Question about Brother Sewing Machines
How to i fix needle threader on brother sa 400
Embrodery machine is less than year old and needle threader stopped working this feature is very imp. having to change colors so often
SOURCE: Brother SE 270D Cassette threader
I too have a christmas gift causing headaches - loopy embroidery. But at least this one I found a work around for... I thread the cassette according to the arrows but when I get to "6" I loop up around the left side and over the top of the bend but DON'T go far enough to cut the thread. I leave about 4 or 5 inches loose and hold the end at the top-right of the thread cassette at about the 2 o'clock position. I push the cassette down into the machine normally and right about when the 6 is below the window the thread will cut leaving you holding the left over piece. Continue pushing down until click and needle will thread. Have not had any threading problems since learning to leave a tail on the thread. Hope this helps.
Posted on Jan 25, 2008
bargainbox
  • 1388 Answers
SOURCE: Needle Threader is not lined up
This is called the Needle Threader Plate.
If this is too small for you to read, or you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Feb 24, 2008
  • 8 Answers
SOURCE: the needle threader has stopped working
Check you needle size. On my machine the needle threader does not work with the smaller needles, 9/65 and 11/75. The eye of the needle appears to be just short of the hook on the needle threader. I have no problems threading needles in larger sizes.
Good luck,
SewReady
Posted on Nov 12, 2008
talk2ginny
  • 34 Answers
SOURCE: automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Posted on Jan 31, 2009
talk2ginny
  • 34 Answers
SOURCE: Broken needle threader?
Hi - welcome to FixYa. I have this machine, and unfortunately, the cassettes can break. If the threader worked when you first got your machine, I would suggest buying a new cassette (even if your threader is working). A second cassette is very handy because you can thread your next color in the extra cassette before the machine stops for the next color change - when the machine does stop, just put in the second cassette, and thread the other with the next color - speeds things up alot. And, if one of the cassettes does break, you aren't sitting in a puddle waiting for a new one.. You can find the thread cassettes for sale on a variety of sites - this is where I buy mine:
http://webstore.quiltropolis.net/stores_app/Browse_dept_items.asp?Store_id=492&page_id=17
Some of the 270Ds came with a spool pin - look in your manual for a picture and for the instructions for installing and using the spool pin. You can use it for spool of thread that are too large for the cassette and I think you can leave it installed on your machine all the time. If you don't have your manual, leave a comment and I'll look mine and check the instructions.
Hope this helps. If you have a minute, a rating (good or bad) tells me if the information or solution I provide is helpful to anyone who visits FixYa.
If you would like me to write a tip on salvaging an embroidery project that has been pulled into a birdsnest, leave a quick comment and I'll add the tip. Thanks everybody, and good luck. Please feel free to comment if you need more help or have more questions.
Posted on Feb 05, 2009
Brother Se 400 sewing machine
The needle threader is a very delicate item on the machine. What is your question? As always, please have a trained technician make the repair for you, they have access to any parts you may need and they can do it safely too!
Cheers,
Embroidery Services
San Diego, CA
Sep 09, 2017 | Brother Sewing Machines
Brother VQ 2400 can't get needle threader to work. Re-thread machine& changed needle still will not work
What happens when you try to use the threader? Does it miss the needle eye, does it not grab the thread, what?
Mar 20, 2017 | Brother Sewing Machines
Can the automatic threader be fixed can i do it myself?
Depends what is wrong with your needle threader. Needle threaders tend to be very fragile parts so it is not uncommon for them to stop working. You may be able to replace the part if it is broken but it may be a job trying to find the part. Search the internet for parts for the make & model of your machine. Once you get the part, search the internet (YouTube) for videos showing how to replace the part.
On the other hand, it is not a serious problem if the auto-needle threader does not work. These options were not available until the most recent sewing machines were manufactured and your machine will most likely operate for many years despite the broken needle threader. Manual threading was all that was available for over 100 years.
HINT: To help make needle threading easier, lick your forefinger then swipe the back of the needle's eye. The moisture in the eye will help pull the thread through.
Nov 11, 2015 | Sewing Machines
Automatic needle threader won't work on brother pe-770
Always make sure the hand wheel is at the exact top. Have you replaced the need recently? If it's bent, then the threader will not work. If the needle is loose or not all the way to the top in the holder, it will also cause the threader to not work.
Jan 06, 2013 | Brother PE770 Computerized Sewing Machine
I changed the needle on my new Brother HE 240 sewing machine and now the automatic threader won't work. Any ideas?
make sure the needle is inserted all the way into the needle holder
also make sure the needle is turned the right way in the needle
holder
Oct 31, 2012 | Brother Sewing Machines
AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
May 01, 2010 | Brother CS-8060 Computerized Sewing...
I have the Viking Emerald 118 model, less than a month old. I cannot get the button for setting whether the needle stops up or down to work. It worked fine the last time I used my machine. I also am having...
The large wheel on the side of the machine that pulls out to thread a bobbin is probably pulled out. Push it in and the rest of the features should work.
Jul 15, 2009 | Sewing Machines
Automatic needle threader on brother se-350
Good luck,
Ginny
Dec 21, 2008 | Brother XL-3500
Auto threader
The parts for any autothreader are necessarily delcate considering the nature of its task. Check (without thread) to make sure the tongue that passes through the eye of the needle isn't bent a tiny bit causing it to strike next to the ****. Have seen this more than once.
Sep 07, 2008 | Brother NX-400
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
