Question about Kenmore 63942 Dryer
PF ON DISPLAY FOR A COUPLE OF SECONDS
I GET A PF ON THE DISPLAY FOR A COUPLE OF SECONDS. IF I UNPLUG IT FOR A DAY THE PF COMES UP AND I CAN GET IT TO RUN FOR ONE TIME. I ALLSO CAN'T TO A DIAGNOSTIC TEST.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
PF is a power failure. The unit is detecting a loss in power, but it should operate fine after the code is cleared (unplugging and plugging back in).
If the problem persists, then either you have an issue with the AC power coming from the wall outlet or the main board is faulty. Also make sure to check all the connections on the terminal block (where the AC cord attaches to the dryer) to make sure there are no loose wires or screw terminals.
Posted on Jan 18, 2009
LG WASHER/DRYER COMBO PF Issues
pf is power failure,, need to replace main board... there should be a parts/repair manual inside unit.. usually bottom panel...
Aug 15, 2016 | LG Washing Machines
I have a Frigidaire Range model PLES389DCC, it's top cooking function well, but display panel PF show, the clock start from 12:00 (after off/on circuit breaker) and kicking. I have order the control panel...
The clock may be set for 12 or 24 hour time of day operation.
The clock has been preset at the factory for 12
hour operation. When the range is first plugged in or when
the power supply to the range has been interrupted, the
timer in the display will flash and PF (power failure) will
appear in the display.
To set the clock:
1. Press Clock . "CLO" will appear in the display.
2. Example for 1:30. Press the numbers 1 3 0 to
set the time of day to 1:30. "CLO" will disappear
after 4 seconds and the clock will start. Or you may
press Start. "CLO" will disappear and the clock will
start.
Nov 29, 2010 | Frigidaire Ovens
I got pf on maytag 3000 dryer how do i fix it?
"pf" means Power Failure took place during the cycle or the cycle was interrupted, It comes when power connection is loose to the machine, Unplug your device for 5-10 MINS, plug it back then press CANCEL button.
Good Luck and have a nice day.
Jul 04, 2010 | Maytag Neptune MCE8000AY Electric Dryer
We have a frigidaire oven with flashing time and PF on display
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Mar 10, 2010 | Frigidaire FEF336BC Electric Kitchen Range
PF CODE COMES UP WHAT IS LIKELY PROBLE
Found the below at http://lgknowledgebase.com
The PF error code indicates a power failure. This might occur while machine is working due to an external disturbance like a storm or power outage in the area. If the PF error code is displayed, turn off the power to the washer, unplug it for 10 seconds, and restart the wash cycle. If the error code continues to present after these steps have been taken, then the washer may require service.
hope this helps,
best of luck, have fun,
thanks,
chuck
Feb 25, 2010 | LG WM1814CW Front Load Washer
The dryer runs for a couple seconds and then give a PF code which I think means power Failure. brand Frigidaire
that is a power failure code. check the main cisuit breaker and the cord to the dryer and make sure the connections are tight.unplug the unit for a few minutes and plug it back in this should clear the pf code out.
Feb 22, 2010 | Frigidaire AEQ6000ES Electric Dryer
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Kenmore Elite dryer shows a flashing PF
pf,,power failer...just unplug for 30 seconds,,,
Dec 31, 2008 | Kenmore 659 Electric Dryer
WHIRLPOOL SLIDE-IN RANGE
PF means power failure.  Usually you can hit cancel or clear and this will go away.  Let me know if this helps.
Oct 12, 2007 | Whirlpool RF378 Electric Kitchen Range
Kenmore 63942 Dryer Logo
89 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
