Question about Myron & Davis AD212
Sound works thru the wireless headphones, but not thru speakers?
Sound works thru headphones but not thru speakers... Is there a station i need to be on? I have flipped the toggle switch to listen thru thr truck speakers.....
  • brisdad27 Jan 18, 2009
    Is there a station i have to have the radio on to hear it? THe speaker connections are good.... I talked to the guy who i bought the truck from and he said that i have to have the radio on a certain station. There is a toggle switch that needs to be on when wanting to hear the sound thru the truck speakers.
    Scholar:
  • 67 Answers
Go over all speaker connections and ensure they are good and also plugged in to the head unit and that the wires didn't fall out during install.
Posted on Jan 18, 2009
There is no bluetooth listed under my devices on my new Vizio D43-D1 tv. Can I connect it to Bluetooth speaker?
Unfortunately, you can't connect Bluetooth speakers to this TV. You can connect a wired sound bar, home theater sound system (receiver and speakers) or wireless headphones with a wired based station (RCA or digital audio input from the TV's audio out). These wireless systems use RF or Bluetooth signals to the headphones. See this page, http://stereodevelopment.com/#what-are-wireless-tv-headphones , for a few models of wireless headphones that will be compatible with the D43-D1.
I wish that I had better news for you. You may be able to find an audio receiver that supports Bluetooth. However, these usually are Bluetooth devices, the same as the Bluetooth headphones. They can't pair and send a signal to your headphones.
Feb 28, 2017 | Vizio Audio Players & Recorders
Headphone problem
Ensure you are not plugging into the microphone input.
Dec 17, 2015 | Computers & Internet
The speakers no long produce sound after using the headphone jack,,disconnected jack , still no sound
When you plug in the headphones, the jack itself routes the signal away from the speakers. When you unplug the headphones, the jack has contacts that close again, routing signal to the speakers. If the jack contacts are dirty, they won't close correctly. I suspect were you to clean the contacts, you'd solve the problem.
Feb 25, 2015 | RCA Rt2760 Home Theater Receiver
What does the orange light mean on your sony pulse headset? And why doesent make noises when its turend on?
check the cables to the base-transmitter station. If they are firmly connected or try to replace them. Most of the wireless headphones of some more advanced design detects incoming signal and switches to mode on wich indicates with another color when the sound dissapears the headphones detects no sound and goes into a powersaving mode. Usually the headphone itself doesn't fault very often, cause they are battery powered and the powersupply isn't wavering like the powertransformer to the base-station due to the irregular power from the ac outlets, wich is why any electronics should be connected to a surgearrester list.
Another thing to check for is there any sound coming from the tv/game connector, try to connect a nother speaker assembly or headphone or if the connector is of a low signal type, a amplifier with speakers or headphone make sure you don't have to much between where the sound comes from and the headphones. Let me know if some of my advice helps you!
Jan 25, 2013 | Radio Communications
No output to speekers Sony STR-DE825
Check that the mute is not on.If a headphone is plugged into the receiver the speakers will be muted.Verify the the output selector is set to the correct source.Here is a simple check.Select a strong FM radio station.Plug in a headphone.If you are receiving an audio thru the headset.Then disconnect the headset and see if the audio is transmitted to the speakers.If you still have no speaker sound check to see if the speakers have fuses which may be blown.I would try another set of speakers to determine if it's the amplifer or the speakers.The amplifer has fuses as well. Wiilbe inside if not at the rear
Oct 21, 2012 | Sony STR-DE825 Receiver
Speaker connections
if there isnt a jack connection you would have to use a set of usb speakers
Dec 10, 2009 | Acer Aspire One PC Notebook
2005 dodge caravan, factory dvd... no sound through speakers
My grandcarvan sxt came with a remote for the DVD system and wireless headphones from KOSS. You have to press the headphone button on the remote to change it to headphones otherwise it comes through the main system. With the button pressed we can listen to cd or radio in front while they wear the headphones in back. You might need the remote to change it back to main system. The headphones from Koss are lifetime guaranty and not too expensive.
Dec 06, 2009 | 2005 Dodge Grand Caravan
Can 2.1 pc speakers work thru headphone jacks?
No it's not possible to have a sound. Because the HDMI and the Headphone (3.5mm jack) are on two different technologies.
The monitor does not have a way to convert the sound from HDMI to Headphone.
There could be a converter that might convert the sound signal from HDMI to headphone (but I'm not sure).
Aug 30, 2009 | Logitech X-540 Computer Speakers
Compaq CQ60 104TU
Kind of confused with the question.
I would suggest you look at the line out and make sure that is not muted withing the sound settings.
Sometimes that happens.
If you are using the headphone part and you plug in the headphones it should turn off the computer speakers and goto the headphones.
If not then there is a different issue.
Happy Holidays
Dec 19, 2008 | Compaq Presario Notebook
ThinkPad R40 with no sound
have you tried going into your master volume contro properties and turned everything up there. If you double click on your volume control near the time and go to properties you'll find all the controls there. Let me know if that works for you.
Dec 11, 2007 | Lenovo ThinkPad R60 with Wireless Wide...
Myron & Davis AD212 Logo
663 people viewed this question
Top Myron & Davis Televison & Video Experts
Electro Med Services...
Are you a Myron & Davis Televison and Video Expert? Answer questions, earn points and help others
