Question about Yamaha Audio Players & Recorders
Volume code for time warner remote yamaha v373
5 Suggested Answers
SOURCE: Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
time warner does not supply the codes. the equipment manufacturer supplies the code to the remote makers
Posted on Jun 04, 2009
smarthome2
  • 1114 Answers
SOURCE: Can't find Yamaha RX-V363 code for a Time Warner
http://www.yamaha.com/yamahavgn/Documents/YEC/AV_Receivers/Manual/RX-V363_U.pdf
Here's your manual. Hope this helps
Posted on Aug 14, 2009
SOURCE: Code for Time Warner Synergy V Model RT-U64CP remote
CODE 301 will turn off Yamaha but I don't have code to turn it back on.
Posted on Sep 13, 2009
issken
  • 1472 Answers
SOURCE: We have our Yamaha RX-V390 receiver hooked up to
denisegra727
I can see if I can find a proper code for your remote code for the volume but I need to know the make and model of your DVR.
Also note the volume control option may be old done to the DVR because the way it is configured. The one that I have for my DVR is the same way. The reason for this is at the time alot of the current DVRs out there were made this is how most of the customers wanted it. However now alot of the home systems have changed in the way they are setup. So you may have to go get a different remote if you want a true master remote.
But get me the make and model and I will see what I can come up with for you.
Issken
http://www.fixya.com/users/issken
Posted on Dec 28, 2010
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Tip
I need a config. my remote control UEI By DirecTV
<span>If you are using the universal remote control provided by directv, try these codes 10054, 10030, 10171 <br />OR:<br /><b>Satellite TV Systems</b> Dish Network Remote Codes 506 or 127 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 <b>Cable TV Systems</b> Cable Vision Remote Codes 506 Charter (Moxie Box) Remote Codes 1144 or 1178 Comcast Remote Codes 11144, 11240, 11331, 21075, 10159, 10154, or 10088 Cox (Remote Model UEI M720p01) Remote Codes 1610 Brighthouse (Remote "UEI" URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" UR5L-8500L) Remote Code 432 Time Warner (Atlas OCAP 5) Remote Code 1610 For the LTxxxxx series: You can use the codes listed under RCA, LG, Philips or Yamaha. <br />Thanks</span>
on May 07, 2011 | Televison & Video
Need manufacturer's setup code for Yamaha AV Receiver RX-V373
Using 1056B03 universal remote from Time Warner. Several codes actually will turn the unit off and allow volume control. Or..I can turn on and volume control. Can't do both. I tried to use the receiver codes in the vcr mode, but the remote rejects receiver codes (i.e. only accepts vcr codes).
It looks like one or the other, not both.
Jun 16, 2012 | Yamaha Audio Players & Recorders
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
Need remote code for yamaha yhts401bl receiver
The remote (most of them in fact) have only about 50 possible codes built into them. Either research for another remote or stick with the original one for the receiver--been there and done that myself.
Apr 29, 2012 | Yamaha YHTS401BL Virtual Surround Speaker...
I want to set the remote to change volume on TV,we can change the channels using the Time Warner remote but cannot change the volume using thesame remote, we have to change the volume on the Toshiba...
I am not familiar with the Time Warner remote, but Tivo remotes require pressing "tv power" and the "Tivo" button at the same time to program them.
Maybe you are pressing one a little ahead of the other.
Oct 18, 2009 | Toshiba 26 26AV502R 26 in. LCD HDTV
I just bought a 52 inch samsung my volume does not work on my cable remote.everything else works ok i have to use remote for the tv to adjust the volume. i have time warner
Did you try another time warner remote if yes then this is normal because if on/off works that means the volume function is not coded for the time warner remote because the set is to new.
Jun 09, 2009 | LG 42LC2D 42 in. LCD HDTV
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Dec 26, 2008 | Onkyo TX-SR573 Receiver
Time Warner Remote Code to work volume for Philips Home Theater
after much trial and error i found a code that partially works.... 3025
it controls volume, power, mute and the c button on the remote controls the genre of music. AND THATS ALL. no analog of songs no fwd or rwd, its better than nothing though
Dec 23, 2008 | Audio Players & Recorders
54 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
