Question about Sylvania 1997-1999 Mercedes Benz S420 Headlight Bulb, 97-99 HID-D2R
Power windows seats indicators and wipers on 97 s420 not working
    Genius:
  • 1,669 Answers
Go to the fuse box under the dashboard and chech the fuses that supply those functions.
Posted on Jan 01, 2013
Why are both the front and back window wipers not working in my 2007 Ford Escape? along with the passenger side charger port?
I show the power point (charger port?) getting 12 volts through 20A FUSE 17 (which you indicate is OK) in the battery junction box.
The front wipers get power through 20A FUSE 25 in the smart junction box (which you indicate is OK) so that leaves the wiper/washer switch as suspect.
The rear wiper gets power through 10A FUSE 21 in the smart junction box (which you indicate is OK) so that leaves the rear wiper relay or wiper/washer switch as suspect.
Mar 29, 2018 | Ford Escape Cars & Trucks
I have a 2005 Buick Terraza. When I put in gear and drive it starts dinging and indicates that a side door is not closed. They are and I have cleaned the contact plate.
This warning indicator is controlled by the BCM - body control module . You cant turn it off , you need to fix the faulty input switch that signals the BCM that the door is open .
Body Control Module
The various body control module (BCM) input and output circuits are described in the corresponding functional areas indicated on the BCM electrical schematics. The BCM functions include the following:
• Battery rundown protection--Inadvertent power--Refer to Interior Lighting Systems Description and Operation in Lighting Systems.
• BTSI/automatic transmission shift lock control--Refer to Automatic Transmission Shift Lock Control Description and Operation in Automatic Transaxle - 4T65-E.
• Bulb check--Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
• Chimes--Refer to Audible Warnings Description and Operation in Instrument Panel, Gages, and Console.
- Check gages
- Content theft deterrent
- Door ajar warning
- Headlamps ON
- Key-in-ignition
- Oil reset
- Park brake warning
- Seat belt not fastened
- Turn signal ON
- Vehicle theft deterrent
• Door lock interface--Refer to Power Door Locks Description and Operation in Doors.
• Exterior and interior lighting control--Refer to Exterior Lighting Systems Description and Operation in Lighting Systems.
- Automatic lighting control
- Backup lamps
- Daytime running lights (DRL)
- Fog lamps
- High/low beam head lamps
- Park brake lights
- Turn hazard lamps
• Gage control--Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
• Heated seats--Refer to Heated Seats Description and Operation in Seats.
• Horn interface--Refer to Horns System Description and Operation in Horns.
• Instrument cluster indicator control--Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
• Interior lighting--Refer to Interior Lighting Systems Description and Operation in Lighting Systems.
• Key-in-ignition sensing--Refer to Audible Warnings Description and Operation in Instrument Panel, Gages, and Console.
• Parking brake state sensing--Refer to Brake Warning System Description and Operation in Hydraulic Brakes.
• Retained accessory power (RAP)--Refer to Retained Accessory Power (RAP) Description and Operation in Retained Accessory Power.
• Rear compartment interface--Refer to Power Door Locks Description and Operation in Doors.
• Rear defogger--Refer to Rear Window Defogger Description and Operation in Stationary Windows.
• Remote function control--Refer to Keyless Entry System Description and Operation in Keyless Entry.
• RFA communication link--Refer to Keyless Entry System Description and Operation in Keyless Entry.
• Seat belt use sensing--Refer to Seat Belt System Description and Operation in Seat Belts.
• Theft deterrent vehicle/content--Refer to Theft Systems Description and Operation in Theft Deterrent.
• Washer solvent level sensing--Refer to Wiper/Washer System Description and Operation in Wipers/Washer Systems.
• Wiper/washer--Refer to Wiper/Washer System Description and Operation in Wipers/Washer Systems.
As far as the sliding doors , pull the fuse's
Jan 12, 2018 | Buick Cars & Trucks
97 jeep cj windows and wipers stopped working fuses are ok
97 wrangler right? CJ ended in 86 (last year)
97 TJ, you mean, or was posting to Cherokee correct all along./?????
factoid:
The Chrysler Corporation bought out AMC in 1987, shortly after the Jeep CJ was replaced with the AMC-designed Jeep Wrangler or YJ.
test the fuse, looking only finds the ones blow to H3LL
they can in fact just crack a bit. and are in fact bad.
use any DMM or any ohmmeter, "resistance Rx1 or RX2 range , low range) 0 ohms good, , infinity bad.
only that works. every time.
lets read the FSM together.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
wipers first. USA not export.
Front wiper not rear. ok>?
page 8w-53 wiper schematic.
fuse 2 and 3 must be good.
then fuse 14 front wiper ,fuse 12 is rear
if the fuses are good, (truely) we never ohm fuses we use VOLTS
on both sides of fuse, volts never lies.
then what is bad, easy bad wiper switch, motor or ground to motor.
the voltmeter again wins the toss and if no 12vdc to motor
then the switch or wire are bad.
if you have 12v to motor then motor is bad , if ground to motor is no cut.
now windows. what windows, are then not crank windows or zipper windows?
i think you posted wrong car,,
Mar 20, 2014 | 1997 Jeep Cherokee Country
Radio, power windows, windshield wipers and turn signals are not working in my 1996 Mercedes S320
the wipers and turn signals are probably a faulty switch (a common problem 0 I have a 1994 c180 and have had 2 switches on they vary from the flashers not working or wipers coming on by them selves or not working at all indicators not working can but from ebay for about 30 pounds hope this helps ivan
Mar 20, 2013 | Mercedes-Benz S-Class Cars & Trucks
I have a 1993 VW Passat VR6, My problem is when I try to start it, I have no spark from the spark plugs..What could be the problem or how do I fix this?????
GO TO THIS SiTE TO CHECK THE FUSE BOX!
http://vwtech.no-ip.info/images/golf/post90.gif
This are the FUSE and RELAY number SLOT!
Fuse No. Description Ampere Rating 1 Headlight, low beam, left 10 2 Headlight, low beam, right 10 3 Instrument panel lights, license plate lights 10 4 Glove compartment light 15 5 Wiper/washer 15 6 Fresh air blower 16-valve only: Air conditioning 20 7 Taillights, side marker light, right 10 8 Taillights, side marker light, left 0 9 Rear window defogger 20 10 2.0 16-valve only: Fog lights 15 11 Headlight, high beam, left,High beam indicator light 10 12 Headlight, high beam, right 10 13 Horn 16-valve only: Radiator cooling fan 10 14 Back-up lights, washer nozzle heaters 10 15 2.0 16-valve only: Engine electronics, stabilizer valve, cold start valve 10 16 Instrument panel warning lights, 16-valve only: Multi function indicator 15 17 Emergency flasher switch, turn signals 10 18 Fuel pump, oxygen sensor heater 20 19 Radiator cooling fan, air conditioning 30 20 Brake lights, cruise control 10 21 Interior lights, digital clock 16-valve only: Luggage compartment light,multi function indicator, central locking 15 22 Radio, cigarette lighter 10
Relays Relay No. Description 1 Air conditioning 2 Open 3 Digifant control unit 4 Load reduction relay 5 Low coolant level control unit or Open 6 Emergency flashers 7 Rear Wiper 8 Intermittent wipers 9 Seat belt warning system control unit (possibly headlight warning too?) 10 Fog lights 11 Horn 12 Fuel pump (except diesel)Glow plugs (diesel) 13 Radiator cooling fan after run (except 16-valve)2.0 16-valve: Starter interlock relay 14 Automatic trans., coolant temperature indicator,starter interlock relay (except 2.0 16-valve)2.0 16-valve: Radiator cooling fan after run 15 ABS pump relay 16 ABS relay 17 Heated seat control unit, driver 18 Heated seat control unit, passenger, or power seat circuit breaker 19 Automatic transmission 20 Open 21 Power window relay, ABS hydraulic pump fuse 22 ABS valves fuse 23 Air conditioning, power seat fuse 24 Power window fuse
Nov 17, 2010 | 1993 Volkswagen Passat
Windows dnt work on my mercedez s420... fuses are
Spin the barrel fuses as corrosion can stop them from working.
Apr 22, 2010 | 1995 Mercedes-Benz S-Class
1998 E230. power seats,central locking,power windows, turn signals, wipers, power mirrors all stopped working
hello,check your fuse number 4 ,15 for signal light ,check also the rear fuse box for power window,central lock,power seat ,located at rear seat in front of battery,ty
May 01, 2009 | 1999 Mercedes-Benz E-Class
The power seats, power rear shade and power mirrors are not working in my 1997 Mercedes S320
i have same problem on 1997 s420, don't know why it is happening. but you can replace cigar lighter fuse then replace seat/mirrors/steering wheel fuse and all is well. thnx
Apr 14, 2009 | 1995 Mercedes-Benz S-Class
BMW 740IL Wiper Issue
try checking for a short to power on ur 12 volt comming into motor also check for a good ground at the plug for ur wiper motor
Jun 16, 2008 | BMW 750 Cars & Trucks
Sylvania 1997-1999 Mercedes Benz S420 Headlight Bulb, 97-99 HID-D2R Logo
77 people viewed this question
Top Sylvania Optics Experts
jdtech
Andrew Taylor
Andrew Taylor
Are you a Sylvania Optic Expert? Answer questions, earn points and help others
