering flux before you start you must warm up the ends with a soldering iron and tin them this will enable the solder to flow on and join correctly
http://mightyohm.com/files/soldercomic/FullSolderComic_images_20110409.zip
http://mightyohm.com/files/soldercomic/FullSolderComic.zip
hope this helps
Posted on Apr 22, 2011
Ive got these speakers and a real high pitch noice just started coming out of them
hello, This can due to loose connection in the stereo cable (broken wire). and also do you have earth wired to the system or the output device? This is how to check a broken wire, just simply remove the stereo jack coming from you device or PC. make sure you remove both ends, see whether the sound is gone. if you don't have a earth wired, please use a proper three pin plug. if this doesn't work, you have problem with the sound amplifier inside the sub-woofer.. you need a repair :(
Feb 16, 2011 | Altec Lansing ADA995 Speaker
I have a set of Harmon Kardan Soundsticks II needing a simple but confounding repair. One of the small pins (#5 I would say as you go over and around the arc of pins) of the satellite speaker connectors...
MiniDIN-4 Connector Pinout. Looking at the male connector from the rear (solder side) Pin 1 = White Pin 2 = Bare Wire Pin 3 = Light Grey Pin 4 = Dark Grey Outer case Ground = Clear
Jan 02, 2011 | Harman Kardon SoundSticks II Computer...
Pioneer DEH-P6350 wiring diagram needed
If it is not the standard colour scheme then you should just google it..
Standard colours Red: ignition Yellow: power Black: earth Blue: Antenna control White and grey: front left and front right (black striped ones are negative) Green and purple: rear left and rear right (black striped ones are negative) RCA plugs are for sub-woofer (either on a cable coming out of the back of the head unit or there will be sockets labeled low out(or similar)) And of course the antenna cable
Dec 26, 2010 | Car Audio & Video
I was given a Sharp HT-DP3000 reciever and all the speakers that go with it.. but I don't know how plug in the speakers into the wire there is a box for the two surround and a separate box for the right...
Do you have speaker wire if not you will need some, the wire is cheap about $5 bucks a roll your local department store will have it. You see a red and black tabs on the back of the unit and on the back of each speakers you push down and stick one wire in the hole. red will be your + and black will be - The two surround go on the back wall behind your seat.The center will sit on top of TV and the sattalite speakes go beside the left and right side of TV. and the sub sits on the floor in hidding behind something or under a table. (P.S, Make sure the wire is shaved about 1/4 of inch before you stick in the wire DO NOT plug the power cord in, intill you hook up all the speakers this could damage the unit. You do not need a sub woofer, if you have one great If not don't worry that will not damage the unit it has a internal switch to turn on/off the sub woofer The sub woofer offers extra deep bass that you can't get from the sattalite speakers.)
Aug 31, 2009 | Sharp HT-DP3000 System
Need wiring diagram for Sony XM-E70 Equalizer/Amp
You need 1 thick ground cable ( usually brown)
you need 1 thick power cable ( same thickness and wire as ground usually red )
you should have 1 rem wire ( thin blue )
RCAs, 2 for sub, extra 2 for 2 speakers.
The rest I have no idea what they are.
You need speaker cables to sub or amp.
Some products use different colouring. Maybe the 9 pin connector is for head deck to speakers.
Jun 30, 2009 | Sony XM-SD61X Car Audio Amplifier
Fitting a towbar for a caravan with 13pin europlug
black socket, black 7 core wire
pin 1 yellow left indicator
pin 2 blue, rear fog light
pin 3 white earth
pin 4 green right indicator
pin 5 brown right side/tail light
pin 6 red brake lights
pin 7 black left side/tail light
Grey socket grey 7 core wiring
pin 1 yellow, reverse
pin 2 blue, supplementary feed (ignition)
pin 3 white, earth
pin 4 green live feed (battery +)
pin 5 brown not connected
pin 6 red supplementary feed (ignition)
Pin 7 black earth
On the discovery there is a purpose made plug behind the panel on the drivers side rear, behind the rear lamp
i think the relay you have bought is for lamp failure you just need a normal 4 pin 30 amp relay.
Good luck Davelee
Mar 19, 2009 | 1997 Land Rover Discovery
Need wire diagram 4 altec lansing acs295 4 red connctor
I have the same speaker set. maybe we can help each other. My plugs are all fine but my sub is not connected to anything at all and I need to know were they must go on the pc board. Maybe we can trade some photos on the wiring diagram?
Mar 14, 2009 | Altec Lansing ACS 295 Computer Speakers
Sub woofer speaker wire
Probably an RCA Pin plug
Jan 02, 2009 | JVC RX-552V Receiver
Need wiring and 9pin connector diagram
Pin 8 = Power A
Pin 9 = Power B
Cheers!
Mar 27, 2008 | Altec Lansing ADA425 3-piece 30-watt...
Wiring diagram for Altec Lansing Vs4221 Right Speaker Wire
red-positive . blue-negative and if another colour mostly brown-Earth.
Jan 15, 2008 | Altec Lansing VS4121 2.1 Channel Powered...
Sony SRS-D21 Computer Speakers Logo
237 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
