Question about Craftsman Garden
My chainsaw wants to bog down when I pull the trigger? I have a 50cc chainsaw
    Problem Solver:
  • 30 Answers
You may need to adjust the carb slightly
Posted on Jan 01, 2013
slohry
  • 87 Answers
SOURCE: chainsaw will start but will not keep going.
May need to overhaul the carb. I suggest that you replace the fuel line and fuel filter too.
Posted on Apr 09, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a craftsman chainsaw model no. 358356081
Does it have a fuel primer bulb?
Posted on Sep 26, 2009
  • 38 Answers
SOURCE: have a poulan chainsaw that won't idle/stay
no carb ajustment is done with a flat head screwdriver, first i would remove the card, disassemble it and blast it with compressed air because its probably just clogged up with varnish. to ajust the high low and idle screws bottom both out ( turn in all the way) then unscrew each one turn. from there start the saw and loosen in 1/4 turn at a time until it runs well
Posted on Apr 30, 2010
  • 13 Answers
SOURCE: what causes the chainsaw to bog down and chain to ...
check chain is sharp oiled and tension is not too tight.if sawis old check engine compression is not low.
Posted on May 26, 2010
  • 760 Answers
SOURCE: My chainsaw will start but it boggs down and shuts
Could be not getting enough fuel. Check pick up tubing and filter in tank. Or could b the choke is not opening. You didn't mention what brand but some saws have a spring that returns the choke to the open position. If its not in place, then even with the choke lever in the open position the choke is not. Remove cover and observe the position to the choke plate. If the saw has been sitting, then a good carb cleaning is in order.
Posted on Jun 30, 2010
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
What causes it to stall when trigger pulled?
Generally lack of fuel..
Pulling on the trigger doesn't increase the fuel getting into the engine like you'd think. The trigger opens up a butterfly valve which allows more air to be drawn in, this in turn draws more fuel through the carb. So if its bogging down when the throttle is pulled then generally it because not enough fuel is being drawn through b the air.. meaning there's too much air to fuel mix to burn effectively. This also can work the other way if the air filter is blocked or the exhaust is blocked with carbon deposits.
Mar 15, 2016 | Garden
The throttle trigger will not work on my 235e husqvarna
I'm guessing from the statement that it "will not work to increase speed" that you have been able to successfully start the chainsaw.
I have to look at this with the assumption that you haven't run a chain saw before, so bear with me if some of this is excessively simple.
If the throttle trigger does not move, something is jammed. The handle for the choke should automatically move to the retracted position when you pull on the throttle. If it doesn't, see if the trigger will move after you push the choke handle back in.
If the trigger moves in when you squeeze it but you don't hear any change in the engine sound then it's probable that the throttle wire has disconnected at the carburetor or at the handle.
Is the chain brake off? You need to pull it firmly back toward the upper handle for it to be disengaged. If the handle is forward it will lock the outer portion of the clutch. If you try to accelerate with it locked the engine will bog and not allow the chain to move.
Any of these conditions other than the chain brake will probably require some disassembly. Make sure you're confident that you've correctly reassembled everything if you're going to do it yourself.
Nov 22, 2013 | Husqvarna 16" Chainsaw Chain Saw Bar...
Rancher 455 wont stay running
you need too adjust the high jet ccw (making it richer) do do that takes
a little work cause you need a special tool but I can help you around that if you like. let me know
Jul 09, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
It will crank but wont run wide open
take off the muffler and run it if it revs up open the muffler and clean the screen inside you can burn it clean
May 16, 2012 | Garden
Chainsaw will start but will not keep going.
Apr 08, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
157 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
