Question about D-Link DIR601 WirelessN 150 Home Router and DLink DWA125 Wireless 150 USB Adapter Bundle
Signal strength excellent singnal quality out of range
Computer shows connected, signal strength is excellent but signal quality is shown as out of network range
  • 826 Answers
Reset your router...your signal quality will improve..
Posted on Jan 02, 2013
SOURCE: not connecting with router
netgear came as optus packege
Posted on Jun 13, 2008
  • 53 Answers
SOURCE: signal strength keeps varying
if you arent in a clear line of sight, many things can affect the signal strength of your network including the thickness of the walls, the composition of them and anything else that may be in the way. if you use a 2.4 ghz router and you have a 2.4ghz cordless house phone, they can interfere and cause issues. A microwave oven that is located between the router and a device can cause interference as well.
Posted on Jun 10, 2009
etaf
  • 779 Answers
SOURCE: Can't get online, even though computer says connected
As the router is working and connected to the internet - then its probably and issue with the wireless setup on router or your PC
1) remove any wireless profiles on your PC read here - how to do that http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm then when reconnect it will ask for the key again 2) A firewall maybe blocking your access - disable any firewalls 3) Remove the wireless security if enabled in the router and see if you can connect - if this is the only wireless device connecting - it may interference try also changing the wireless channel in the router - use 1 or 6 or 11
Posted on Mar 20, 2010
kookie78
  • 56 Answers
SOURCE: when i switch on my
Check your ip settings in your pc and make sure they are set to get dynamically. Also check under wireless lan settings that you have dynamic ip turned on.
Otherwise you will manually have to set your computer ip address to the range set in the router/modem
Posted on Oct 23, 2010
puertobori
  • 7733 Answers
SOURCE: i have strong signal strength
Reconfigure using this help D-Link - TechSupport FAQ
Posted on Oct 25, 2010
Signal quality issue
Check the cables and connectors. A bad connection, can cause intermittent signal loss.
Jul 27, 2014 | Panasonic VIERA TX-L32E5B 32" LED TV...
Ican not get signal from my roku
**You can skip this if your Roku player is wired to your router with an Ethernet cable.
If you are connected using wireless networking, check that the signal strength is at least "good".
To check your wireless signal:
1. From the Home screen, go to Settings>network and see what is displayed for "Signal strength"
2. If it is "good" or "excellent" you should be all set
3. If it is "fair" or "poor", follow the next steps
4. Move the placement of your Roku player and/or your wireless router to improve the signal quality
- The Roku player should not be recessed within a media cabinet, instead it should exposed in the open if possible
- Try changing the direction the Roku player faces, you may have to experiment with various spots for optimal signal
5. Run repeat guided setup and note the dark bands above your wireless router name. This gives a visual indication of the signal quality.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/wireless-router-support/
Dec 18, 2012 | Computers & Internet
Expand coverage range
Wireless Protocols A wireless router's range is determined by what 802.11 protocol is used, the overall strength of the router itself, and the nature of the obstructions and interference in the area.
The 802.11g protocol supports speeds up to 56Mbps. Its biggest drawback is that this protocol operates on the same band (2.4GHz) as many other devices, such as microwaves and cordless phones. Because of this, in all likelihood your wireless connection will be negatively impacted by interference from other devices.
The 802.11n protocol operates on the 5GHz band and is advertised to support speeds up to 300Mbps. Actual speeds, however, are much less. To take advantage of this protocol, all connected devices must be 802.11n compliant, and you should be aware that the 5GHz band, while allowing for less interference than the 2.4GHz band, will result in reduced signal range.
Wireless Signal Strength and Speed
Signal strength depends on the distance, the number of obstacles, and the type of obstacles your signal encounters. Signal strength stability is affected by physical changes in the environment, such as movement of the computer, people movement, and electrical devices. In fact, I completely lose my signal if I have my laptop in the kitchen when the microwave is running. Troubleshooting your wireless router can be very difficult because there are so many constantly changing variables that affect wireless signal quality. Consider the following to improve your wireless router signal and speed:
Position your router in a better location. Try to locate it in the center of the house. Elevate the router in the room and keep it away from other electronic devices and metal objects. Since cordless phones can adversely affect router performance, position the router as far away from phones as possible. The fewer obstacles in the way, the better chance your computer has of obtaining a quality signal.
Change the Wi-Fi Channel. Signal quality can be adversely affected if too many people use the same channel. See if switching channels makes any difference. You can use channels 1 through 11, but for best performance, use 1, 6, or 11.
Update firmware or drivers. Check your router's web site to ensure the latest firmware has been installed on the router. Also, make sure the latest driver has been installed. I noticed a slight increase in signal strength when I updated my driver.
Replace your antenna. Replacing your antenna with a high gain antenna may improve your signal quality. There was no noticeable improvement when I tried this option.
Replace your adapter. Check to make sure your computer's internal adapter isn't defective. If necessary, you can either replace the internal adapter or purchase an USB adapter, The USB adapter includes an external antenna.
Implement an additional access point or repeater. In theory, additional access points and repeaters will extend the distance of the signal. There are mixed reviews as to how effective these are, but they are worth a try if other options are unsuccessful.
There are several applications designed to monitor your wireless router performance. However, one way to obtain a rough estimate of your router's performance is to hold a laptop near the router. Access the wireless utility software on the laptop and note the readout, which should be excellent or close to 100%. Carry the laptop out of the room, noting any changes in signal strength. If the signal strength drops to poor or a very low percentage signal reading, then the router may be performing properly but obstacles, either structural or electrical, may be interfering with your router's broadcast signal. The results of your evaluations will help you determine if wireless signal quality issues exist in certain locations in your house.
What Worked for Me
There are several possible ways to improve wireless router signal quality in your home. Try the least expensive solutions first. Otherwise, you may be needlessly spending money for equipment that doesn't solve your specific issue. In my particular case, I was able to obtain some slight improvement by updating software and making some system improvements. Ultimately, I was able to get the signal strength and speed I wanted by using two routers on opposite ends of the house. My primary router, which is connected to the modem, is on the first floor. My secondary router is on the second floor and is connected to the primary router by an ethernet cable. This was the best and least expensive solution that provided me with very good coverage inside and outside my house.
*Although Belkin has discontinued the F5D8231-4 model, it is available from some online companies.
Nov 17, 2012 | TP-LINK TD-W8901G Router
No input 2 signal
The connections bad.... try rewiring the one for signal 2 or if its making a good connection... look for a weak spot in wire... that helped me when i couldn't figure out wiring
Aug 28, 2012 | Cars & Trucks
BlackBerry Curve 8520 signal swing
#1 Your BlackBerry does not have sufficient Power
Check the battery charge level as shown by the battery icon on the top left of the home screen. No Power - Battery Charge Indicator does not show a charge or is very weak. The battery icon may be red. Charge the battery.
#2 You are Out of Network coverage area
Check the Signal Strength Indicator on the home screen. (1 to 5 bars, as shown below, indicating signal strength). If there is no signal, you may be out of range of the network.
If you are sure you are in range of the network, but show no signal strength, press Alt-Right Shift-Del at the same time. This will cause the BlackBerry to reacquire a network connection.
The process for this procedure is:
  • Press Alt-Right Shift-Del (The Del key is also the Backspace key.)
  • The screen will go blank, and an hourglass will appear. Wait for the hourglass to go away.
  • The startup screen will appear. Wait for it to go away.
  • A screen that says Verifying Security Software will appear. Wait for it to go away.
  • Check the Radio Tower icon.
If you are in Coverage Area of your Service Provider, You will get the network.
#3 Your Data plan is switched Off.
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
When i switch on my ADSL modem which is connected thro the dlink wireless router,my laptop shows"No internet access" in the task bar,but the signal zebra-band is visible-excellent signal...
Oct 23, 2010 | D-Link Computers & Internet
Cannot access internet, Acer Aspire 5315
Try this. go to firewall. click on exception, and then click "secure socket tunneling" this should solve the problem. If it did not work the first time unclick it again. re start computer, and re do the exception thing.
Jul 01, 2009 | Acer Aspire 5315 Notebook
Wireless shows connection,but will not connect.
This kind of problem occur due to dhcp disable in the wireless router for the security purpose. So try to give the ip adress manually by right clicking on the wireless and give the ip adress of the same range in which your network in working e.g 192.168.1.0 is the range of your ip addresses so please select the ip which is not been used by any other computer and than in default gateway enter the ip address of you wireless router and you will be able to access the internet on your system.
Dec 01, 2008 | Linksys Wireless-G WRT54GS Router...
WIRELESS
So, what kind of wireless card or adapter on your computer/laptop?
May 10, 2008 | Dell Microsoft Windows XP Home Edition
D-Link DIR601 WirelessN 150 Home Router and DLink DWA125 Wireless 150 USB Adapter Bundle Logo
158 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
